Thanks Bert. I will try it out tonight.
I think it works! Thanks Bert
Hi
Iām trying to collect multiline log statements.
My pattern would be:
^(\x1B?\[([0-9]{1,2}(;[0-9]{1,2})?)?[m|K])(\d{4}-\d{2}-\d{2} \d{2}:\d{2}:\d{2})
The above pattern detects the shell color-prefix that is added by the default containers. Iāve verified the regex with some log lines shown in the System/Log section on regex101.com - there the pattern is highlighted.
However, HA breaks the regex pattern into 2 lines after saving the addon configuration. My doubt is now that this is causing the pattern to break and not recognize the multilines anymore. My interpretation of it is that when the pattern is interpreted by Logspout during log parsing it āre-assemblesā the pattern into one line (removing the new line shown below) but then omits the whitespace between the day and the hour ā\d{2} \d{2}ā - hence the pattern doesnāt work anymore.
As a consequence, in Graylog all the lines that should be part of an error stacktrace are logged as single events.
Has anyone experienced something similar? Any suggestions how to fix this / prevent the line break? (Iāve tried replacing āvalue: >-ā with just āvalue:ā but then apparently HA is not happy with the config.
The problem may indeed be that ā>-ā will replace a linebreak with a space. You can see this for example by using an online yaml to json converter.
Did you try do āEdit as YAML?ā Maybe HA will preserve the format you type there, although it might break whenever you use the GUI editor again. I think the GUI editor is a bit broken and only works well for simple configuration options.
I must add however that multiline logging in Logspout is quite limited even when you do get the configuration right in HA. It might work well in a more homogeneous environment with containers logging in similar format. But HA add-ons typically log in very different formats. Creating a multiline pattern for some of them without breaking the output of others may be challenging at least.
I did intend to add a feature to configure multiline logging per container. But that would require a custom configuration file (to avoid problems like you have with the configurator) and some changes to the internals of Logspout. And when I thought about this I immediately thought of some other features that would be nice. But then I would end up with a lot of customization, which in turn would require documentation and maintenance. So at least for now I decided to not go there, itās probably better for most users to have a simple well-maintained add-on than a complex one which in the end could become unmaintained simply because it grew too big.
Thanks for the response.
Yes, I tried to edit it in the YAML view. However, then the editor wonāt let me save. I think it does some validation in the background probably.
I understand that you would like to keep the addon in a simple way.
Would you have a suggestion/workaround how one could handle multiline logs (e.g., exception stacktraces).
In a āregularā Docker environment it would be possible to send the container logs directly to Graylog with some syslog driver (and probably deal with multiline-issues directly - although Iāve never done that). However, in the somewhat āprotectedā environment of Home Assistant Operating System this is probably not possible(? )
For me it does save, I wonder if there is something wrong with your yaml then. This config does save at least for me (HA version 2023.11.3):
routes:
- gelf://graylog.home:12201
env:
- name: MULTILINE_PATTERN
value: ^(\x1B?\[[([0-9]{1,2}(;[0-9]{1,2})?)?[m|K])(\d{4}-\d{2}\d{2}:\d{2}:\d{2})
hostname: ha
As far as I know HA only validates for valid yaml and against this schema.
On the Home Assistant Operating System you are limited Iām afraid. I know the Promptail addon can be used, but Promptail unfortunately only targets Loki. Graylog can also not combine the logs on its end, so I currently donāt know about any other solutions or workarounds.
Thatās odd - when I tried to save it again today, this time it worked. However, the editor applied some auto-formatting afterwards and it is broken again (showing a newline where there should be none).
This input:
routes:
- gelf://graylog.local.domain.com:12201
env:
- name: SYSLOG_HOSTNAME
value: homeassistant
- name: INACTIVITY_TIMEOUT
value: 1m
- name: EXCLUDE_LABELS
value: io.hass.name:Logspout addon,
- name: MULTILINE_MATCH
value: first
value: ^(\x1B?\[([0-9]{1,2}(;[0-9]{1,2})?)?[m|K])(\d{4}-\d{2}-\d{2} \d{2}:\d{2}:\d{2})
- name: DEBUG
value: "true"
Resulted again in this:
I happen to notice that there is a space in your pattern between the date and time. So this line break should actually leave the value intact (it will be converted back to a space). You can verify this in the log output of the logspout add-on.
So I guess itās the pattern itself that doesnāt match. It may have to do with the color code, Iām not sure if it can be matched like this in Logspout. But I would need to debug to be sure.
You are right - there was an error in the pattern. I was testing it with regex101.com but I seem to have missed something. Now the regex tester is showing all the results as desired.
However, the multiline logs are still not arriving properly in Graylog. My suspicion is now that Logspout and I are not using the same regex flavor which would render my tests incorrect. Would you happen to know which regex variation Logspout is using? I was not able to find it out (I understand it is written in Go, I think? but not an expert in that).
On regex101 I was using the Python flavor as Iāve read that many things in HA are written in Python.
I had some time to debug today. I think itās going wrong already in the translation from the configuration yaml to environment variables, which is done by shell scripting and gives problems with escapes. This is also vissible in the log output from the addon, where the logged pattern string differs from the actual pattern string. I didnāt manage to find a way around this so Iām afraid configuring patterns with escape characters is not possible this way due to all the conversioning happening before the value even arrives at Logspout.
A custom multiline adapter reading the config from yaml directly (and configurable per container) would be nice, I will reconsider adding this feature.
Thanks a lot for the investigation! Much appreciated!
Iāll patiently await this feature in that case
Anyone knows how to force INCLUDE an addon? I am trying exclude all addons by using āio.hass.typeā in the EXCLUDE_LABELS, but there doesnāt seem to be a way to supersede this to include a specific addon.
e.g. Exclude all addons except ESPHome.
If you didnāt manage to get this working with a combination of EXCLUDE_LABELS
and a filter parameter (?filter.name=*_db
) then probably this is not supported. Not sure how important this is for you, on most log servers you can also perform filtering on the server side, but this will use unnecessary bandwidth of course.
Note that you can specify the same route url multiple times with different filter options. But this may still not be enough for you to achieve what you want.
Hi!
Is anybody currently using this addon actively with Grafana Cloud? I am trying to set it up but something is going wrong silently.
I did enable debug logging through the envvar and it does show errors 401 or 404 if I misconfigure my Loki URL on purpose. So it looks like the actual URL does work and is accepted by Loki.
Nevertheless Grafana still shows me 0 Bytes of logsā¦
Anybody using Grafana Cloud with success rigth now? I might now see the obviousā¦
The logs of the addon show this periodically, but I am not sure this is indicating an error condition.
2024/04/27 09:12:52 pump.Run() event: d06b88c180ac exec_create: /bin/sh -c curl --fail http://127.0.0.1:1337/healthz || exit 1
2024/04/27 09:12:53 pump.Run() event: d06b88c180ac exec_die
2024/04/27 09:12:54 pump.Run() event: 5d3dd10da205 exec_create: /bin/sh -c curl --fail http://127.0.0.1:1337/api/health || exit 1
2024/04/27 09:12:54 pump.Run() event: 5d3dd10da205 exec_die
2024/04/27 09:13:18 pump.pumpLogs(): cf9a97f46524 stopped with error: inactivity time exceeded timeout
2024/04/27 09:13:18 pump.pumpLogs(): cf9a97f46524 started, tail: all
2024/04/27 09:13:18 pump.pumpLogs(): 8cc79fcdf321 stopped with error: inactivity time exceeded timeout
