I’ve uninstalled, deleted the config/node-red and config/.storage folders completely, restarted hassio, reinstalled Node-Red addon, but I keep getting Login Failed.
This is what I get from log after trying to login three times:
Welcome to Node-RED
17 Jan 09:22:11 - [info] Node-RED version: v0.19.5
17 Jan 09:22:11 - [info] Node.js version: v8.14.0
17 Jan 09:22:11 - [info] Linux 4.14.81-v7 arm LE
17 Jan 09:22:12 - [info] Loading palette nodes
17 Jan 09:22:22 - [info] Settings file : /etc/node-red/config.js
17 Jan 09:22:22 - [info] Context store : 'default' [module=memory]
17 Jan 09:22:22 - [info] User directory : /config/node-red/
17 Jan 09:22:22 - [warn] Projects disabled : editorTheme.projects.enabled=false
17 Jan 09:22:22 - [info] Flows file : /config/node-red/flows.json
17 Jan 09:22:22 - [info] Starting flows
17 Jan 09:22:22 - [info] Started flows
17 Jan 09:22:22 - [info] Server now running at http://127.0.0.1:1880/
17 Jan 09:22:23 - [info] [server:Home Assistant] WebSocket Connected to http://hassio/homeassistant
17 Jan 09:22:42 - HA Auth - Failed to authenticate: vittorio
17 Jan 09:23:12 - HA Auth - Failed to authenticate: vittorio
17 Jan 09:23:24 - HA Auth - Failed to authenticate: vittorio
Any suggestion?
PS:
Solved
Now I have to use the Hassio credentials rather than the one defined in the Addon config.
It’s confusing the fact that there are still user/pass definition that is not going to be used…
This problem hit me today (I’m new to Node Red) and all I had to do was change my HA password and avoid any special characters that would get URL-encoded.
If any of the topmost posters in this thread can confirm that her problem also stems from this issue, it would really help others if you would edit your posting and place a hint. So others will read the solution early in this thread, before they start a deletion and reinstallation odyssey.
In Node Red at the top of the right side panel there are different icons: Info, Debug, Bargraph,… The bargraph icon is for the dashboards. Click it. In the row below you will find will a second set of tabs. Just right to this set there is a kind of expand icon. THIS will open the dashboards for you.
