Local realtime person detection for RTSP cameras
No other errors before that message? Are you using a Coral?
Yep, I do have a usb Coral and the logs dont complain about TPU not being there so I am assuming it is being used. I also obeserved that this only happens with Unifi RTSP stream(1024x576 H264) cameras but not with Hikvision substream(640x480 H264H). I can try reducing the aspect ratioā€¦may be that will help. Will post update in a bit.
Update: Tried lowering the resolutionā€¦ didnt help. Process got stuck the moment there was motion but the Hikvision camera stream detection seems to work fine.
So it works if you only setup your hikvision cameras and stops if you add your unifi cameras?
Correct. Btw, all cameras work great with v0.3
Edit: To clarify - All cameras startup fineā€¦I can see the debug stream working fine. I get the error mentioned above about detection appearing to be stuck only from unifi cameras when there is motion.
Edit2: Confirmedā€¦works fine v0.3 and near instant detection too.
Edit3: Hikvision camera stream seems to be getting stuck after a bit as well.
It should restart the detection subprocess and keep going. What happens after it says it is stuck?
Like you said it restarts the process but gets stuck again. The debug stream ā€œdiesā€ as in I can see the timestamp frozen.
And 0.4.0 does not work either right? Trying to narrow down where the change could have happened.
Double checked - it looks like 0.4.0-beta works. Seems to be post 0.5.0-rc1.
Edit: Here is the version breakdown and status
  • 0.3.0 - Everything works great and near instant
  • 0.4.0-beta - Everything works but choppy/slow
  • 0.5.0-rc1 - I get the following error when I try to pull up the debug frame:
Error on request:
  File "/usr/local/lib/python3.7/dist-packages/werkzeug/serving.py", line 323, in run_wsgi
    execute(self.server.app)
  File "/usr/local/lib/python3.7/dist-packages/werkzeug/serving.py", line 314, in execute
    for data in application_iter:
  File "/usr/local/lib/python3.7/dist-packages/werkzeug/wsgi.py", line 506, in __next__
    return self._next()
  File "/usr/local/lib/python3.7/dist-packages/werkzeug/wrappers/base_response.py", line 45, in _iter_encoded
    for item in iterable:
  File "/opt/frigate/detect_objects.py", line 224, in imagestream
    frame = object_processor.get_current_frame(camera_name)
  File "/opt/frigate/frigate/object_processing.py", line 47, in get_current_frame
    return self.camera_data[camera]['current_frame']
KeyError: 'current_frame'
  • 0.5.0-rc2 - Same error as above
  • 0.5.0-rc3 - I get black screen in the debug stream with the following errorā€¦
/arrow/cpp/src/plasma/store.cc:738: Disconnecting client on fd 8
  • 0.5.0-rc4 - Same black screen as above
driveway: ffmpeg_process exited unexpectedly with 1
driveway: exiting subprocess
  • 0.5.0-rc5 - Debug stream works fine but the error mentioned above happens.
Detection appears to be stuck. Restarting detection process
Hope this helps and let me know if you need any additional info
@blakeblackshear
Unless Iā€™m missing something, thereā€™s no easy way to view the logs in a container on Synology.
There is a logs tabs in the UI but I canā€™t figure out how to simply view the logs in a terminal.
ie: tail -f logfile
Can you add an option to direct the logs to a regular log file?
Iā€™ve had a few instances where 1 of my 2 feeds stopped getting processed by frigate.
when this happens, going to the 5555/ url would show the last time the feed was working.
This happened twice.
A third time, the feed stopped for both and nothing was showing in the Terminal view.
In a previous post you mentioned the restart is not required in the Run the container with section of your docs. Does that mean restarts are enabled by default or if I donā€™t have that, they are not?
Iā€™m using grafana for better graphing and this shows where the drops are.
The first 2 areas show where one camera feed just stopped getting processed
The 3rd area shows where frigate just died.
