All my devices are renamed. I have over 150 zwave devices, so everything needs to be named clean. The latest version of HA allows for easy rename of all device base names. I will remove and readd to see if that fixes things, but my basename is lock_deadbolt. I have nothing that has the original basename. With tons of light switches/sensors/etc. they start showing up as basename(1) basename(2) etc.
Also I completely removed the package, removed the left behind entities in HA, removed my doorlock and re added it. So now my naming is identical to your, and have the same issue.
Think I found the problem. Do a pull then run the script again. Then check the template. If there is no error you should be good. It’s totally weird how I found this error doing something else
Ok way farther now. No errors in the log file. However now when I add a username and pinn and click enable the status changes to connected but nothing happens. I don’t see any communication with the lock in my zwave logs. Not sure where to troubleshoot.
Yes it does. I expected that as soon as I select enabled, and the status turned to yellow that I would see it send the set message out via Zwave. It is almost like a automation is broken somewhere…
Mine is working. Start throwing this into your generated automations actions block to track what is firing and what is not. Especially the FrontDoor Add Code automation
I missed this. That’s a good idea. Yes, you have to tweak you other automations, however you can create sensors with your naming scheme that just pony off the new lock name. I do this all the time so I only have to change entity names in one or two places.
Oh snap! I forgot to document this. Make sure you have created a sensor named binary_sensor.allow_automation .I use this during startup to prevent automations from running. Put this where you create sensors. Then create the input_boolean allow_automation_execution and set it to true.
Deleted codes are randomized per what @ptdalen discovered that you can’t “wipe” slots. I was going to see if you could factory reset the lock to wipe the slots, but that doesn’t work.
Six digit codes might work with a little tweaking. Matter of fact it might work already. I just haven’t adjusted the lock to try .
