How do you do that?
@alexbeatle - great piece of work. One question from a newbie, how do I work out what the needs to be
How does what need to be?
Ignore me - iām an idiot.
The above has been very very useful - thank you!
So one problem I am having with this is that it doesnāt auto-update unless I press the refresh button. Is there any way to set this to do so? Also does any one have the white Tesla Y model template they could post/send?
You can change the refresh rate in the Tesla Integration. I believe itās every 6mins by default.
Thank you to alexbeatle for sharing!
I have decided to make some of my own changes including making the card more minimalist (although not completely). The original is great, but in case anyone is interested in a different look with very similar functionality, here is my take: RampantRedsFan/TeslaHADashboardElement: A somewhat minimal and interactive Tesla Home Assistant/Lovelace Dashboard Element (github.com)
Thanks for sharing this Alex.
I have a question regarding this, I see that temperature are shown in Fahrenheit, how can change it to celsius? just found out that I can change in Developer Tools->Statistics->Device
Nice one! Iām going to look in to this one. What I am missing at first glance is the ability to turn on the heated seats (especialy in the rear).
Hi, Iām having the same issue (total novice!), did you manage to sort it? Is it something to do with the image?
Total newbie guys and trying to build my dashboard. Tried the YAML code but havenāt had much luck with the image. Can you tell me where I am going wrong?
And have this error message at the bottom of the card. Looks like it is refusing to load the image file.
@alexbeatle great work mate. Need your help here. I have managed to clean up the error at the bottom (donāt understand why it doesnāt work) but I am still having difficulty getting the TESLA image as a background for this card.
Can you help? Latest look ā¦
Hi Osden, on this one you need to install a custopm bar : GitHub - custom-cards/bar-card: Customizable Animated Bar card for Home Assistant Lovelace
Then check how you did your card, here itās showing you he canāt find your backgroung image !
Have you set the right name ? and have you uploaded the image localy on your HA install ? (like image: /local/tesla_y.jpeg)
@bsteven
Thank you for your help. Works beautifully ā¦
Just FYI. If you have a relatively older vehicle, there seem to be an issue with api updates Tesla did. My data doesnāt āforce updateā.
The workaround I do is use the refresh button to turn the āpollingā switch off, and let automation turn it back on after 5 seconds.
Also, if youāre using browser_mod (GitHub - thomasloven/hass-browser_mod: š¹ A Home Assistant integration to turn your browser into a controllable entity and media player), you can refresh button get triggered when you open the page with your tesla car.
