holy crap, for some reason I missed the HW acceleration stuff in my config. when I added these in, I saw my nuc load go from ~5 to ~1. thanks for all your hard work on this, really appreciate it!
So I got Frigate 0.5.* working on unraid (Thanks @hollywoodford). I have just noticed the vs 0.4 I see massive smearing (Reolink RLC-410 5MP) on the image when its nighttime and using IR which makes detection impossible.
Anyone with these cameras have suggestions for configs which work?
reolink does not behave well with rtsp,
you should use rtmp:
ffmpeg:
input: rtmp://192.168.0.199/bcs/channel0_sub.bcs?token=254&channel=1&stream=0&user=username&password=password
if i add my reolink cameras as rtmp it gives me an error and frigate does not start
Ill give it a try.
Hi there,
I would really like to have Frigate running, can someone please geve some advice on how to do this with the HA portainer add-on? So far I managed to pull the image from blakeblackshear/frigate:stable (not much, I know) but I am unsure of how to proceed from there.
Thanks in advance
Okay not sure whatās going on using the command:
sudo docker run --rm \
--privileged \
--shm-size=1024m \
-v gpus=all \
-v/opt/frigate:/config:ro \
-v /etc/localtime:/etc/localtime:ro \
-p 5001:5001 \
And getting the result of:
File "detect_objects.py", line 25, in <module>
with open('/config/config.yml') as f:
FileNotFoundError: [Errno 2] No such file or directory: '/config/config.yml'
Iāve checked the file and directory and I do have: ā/config/config.ymlā can anyone help please Iāve been trying this for some time a straightforward method would be Great
If you are not so familiar with Docker and Portainer, you can just use the Frigate addon for HA: https://github.com/mories76/ha-addon-frigate
hello, just add that line in config.yml for the camera? shouldnāt I add or change an argument? I have tried adding my cameras as well, but it gives me the following error: under1: ffmpeg didnt return a frame. something is wrong. under1: ffmpeg process is not running. exiting capture thread ā¦
Best way using portainer is to add frigate as a stack using the docker-compose script. I donāt have an example because I donāt do it this way, but itās not too hard once you get the variables set right, not really much different than getting a hass.io addon working but a few more variables to contend with.
In case it helps someone else, after thinking about it I have obtained that it will work with the following configuration:
ffmpeg:
input: rtmp://192.168.1.6:1935/bcs/channel0_sub.bcs?channel=0&stream=0&user=xxxxxxx&password=xxxxxxx
hwaccel_args:
- -hwaccel
- vaapi
- -hwaccel_device
- /dev/dri/renderD128
- -hwaccel_output_format
- yuv420p
input_args:
- -avoid_negative_ts
- make_zero
- -fflags
- nobuffer
- -flags
- low_delay
- -strict
- experimental
- -fflags
- +genpts+discardcorrupt
- -vsync
- drop
- -use_wallclock_as_timestamps
- '1'
Okay Iāve solved that issue frigate is now running but I still have an error:
[rtsp @ 0x559173fe2a20] RTP: missed 1 packets
[rtsp @ 0x559173fe2a20] max delay reached. need to consume packet
[h264 @ 0x559173fe6480] concealing 3231 DC, 3231 AC, 3231 MV errors in P frame
[rtsp @ 0x559173fe2a20] decoding for stream 0 failed
Input #0, rtsp, from 'rtsp://root:[email protected]:8554/unicast':
Metadata:
title : LIVE555 Streaming Media v2020.03.06
comment : LIVE555 Streaming Media v2020.03.06
Duration: N/A, start: 0.180700, bitrate: N/A
Stream #0:0: Video: h264 (Main), yuv420p(progressive), 1600x900, 25 fps, 25 tbr, 90k tbn, 50 tbc
Stream #0:1: Audio: mp3, 44100 Hz, mono, s16p, 64 kb/s
[NULL @ 0x5591740da240] Unable to find a suitable output format for 'pipe:'
pipe:: Invalid argument
back: ffmpeg didnt return a frame. something is wrong.
back: ffmpeg process is not running. exiting capture thread...
Does anyone have any ideas on how I can fix this please thank youā¦
scstraus:
will stick to the add-on for nowā¦
Mario:
thanks fot the heads up!
Having an add-on is great! But is not working (I am starting to hate be a noob) Anyway, installed it, created the config.yml in the proper folder and added the camera, binary sensor and sensor to my configuration.yaml. Was hoping to see it working, but pressing the start button has no effect, after a moment is back to start as opposed to stop.
What am I doing wong? Can it be an error in the config file?
Hi Blake
Iāve been running v0.5.1 stable since it was released, but it has been failing on average every 4-5 days. When this happens, objects are not detected. The debug stats return all frames as āSkippedā, and there is no activity on the Coral.
I was waiting to catch it again as soon as it happened so I could check if there was anything meaningful in the log at the point it started, but there is not.
This evening it died at 1747.
