Hey guys, I have a couple of puls buttons throughout my house and want to add an extra layer to them.
Im activating scenes when the button inputs switch from off to on.
But now I want to add a second automation to them, when pressed longer than 1 second.
This works, but there’s an unwanted side effect.
Lets say input 1 short pressed activates scene 1.
And long press activates scene 2
now when another scene is activated (e.g. scene 3) and I long press it will first activate scene 1 and then 2.
I tried adding a wait timer before activating, but that just overrules the long press as the short press scene gets activated after the await time expires.
short press automation:
alias: Puls 1 kort
description: ""
- platform: state
entity_id:
- binary_sensor.pulslinks1
to: "on"
condition: []
- service: scene.turn_on
entity_id: scene.verlichting
metadata: {}
long press automation:
alias: Puls 1 Lang
description: ""
- platform: state
entity_id:
to: "on"
for:
hours: 0
minutes: 0
seconds: 1
condition: []
entity_id: scene.verlichting_uit
metadata: {}
I don’t think you can solve that.
I’m just thinking out loud now. Perhaps using a history stats sensor?
It will probably cause a delay from pressing to action but that could give something perhaps.
Or click and double click using a history stats count sensor? But that will also cause a delay
Perhaps that is possible.
Trigger on state off then.
If you add a history stats sensor with the time “on” the past two seconds.
As action, add a choose with history stats > 1 or < 1 as condition.
Yes, this is the solution.
Is it possible to add a maximum time to this, so it executes after 1,5/2 seconds?
Now when you long press, you can, e.g., long press indefinitely.
I think it would “feel” better when you see the scene change while pressing the button. That way you know you’ve pressed long enough.
It took me awhile, because I was thinking way too difficult. I was also trying to activate the long press buttons with an alteration of your code.
I did not understand your last post correctly…
What I did now, obviously, is use your code for the short press (less then 1 sec and on to off)
and for the long press just simply, activate when pressed, from off to on for 1 second.)
Hey jba, could you please share your working code. I try to solve the same problem (long and short press). A working example would be finde. Thank you.
Sorry, been awhile, but I hope its still helpfull:
Example yaml automation for short press, this automation executes a scene when the button is pushed and released within 1 second.
Since the trigger is a binary_sensor it’s state can be only „on“ or „off“. That’s why I think it is not needed to use the „from:“ part here.
In addition I would believe it could be only one automation triggered by „to: off“ and then using the „choose“ action to decide how long the press was. This would also give the option to have not only short and long presses but also very long presses and very, very long and so on.
Been using it for more than a year now, never had any problems or the need to expand on it.
But I think your right, the “from” isn’t necessarily needed.