Viewing logs like this doesnā€™t work? https://www.synology.com/en-us/knowledgebase/DSM/tutorial/Virtualization/How_can_I_debug_and_fix_common_Docker_container_issues
Frigate manages all the processes itself, and very rarely crashes in a way that would cause the container to stop. Docker only restarts the container if it exits. Adding the restart unless-stopped parameter would only have an effect if the container actually exits or the server restarts.
Just realized that I never call the function to restart the detection process when it gets stuck. I just log a message and keep going. Going to fix and push up rc6 tonight. :man_facepalming:
rc3 rc4 rc5 rc6 and rc7:
Iā€™m randomly having black screens on the debug url.
Killing and recreating the container with the exact same config sometime solve the problem.
It seems to not start the ffmpeg process?
I donā€™t have this line in the logs when the issue happens:
frigate    | {'streams': [{'index': 0, 'codec_name': 'h264', 'codec_long_name': 'H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10', 'profile': 'High', 'codec_type': 'video', 'codec_time_base': etc...
/debug/stats
{"camera1":{"detection_fps":0.0,"fps":5.0,"skipped_fps":0.0},"coral":{"detection_queue":0,"detection_start":0.0,"fps":0.0,"inference_speed":10.0},"plasma_store_rc":null,"tracked_objects_queue":0}
Ok. Here is rc6.
Changes:
  • Update docs
  • Handle errors better in detection process
  • Actually call the restart function when detection hangs
Docker image is available with docker pull blakeblackshear/frigate:0.5.0-rc6
it works but itā€™s not as good as tail -f logfile
the first Log view they mention just shows basic ā€œcontainer started, stopped, deleted, etcā€¦ no actual frigate infoā€
the second Log view they mention isnā€™t as interactive and when it Exports it reverses the order so itā€™s not a share friendly.
for exampleā€¦ hereā€™s the latest output (thereā€™s nothing to check, iā€™m just showing the output)
Frigate-0.5.0-rc6
date stream content
2020-03-02 01:04:13 stderr [rawvideo @ 0x5568d9575680] Encoder did not produce proper pts, making some up.
2020-03-02 01:04:13 stderr encoder : Lavc57.107.100 rawvideo
2020-03-02 01:04:13 stderr Metadata:
2020-03-02 01:04:13 stderr Stream #0:0: Video: rawvideo, 1 reference frame (RGB[24] / 0x18424752), rgb24(left), 1920x1080, q=2-31, 746496 kb/s, 15 fps, 15 tbn, 15 tbc
2020-03-02 01:04:13 stderr encoder : Lavf57.83.100
2020-03-02 01:04:13 stderr comment : live
2020-03-02 01:04:13 stderr title : Session streamed by ā€œwyzeā€
2020-03-02 01:04:13 stderr Output #0, rawvideo, to ā€˜pipe:ā€™:
2020-03-02 01:04:13 stderr [auto_scaler_0 @ 0x5568d962b760] w:1920 h:1080 fmt:yuv420p sar:0/1 ā†’ w:1920 h:1080 fmt:rgb24 sar:0/1 flags:0x4
2020-03-02 01:04:13 stderr [format @ 0x5568d95a2220] auto-inserting filter ā€˜auto_scaler_0ā€™ between the filter ā€˜Parsed_null_0ā€™ and the filter ā€˜formatā€™
2020-03-02 01:04:13 stderr [auto_scaler_0 @ 0x5568d962b760] w:iw h:ih flags:ā€˜bicubicā€™ interl:0
2020-03-02 01:04:12 stderr frame= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbits/s speed=N/A frame= 23 fps= 11 q=-0.0 size= 201204kB time=00:00:01.15 bitrate=1433272.3kbits/s speed=0.554x [graph 0 input from stream 0:0 @ 0x5568d95a1380] w:1920 h:1080 pixfmt:yuv420p tb:1/90000 fr:15/1 sar:0/1 sws_param:flags=2