2020-07-12T09:19:20.432438109Z Camera_process started for driveway: 36
2020-07-12T09:19:20.442843181Z Camera_process started for side: 37
2020-07-12T09:19:20.451120258Z Starting process for driveway: 36
2020-07-12T09:19:20.454022774Z Camera_process started for back: 38
2020-07-12T09:19:20.462770860Z Starting process for side: 37
2020-07-12T09:19:20.482972849Z Starting process for back: 38
2020-07-12T09:19:20.490384351Z Camera_process started for backside: 39
2020-07-12T09:19:20.491902376Z Starting process for backside: 39
2020-07-12T09:19:20.509883316Z Starting process for frontdoor: 40
2020-07-12T09:19:20.515580537Z Camera_process started for frontdoor: 40
2020-07-12T09:19:20.538748430Z * Serving Flask app "detect_objects" (lazy loading)
2020-07-12T09:19:20.538969666Z * Environment: production
2020-07-12T09:19:20.539018276Z WARNING: Do not use the development server in a production environment.
2020-07-12T09:19:20.539042628Z Use a production WSGI server instead.
2020-07-12T09:19:20.539068405Z * Debug mode: off
2020-07-13T17:47:22.321685309Z Detection appears to be stuck. Restarting detection process
2020-07-13T17:47:22.321775216Z Waiting for detection process to exit gracefully...
2020-07-13T17:47:22.355060110Z Starting detection process: 10799
2020-07-13T17:47:25.261354539Z ../src/plasma/client.cc:182: mmap failed
2020-07-13T17:47:25.262250344Z /usr/local/lib/python3.7/dist-packages/pyarrow/libarrow.so.17(+0x614cc0)[0xac74acc0]
2020-07-13T17:47:25.262688210Z /usr/local/lib/python3.7/dist-packages/pyarrow/libarrow.so.17(_ZN5arrow4util8ArrowLogD1Ev+0x108)[0xac74ade0]
2020-07-13T17:47:25.262734709Z /usr/local/lib/python3.7/dist-packages/pyarrow/libplasma.so.17(+0xd0f4)[0xabf000f4]
2020-07-13T17:47:25.262889986Z /usr/local/lib/python3.7/dist-packages/pyarrow/libplasma.so.17(+0xdd54)[0xabf00d54]
2020-07-13T17:47:25.262919596Z /usr/local/lib/python3.7/dist-packages/pyarrow/libplasma.so.17(+0xe8ac)[0xabf018ac]
2020-07-13T17:47:25.262942189Z /usr/local/lib/python3.7/dist-packages/pyarrow/libplasma.so.17(_ZN6plasma12PlasmaClient3GetERKSt6vectorINS_8UniqueIDESaIS2_EExPS1_INS_12ObjectBufferESaIS7_EE+0x24)[0xabf019a4]
2020-07-13T17:47:25.262964614Z /usr/local/lib/python3.7/dist-packages/pyarrow/_plasma.cpython-37m-arm-linux-gnueabihf.so(+0x22d40)[0xabf45d40]
2020-07-13T17:47:25.262986003Z /usr/local/lib/python3.7/dist-packages/pyarrow/_plasma.cpython-37m-arm-linux-gnueabihf.so(+0x1d334)[0xabf40334]
2020-07-13T17:48:52.434941577Z Detection appears to have stopped. Restarting detection process
2020-07-13T17:48:52.458307822Z Starting detection process: 10816
2020-07-13T17:48:55.317279066Z ../src/plasma/client.cc:182: mmap failed
2020-07-13T17:48:55.318371386Z /usr/local/lib/python3.7/dist-packages/pyarrow/libarrow.so.17(+0x614cc0)[0xac74acc0]
2020-07-13T17:48:55.318888195Z /usr/local/lib/python3.7/dist-packages/pyarrow/libarrow.so.17(_ZN5arrow4util8ArrowLogD1Ev+0x108)[0xac74ade0]
2020-07-13T17:48:55.318938602Z /usr/local/lib/python3.7/dist-packages/pyarrow/libplasma.so.17(+0xd0f4)[0xabf000f4]
2020-07-13T17:48:55.318962935Z /usr/local/lib/python3.7/dist-packages/pyarrow/libplasma.so.17(+0xdd54)[0xabf00d54]
2020-07-13T17:48:55.318986305Z /usr/local/lib/python3.7/dist-packages/pyarrow/libplasma.so.17(+0xe8ac)[0xabf018ac]
2020-07-13T17:48:55.319008971Z /usr/local/lib/python3.7/dist-packages/pyarrow/libplasma.so.17(_ZN6plasma12PlasmaClient3GetERKSt6vectorINS_8UniqueIDESaIS2_EExPS1_INS_12ObjectBufferESaIS7_EE+0x24)[0xabf019a4]
2020-07-13T17:48:55.319031434Z /usr/local/lib/python3.7/dist-packages/pyarrow/_plasma.cpython-37m-arm-linux-gnueabihf.so(+0x22d40)[0xabf45d40]
2020-07-13T17:48:55.319053656Z /usr/local/lib/python3.7/dist-packages/pyarrow/_plasma.cpython-37m-arm-linux-gnueabihf.so(+0x1d334)[0xabf40334]
2020-07-13T17:50:22.534771178Z Detection appears to have stopped. Restarting detection process
2020-07-13T17:50:22.573770457Z Starting detection process: 10833
