Thank you for the quick response!
I just did that and found this:
Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py", line 339, in _async_add_entity
'Invalid entity id: {}'.format(entity.entity_id))
homeassistant.exceptions.HomeAssistantError: Invalid entity id: camera.
At first I thought this might have something to do with my naming, since I used Chinese characters during the first setup. So I changed it in the App, didnāt work.
Then I reset the camera using the App and gave it an āEnglish-onlyā name, didnāt work.
Then I manually reset the Camera again by pressing the button for 9 seconds and even connecting it to another, new account and only use English characters to name it. Still the same message.
The Circle App and HomeKit are working fine though. Just home-assistant doesnāt seam to want to give it a name.
Hey, sorry about this @TTDARK. Looks like the Logi API wrapper (python-logi-circle) is returning an empty string to home assistant when querying its name. I have no idea why, though maybe the API behaves differently across different regions.
Without knowing the root cause, one change I can try is to have it use the cameraās serial number or MAC address in place of its name if the name is empty. Iāll post that after work today.
If that doesnāt work, Iāll need your help to see what exactly Logiās API is returning for your account (with anything sensitive scrubbed of course) to fix it properly.
This might also be fixed by switching to Logiās official API, which I just got access to a few hours ago. It will however take a while to refactor the integration to use it.
OK @TTDARK , can you please go here: https://github.com/evanjd/hass-logi-circle/tree/regional_issues
Click the Clone or Download dropdown, then download ZIP. Place the contents in your custom_components folder (you will need to create it if it doesnāt already exist, create it inside your home assistant config directly).
Once done, restart and see if the camera works then? Theyāll have an ugly UUID as their name, but you can easily rename it once the entities are functioning.
I ran into an issue this morning setting up the camera for some automation:
Error doing job: Future exception was never retrieved
File "/usr/local/lib/python3.6/site-packages/logi_circle/camera.py", line 276, in get_livestream_image
image = _get_first_frame_from_video(segment_temp_file_path)
File "/usr/local/lib/python3.6/site-packages/logi_circle/utils.py", line 92, in _get_first_frame_from_video
stderr=subprocess.DEVNULL
File "/usr/local/lib/python3.6/subprocess.py", line 336, in check_output
**kwargs).stdout
File "/usr/local/lib/python3.6/subprocess.py", line 418, in run
output=stdout, stderr=stderr)
subprocess.CalledProcessError: Command '['ffmpeg', '-i', '/tmp/tmpve64bjsb', '-vf', 'select=eq(n\\,0)', '-q:v', '3', '-f', 'singlejpeg', '-']' died with <Signals.SIGSEGV: 11>.
This error occurs when triggering the service camera.logi_circle_livestream_snapshot from the hassio interface with the following service data:
The folder camera_test exists and hassio should be able to write to it since itās an internal folder. Ie. whitelist_external_dirs shouldnāt be necessary.
Running hass.io 0.86.1 on a Rpi3. The camera works fine otherwise. I can see the picture and all sensors.
Got any ideas why this is happening? Should I enter this as an issue in the HA Github?
@vegard Do you know how recently this started? That error means that ffmpeg is seg faulting when converting the 1st frame of the live stream snapshot into a jpeg, which is⦠strange. I wonder if hass.io has recently updated/changed ffmpeg.
For what itās worth I canāt reproduce this issue on 0.81.6, though Iām running home assistant via docker on my NAS, not hass.io on an rPi.
I donāt know when this occurred. Somewhere between 0.7x and 0.81.6. My server crashed so I moved over from hassbian (in docker) to hass.ioon a pi3. Most of the automation was ditched and started over. So I am sorry I donāt have a better answer.
No problem. Might be worth raising an issue on github, this seems like more of a hassio problem than an issue with the logi circle integration (even with bad inputs, ffmpeg shouldnāt seg fault). But if you uncover anything that points to the integration being at fault please let me know.
I would like to ask if Logi Circle component supports two accounts being set up?
I have two accounts with different cameras. I can only set up one account on Home Assistant right now.
It supports only one account Iām afraid. For what itās worth I think the same constraint exists for most other integrations of this type, eg. nest, ring, etc.
Firstly, thanks for getting the Logi Circleās working with HA, I have two Circle 2ās and the HA component is great. I just wondered (and Iām only being impatient :P) if youād had any luck in getting motion detection to work with the new API?
Iād love to use mine in a couple of automations so would be great if you managed to get it working. If you do manage to get anywhere and want anything testing on the Circle 2ās Iād be more than happy to help.
I have, and it worked well in my limited testing. I also have live streams working from within the camera preview.
Unfortunately I canāt release anything until Logitech make their API available publicly. I asked when that might be but didnāt get a firm answer (āhopefully soonā). As soon as itās released Iāll get something out for you all to play with.
Yeah, Iām a harmony user too and was surprised to wake up a few days ago with all my integrations broken.
No impact as far as I know. Iām guessing Harmony and Circle teams operate independently and are run very differently, Circle has been nothing but supportive with me in getting the HASS integration on an officially supported API (good documentation, test hardware, responsive with e-mails, etc). Of course no formal commitment is made so they could change their minds at any time, but Iām hopeful.
Logitech reached out and said Iām allowed to direct you all to a form to request API access before the official OAuth2 portal is released, so thereās no longer any blocker in releasing the updated version of the integration to you all.
Iāll try and get something out as soon as I can. I have very little spare time right now on a count of sick kids, upcoming Christmas holiday, etc so give me approx 3-4 weeks to test and tidy up what Iāve got implemented so far.
Iāve raised PRs for Home Assistant that updates the integration to use the public API and all the goodness that entails.
Unfortunately the updated component does not work in the custom_components folder (conflicts occur between the old logi circle implementation and the custom component), so youāll either need to build/run home assistant from my PR or wait until the update is merged + released.
You can see a preview of the updated documentation here, including the process for requesting API access (youāll want to do this BEFORE upgrading as it takes a few days for Logitech to issue API access).
Fantastic!
The url , for example, https://homeassistant.local, need to be the local url or could be the duckdns.org url?
Iām running hassos, do I need to upgrade the ffmpeg?
Doesnāt matter whether itās local or remote, so long as you can access it and it listens on HTTPS.
Never used it, but I assume HassOS still runs the hass docker container. If so, yes. But you can upgrade ffmpeg without messing with the container, Iāve included instructions for that here.