2020-03-02 01:04:11 stderr frame= 12 fps=7.8 q=-0.0 size= 104976kB time=00:00:00.60 bitrate=1433272.3kbits/s speed=0.39x [h264 @ 0x5568d95590c0] Reinit context to 1920x1088, pix_fmt: yuv420p
2020-03-02 01:04:11 stderr Press [q] to stop, [?] for help
2020-03-02 01:04:11 stderr Stream #0:0 ā†’ #0:0 (h264 (native) ā†’ rawvideo (native))
2020-03-02 01:04:11 stderr Stream mapping:
2020-03-02 01:04:11 stderr Stream #0:1: Audio: pcm_alaw, 8000 Hz, mono, s16, 64 kb/s
2020-03-02 01:04:11 stderr Stream #0:0: Video: h264 (Main), 1 reference frame, yuv420p(progressive, left), 1920x1080 (1920x1088), 15 fps, 15 tbr, 90k tbn, 30 tbc
2020-03-02 01:04:11 stderr Duration: N/A, start: 1583111049.299267, bitrate: N/A
2020-03-02 01:04:11 stderr comment : live
2020-03-02 01:04:11 stderr title : Session streamed by ā€œwyzeā€
2020-03-02 01:04:11 stderr Metadata:
2020-03-02 01:04:11 stderr Input #0, rtsp, from ā€˜rtsp://g6ev8v43:[email protected]/liveā€™:
2020-03-02 01:04:11 stderr frame= 1 fps=1.0 q=-0.0 size= 8748kB time=00:00:00.05 bitrate=1433272.3kbits/s speed=0.0494x Guessed Channel Layout for Input Stream #0.1 : mono
2020-03-02 01:04:10 stderr [rawvideo @ 0x5567e0378400] Encoder did not produce proper pts, making some up.
2020-03-02 01:04:10 stderr encoder : Lavc57.107.100 rawvideo
2020-03-02 01:04:10 stderr Metadata:
2020-03-02 01:04:10 stderr Stream #0:0: Video: rawvideo, 1 reference frame (RGB[24] / 0x18424752), rgb24(left), 2304x1296 [SAR 1:1 DAR 16:9], q=2-31, 1433272 kb/s, 20 fps, 20 tbn, 20 tbc
2020-03-02 01:04:10 stderr encoder : Lavf57.83.100
2020-03-02 01:04:10 stderr title : Media Server
2020-03-02 01:04:10 stderr Output #0, rawvideo, to ā€˜pipe:ā€™:
2020-03-02 01:04:10 stderr [auto_scaler_0 @ 0x5567e03aa320] w:2304 h:1296 fmt:yuvj420p sar:1/1 ā†’ w:2304 h:1296 fmt:rgb24 sar:1/1 flags:0x4
2020-03-02 01:04:10 stderr [swscaler @ 0x5567e042a9e0] deprecated pixel format used, make sure you did set range correctly
2020-03-02 01:04:10 stderr [format @ 0x5567e03a77e0] auto-inserting filter ā€˜auto_scaler_0ā€™ between the filter ā€˜Parsed_null_0ā€™ and the filter ā€˜formatā€™
2020-03-02 01:04:10 stderr [auto_scaler_0 @ 0x5567e03aa320] w:iw h:ih flags:ā€˜bicubicā€™ interl:0
2020-03-02 01:04:10 stderr frame= 0 fps=0.0 q=0.0 size= 0kB time=-577014:32:22.77 bitrate= -0.0kbits/s speed=N/A [graph 0 input from stream 0:0 @ 0x5567e03af1e0] w:2304 h:1296 pixfmt:yuvj420p tb:1/90000 fr:20/1 sar:1/1 sws_param:flags=2
2020-03-02 01:04:09 stderr [h264 @ 0x5567e03fbac0] Reinit context to 2304x1296, pix_fmt: yuvj420p
2020-03-02 01:04:09 stderr Press [q] to stop, [?] for help
Similar error with 0.5.0-rc6
Waiting for detection process to exit gracefully...
/arrow/cpp/src/plasma/store.cc:738: Disconnecting client on fd 6
Starting detection process: 124
At least it is actually restarting it now. Does it restart over and over?
Yep. It just keeps restarting but the debug screen remains frozen.
Can you post the output of /debug/stats?
I am primarily testing Backpatio atm.
Starting detection process: 126