2020-07-13T17:50:25.429654956Z ../src/plasma/client.cc:182: mmap failed
2020-07-13T17:50:25.430757257Z /usr/local/lib/python3.7/dist-packages/pyarrow/libarrow.so.17(+0x614cc0)[0xac74acc0]
2020-07-13T17:50:25.431220066Z /usr/local/lib/python3.7/dist-packages/pyarrow/libarrow.so.17(_ZN5arrow4util8ArrowLogD1Ev+0x108)[0xac74ade0]
2020-07-13T17:50:25.431389842Z /usr/local/lib/python3.7/dist-packages/pyarrow/libplasma.so.17(+0xd0f4)[0xabf000f4]
2020-07-13T17:50:25.431422915Z /usr/local/lib/python3.7/dist-packages/pyarrow/libplasma.so.17(+0xdd54)[0xabf00d54]
2020-07-13T17:50:25.431445989Z /usr/local/lib/python3.7/dist-packages/pyarrow/libplasma.so.17(+0xe8ac)[0xabf018ac]
2020-07-13T17:50:25.431468433Z /usr/local/lib/python3.7/dist-packages/pyarrow/libplasma.so.17(_ZN6plasma12PlasmaClient3GetERKSt6vectorINS_8UniqueIDESaIS2_EExPS1_INS_12ObjectBufferESaIS7_EE+0x24)[0xabf019a4]
2020-07-13T17:50:25.431490896Z /usr/local/lib/python3.7/dist-packages/pyarrow/_plasma.cpython-37m-arm-linux-gnueabihf.so(+0x22d40)[0xabf45d40]
2020-07-13T17:50:25.431512414Z /usr/local/lib/python3.7/dist-packages/pyarrow/_plasma.cpython-37m-arm-linux-gnueabihf.so(+0x1d334)[0xabf40334]
2020-07-13T17:51:52.646667867Z Detection appears to have stopped. Restarting detection process
2020-07-13T17:51:52.664862689Z Starting detection process: 10851
2020-07-13T17:51:55.502596252Z ../src/plasma/client.cc:182: mmap failed
Many thanks
I havenāt see the āmmap failedā error from the plasma store. Not entirely sure what that could be, but it sounds like an issue with the plasma client trying to read or write from memory.
Never mind, disabled protected modeā¦
Edit: Spoke too fastā¦ stops after a few momentsā¦
i donāt use environment variables as i just saw it easier to define that in my config file.
you can pretty much just use @blakeblackshear 's examples.
below is a sanitized version of my docker-compose
In portainer, click on stacks, add new stack, give it a name (i called this stack object-detection) then in the editor use my snippet below or the example from @blakeblackshear 's repo.
before starting the stack, you need to make sure you have a proper config file in the config folder to reference otherwise the container will just error out
version: '2'
services:
frigate:
container_name: frigate
restart: unless-stopped
privileged: true
shm_size: '2g' # should work for 5-7 cameras
image: blakeblackshear/frigate:0.5.1
# image: blakeblackshear/frigate:stable
volumes:
- /dev/bus/usb:/dev/bus/usb
- /etc/localtime:/etc/localtime:ro
- <PATH_TO_YOUR_CONFIG_FOLDER>:/config
ports:
- "5000:5000"
devices:
- /dev/dri:/dev/dri
I use the āmainā url below for my RLC-420.
input: rtmp://192.168.2.140/bcs/channel0_main.bcs?token=254&channel=0&stream=0&user=USERNAMEHERE&password=PASSWORDHERE
and hereās a link to my whole frigate.yml if itās helpful. Iām not currently using HW accel, but need to try it out.
Hrmā¦I tried adding the hwaccel args, but now itās just stuck trying to create the FFMPEG process. Iāve tried passing both /dev/dri and /dev/dri/renderD128 to the docker, but no dice. I just got a new 10th gen Intel (i7-10700), could that have anything to do with it?
Creating ffmpeg process...
ffmpeg -hide_banner -loglevel panic -hwaccel vaapi -hwaccel_device /dev/dri/renderD128 -hwaccel_output_format yuv420p -avoid_negative_ts make_zero -fflags nobuffer -flags low_delay -strict experimental -fflags +genpts+discardcorrupt -vsync drop -use_wallclock_as_timestamps 1 -i rtmp://192.168.2.140/bcs/channel0_main.bcs?token=254&channel=0&stream=0&user=admin&password=PASSWORD -f rawvideo -pix_fmt rgb24 pipe:
front: ffmpeg didnt return a frame. something is wrong.
front: ffmpeg process is not running. exiting capture thread...
edit: I should add, I have it passed through fine to my Plex docker, just canāt get it to work here.
You were right: I was not using a pure black color.
