I tried HA few different ways, installed it on SD card for raspberry Pi4 as well as Virtual Machine. In each instance I am able to access the HA using http://ip_address:8123 but I cannot log into the host system from command line. There is prompt for login and I tried using “pi:passwd”, “pi:raspberry” and few other combinations but nothing works.
Any clue how to login into host system from command line? I need to install HACS and need access to command line.
Thanks,
Pankaj
