I recently installed logitec media server v8.2.0 and squeezelite on my rasp pi 4b
If a song is being played from a playlist and a tts message is played out, the song is not resumed after the tts rather a random track is played from the Playlist(Random is turned on for the playlist).
Really like this plugin. Since I have last.fm don’t stop the music running on various LMS players I get a bit of a weird situation when the music is not active and an announcement is made (e.g. doorbell). Basically what happens, the playlist Doorbell is triggered but immediately additional songs are added to this playlist. Luckily this is cut after 5-10 seconds but I rather only have the doorbell. Is there a way this can be done? Add an empty sound to the doorbell playlist? Open to all options
I don’t know if it helps but you can turn on/off DSTM (Don’t stop the music = logitech media player plugin) with the squeezebox.call_query. Here’s an example:
So if you turn off DSTM before the anouncement en turn it on after. So you can prevent that a previous saved playlist will begin playing again. However i never use this after installing the LMS TTS Notify intergration by floris-b.
Super Cadster, this is indeed what I need to do. Turning it off works, but turning it back on doesn’t. Do you know what other parameter options I can give? Turning it on now results into below (i.e. nothing gets selected). I would like to use the LastMix - based on last.fm. Thanks!
Good that you found it! For others, these are the options:
PLUGIN_LASTMIX_DSTM_MYMUSIC_ONLY - LastMix ("My Music" only)
PLUGIN_LASTMIX_DSTM_ITEM - LastMix - Don't Stop The Music support using Last.fm.
PLUGIN_LASTMIX_DSTM_YOUR_FAVORITE_ARTISTS - LastMix - Your Favorite Artists
I made some changed to the integration so Don’t Stop The Music is turned off and on automatic
Made some other changes but did not do a lot of testing, squeezebox join and unjoin is replaced by media_player join and unjoin in the future
Maybe I publish as is because don’t have a lot of time at the moment
Perhaps you can send your notification to a defined group of mediaplayers. There’s a lms plugin for that wich you can find in the slimdevices-forum. And here a solution wich is a bit different but can be an inspiration.
Just wanted to thank @floris-b (and everyone). Setting the playlist location in LMS is what got this working for me. (which is actually in the readme!)
Is there any change to get the resume working with the Bookmark plugin? Or another way to resume the position of the currently playing track instead of playing from the beginning? Especially when playing a podcast or audiobook, starting at the beginning is better than an empty playlist, but not quite seamless.
Thanks floris. I’m assuming that does include media from network mounted (nfs) drives?
I’m using the group players plugin and I’ve set my ‘media_player’ to a group player created with this plugin. Would this potentially have anything to do with not resuming the position? It resumes the correct track. Narrowed it down to these two, will test the group player one myself and report back.
One more question: when playing music the TTS service notification works perfectly and the music continues where after the playlist is done. But with a playlist loaded that is on pause it doesn’t. In this scenario the TTS playlist is played once and remains as default playlist. Is there a way to also get this returned to the playlist that was previously loaded?
