I thought the constant trouble Iāve been having was due to the Wyze camera.
I picked up a Eufy Indoor 2k camera. Unfortunately, the RTSP feed is only 1080p.
Hereās a video from my Eufy camera. The quality looks worse than the Wyze and you can see the constant detection.
Has anyone had decent luck with Wyze cameras or cheap RTSP cameras?
I also notice that at night itās hard to trigger the motion detection. Once triggered it tracks the objects fine. Some cameras are more or less noisy than others under night vision. I notice this problem with one of my less noisy cameras. Maybe have an adjustable sensitivity per camera?
Check out the edges. Iām not sure but I think itās called artifacts? Itās not smooth so it seems to get detected as a new image.
It was pretty bad with the Wyze camera as well.
You mean the jagged edges on the columns? The debug feed is encoded with the lowest quality jpeg conversion to minimize CPU usage. Frigate sees the same quality you would see using VLC. If you append ?h=1080 to your preview endpoint, you will get the least artifacts from the jpeg conversion if it is a 1080p stream. What do you mean detected as a new image? Frigate is going to look for that car in every frame until it disappears. It looks anywhere there is motion AND anywhere a tracked object was in previous frames.
Man, have you seen something like this? If not, then you have no idea about artefacts And this is not a RTSP stream issue, frigate sometimes/often somehow corrupts the image (OR itās single image RTSP corruption which is picked up by frigate, donāt know, never seen this in stream itself)
coolā¦ i guess I got bad info.
Which camera are you using?
Iām looking for a Wifi camera capable of RTSP.
Except for the low quality RTSP feed, the Eufy is nice. Great control of finding recorded video. Decent app, etcā¦ this is compared to my Wyze cameras.
@blakeblackshear I am trying the 0.6.0-rc1 and having issue with the clips. I am using RTSP stream from Reolink cameras
* Debug mode: off
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x559c6d68d4c0] moov atom not found
/cache/back-20200821210423.mp4: Invalid data found when processing input
bad file: back-20200821210423.mp4
bad file: garage-20200821210335.mp4
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x5585a6bb34c0] moov atom not found
/cache/garage-20200821210335.mp4: Invalid data found when processing input
I just bought a Google Coral and connected it to my DS218+ , looks like itās detected in /debug/stats
But i have 90% CPU usage even with the google coral.
Does somebody know why ?
It looks like this is due to showing lower fps than cameraās feed. Following fix seems to resolve this issue also. My camera feed is 7fps and whenever I see this issue, the frigate camera fps shows 2-4 fps
Me too! Iām currently using a combination of Zoneminder (which doesnāt cope well with multiple high resolution cameras) and Synology, held together with bits of string and wishful thinking
It would be great to get a better solution that integrates natively with HA. I found this thread today and Iāve already ordered the Coral accelerator to start playing with it!
