No problem. It is exactly what I suspected. Those are great inference speeds. What hardware are you running on?
For anyone using Hassio on amd64 platform (For example the Celeron NUC Iām running on)
You can add the following URL as a repository https://github.com/mories76/ha-addon-frigate
It might work I am not a developer, no prior github experience.
@blakeblackshear a parameter CONFIG_FILE or something like that would work fine. Iāve added the /dev/dri/renderD128
Iāll try it when I can
The hardware is an older Dell Optiplex i5 at 3.4ghz. Works great for HA and pretty much anything else Iāve thrown at it.
The blakeblackshear/frigate:dev
image works great with HW Accel now!
I do notice that my min_area
isnāt being filtered though for a person
EDIT: It looks like it is filteringā¦ But itās also sending notifications for ones that are below the threshold?
I think this is happening.
When I choose not to fill out the global config, the debug screen shows it tagging all objects.
Since I have a notification set up to detect a person, it pushes that notification and is ignoring the camera specific filtering in the yaml.
So this config is missing the optional global objects
, so it tags all objects and sends notifications for people? I think thatās why this is happening to me.
cameras:
front_window:
ffmpeg:
input: REDACTED
take_frame: 2
objects:
track:
- person
filters:
person:
min_area: 235000
max_area: 3686400
threshold: 0.8
regions:
- size: 1920
x_offset: 0
y_offset: 0
I an effort to stop editing my post, Iāll summarize.
This does not correctly filter:
cameras:
front_window:
ffmpeg:
input: REDACTED
take_frame: 2
objects:
track:
- person
filters:
person:
min_area: 235000
max_area: 3686400
threshold: 0.8
regions:
- size: 1920
x_offset: 0
y_offset: 0
This does correctly filter (but at the cost of removing all non-persons from the debug view:
objects:
track:
- person
cameras:
front_window:
ffmpeg:
input: REDACTED
take_frame: 2
objects:
track:
- person
filters:
person:
min_area: 235000
max_area: 3686400
threshold: 0.8
regions:
- size: 1920
x_offset: 0
y_offset: 0
Im not sure I understand what you mean by ābut at the cost of removing all non-persons from the debug viewā. Only tracked objects are shown in the debug view now. It doesnāt waste time tracking objects that arenāt listed.
In the first example you posted, I would expect it to track person, car, and truck objects and apply the filters for size and threshold to the person object on the front_window camera. Specifying person
under track on the camera would have no effect, because the global default already includes person
In the second example, I would expect frigate to only look for person objects across all cameras. Again, specifying person
I am starting to think that the way I am merging tracked objects is too confusing.
I pushed up a new version of the beta image that might fix the issue @hawkeye217 and @billimek are running into. It also addresses the HW accell issues that @Kyle was having.
Ah. I was under the impression that the MJPEG
debugging stream would show all objects (even those not tracked) to aid with debugging. No worries if it isnāt.
What Iām seeing in my second example (posted again below) is that if I donāt include the global rule at the top of my config, the filters in the camera arenāt working. Specifically, I couldnāt get the min_area
to work inside the camera config unless I declared it
After pulling your latest 0.4.0-beta
image (sha256-a1219fac2320c10d58fec39723eed4d4da61302c6f1569161c1dad481f167f67
) it looks like the filter issue is no longer a problem. Itās either fixed or I had a problem with my config this morning.
Thanks for updating the beta to fix the VAPI! HW Accel is working great again on the latest beta.
Hi guys,
Was cpu (non coral) support included in the latest version?
Not yet. It will be available soon.
Sorry for the late reply!
Both frigate and motion are configured to receive the camera feed via rtsp.
In home assistant I have this binary_sensor for the mqtt topic that frigate publishes to
- name: Person Front Yard
platform: mqtt
state_topic: "frigate/front/person"
device_class: motion
availability_topic: "frigate/available"
I then have two automations that trigger from the state changes of that binary sensor. These automations call a shell command action to toggle the motion of motioneye to on or off.
in my automations.yaml, configured through the ui editor
- id: '1576636282260'
alias: Start motion capture
description: Starts capture on motion eyebased on person sensor
- entity_id: binary_sensor.person_front_yard
platform: state
to: 'on'
condition: []
- service: shell_command.motion_on
- id: '1576636379494'
alias: Stop motion capture
description: Stops capture on motion eyebased on person sensor
platform: state
to: 'off'
condition: []
- service: shell_command.motion_off
from configuration.yaml
shell_command:
motion_on: curl http://<motioneyeip>:7999/2/config/set?emulate_motion=on
motion_off: curl http://<motioneyeip>:7999/2/config/set?emulate_motion=off
For motioneye I only have videos enabled (other than the required sections at the top). Iāve found that I can configure the motion detection section how I want it to behave, then I turn off the motion setting. I also mask out the entire screen in motion so that its motion detection does not fire on its own. The mask may not be necessary but I swear I was seeing it intervene. Even though motion is disabled, the shell command above will trigger āmotion detectedā and it will record video with the settings (pre/post frames)
note, the 7999 is the motioneye api port, i had to enable remote control in the motion.conf file. See here
When you navigate the web ui youāll see the structure, i.e the /2/ above is the camera id.
This has been pretty stable. Iām using a wyze cam w/ the dafang hacks and itās a bit flakey. I have some todoās like consolidate the automations to a single one, get more/better cameras, etc but otherwise Iām pretty happy with it.
Iām running the latest image you pushed and there was some activity on my camera, so I just went to check the frigate logs and saw about 15 of these:
RegionPrepper: frame_time not in frame_cache
No memory leak or restarting yet, though. And the debug output is clean with 0 frames in the queue, unlike earlier.
That message doesnāt necessarily indicate a problem. It means frigate was still trying to refine object tracking on that frame, but the image expired from the cache because it was too old. It is how I tell frigate to give up and move on because it should be looking at a more recent frame. As long as it isnāt causing your queues to fill up, it should be fine.
Yep, I looked at your code and noticed it was just an informational message. Iāll let you know if I run into any more issues. Thanks!
Pushed up a new version of the 0.4.0 beta that addresses the following:
@blakeblackshear Iām having trouble with this latest version of the 0.4.0-beta image. It starts-up with some new/different logging output, but never seems to start fully and eventually times-out the healthcheck,
On connect called
ffprobe -v panic -show_error -show_streams -of json "rtsp://<redacted>@porch:554/cam/realmonitor?channel=1&subtype=1"
{'streams': [{'index': 0, 'codec_name': 'h264', 'codec_long_name': 'H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10', 'codec_type': 'video', 'codec_time_base': '0/2', 'codec_tag_string': '[0][0][0][0]', 'codec_tag': '0x0000', 'width': 0, 'height': 0, 'coded_width': 0, 'coded_height': 0, 'has_b_frames': 0, 'sample_aspect_ratio': '0:1', 'display_aspect_ratio': '0:0', 'level': -99, 'chroma_location': 'left', 'refs': 1, 'is_avc': 'false', 'nal_length_size': '0', 'r_frame_rate': '90000/1', 'avg_frame_rate': '0/0', 'time_base': '1/90000', 'disposition': {'default': 0, 'dub': 0, 'original': 0, 'comment': 0, 'lyrics': 0, 'karaoke': 0, 'forced': 0, 'hearing_impaired': 0, 'visual_impaired': 0, 'clean_effects': 0, 'attached_pic': 0, 'timed_thumbnails': 0}}]}
ffprobe -v panic -show_error -show_streams -of json "rtsp://<redacted>@front:554/cam/realmonitor?channel=1&subtype=1"
ffprobe -v panic -show_error -show_streams -of json "rtsp://<redacted>@driveway:554/cam/realmonitor?channel=1&subtype=1"
ffprobe -v panic -show_error -show_streams -of json "rtsp://<redacted>@pool:554/cam/realmonitor?channel=1&subtype=1"
ffprobe -v panic -show_error -show_streams -of json "rtsp://<redacted>@basement:554/h264Preview_01_sub"
Any ideas? Configuration used is here.
Thatās strange. ffprobe is showing your width and height at 0. Not sure why it isnāt working for your camera. Can you try this command?
ffprobe -v error -select_streams v:0 -show_entries stream=height,width -of csv=s=x:p=0 <rtsp_url>
Sure thing,
root@frigate-577b57559f-jtgtl:/opt/frigate# ffprobe -v error -select_streams v:0 -show_entries stream=height,width -of csv=s=x:p=0 "rtsp://<redacted>@front:554/cam/realmonitor?channel=1&subtype=1"
[rtsp @ 0x55a201f2f6a0] method SETUP failed: 454 Session Not Found
0x0
root@frigate-577b57559f-jtgtl:/opt/frigate# ffprobe -v error -select_streams v:0 -show_entries stream=height,width -of csv=s=x:p=0 "rtsp://<redacted>@driveway:554/cam/realmonitor?channel=1&subtype=1"
[rtsp @ 0x5624fb41d6a0] method SETUP failed: 454 Session Not Found
0x0
root@frigate-577b57559f-jtgtl:/opt/frigate# time ffprobe -v error -select_streams v:0 -show_entries stream=height,width -of csv=s=x:p=0 "rtsp://<redacted>@pool:554/cam/realmonitor?channel=1&subtype=1"
[rtsp @ 0x55bdcc1ec6a0] method SETUP failed: 454 Session Not Found
0x0
real 0m10.433s
user 0m0.086s
sys 0m0.039s
Here is the command against three of the cameras - the last command included a time
wrapper, it seems to ātime outā after 10s based on my observations.
As an aside, after auto-restarting about 7 times (due to the healthcheck probe failing), it eventually went live, but the camera pages are returning a 500 with the following stack trace in the logs,
10.42.3.41 - - [19/Jan/2020 01:52:04] "GET /porch HTTP/1.1" 500 -
Error on request:
File "/usr/local/lib/python3.6/dist-packages/werkzeug/serving.py", line 304, in run_wsgi
execute(self.server.app)
File "/usr/local/lib/python3.6/dist-packages/werkzeug/serving.py", line 294, in execute
for data in application_iter:
File "/usr/local/lib/python3.6/dist-packages/werkzeug/wsgi.py", line 506, in __next__
return self._next()
File "/usr/local/lib/python3.6/dist-packages/werkzeug/wrappers/base_response.py", line 45, in _iter_encoded
for item in iterable:
File "/opt/frigate/detect_objects.py", line 146, in imagestream
frame = cameras[camera_name].get_current_frame_with_objects()
File "/opt/frigate/frigate/video.py", line 385, in get_current_frame_with_objects
frame_bytes = self.frame_with_objects(frame_time)
File "/opt/frigate/frigate/video.py", line 366, in frame_with_objects
time_to_show = datetime.datetime.fromtimestamp(frame_time).strftime("%m/%d/%Y %H:%M:%S")
TypeError: an integer is required (got type NoneType)
ā¦ and the debug page suggests that it isnāt capturing anything from the cameras,
