Sure thing! Although, about half of the entities from my screenshot above come from “boilerplate yaml” that is included with every ESPHome device (highly recommended). You’ll see the line device_base: !include common/device_base_esp8266.yaml
which points at more files to build up the boilerplate. I’ve included all the important files at the bottom. I’m not including my wifi.yaml
because it has some customizations in it but it’s only the wifi:
block.
This build is using:
Here’s the big one: raygarage.yaml
substitutions:
node_name: raygarage
friendly_name: Ray's Garage
board: d1_mini
restore_from_flash: 'False'
log_level: NONE
library_priority: '0'
garage_priority: '1'
packages:
wifi: !include common/wifi.yaml
i2c:
scl: D2
sda: D4
scan: True
ads1115:
- address: 0x48
globals:
- id: performing_last_movement
type: boolean
restore_value: no
initial_value: 'false'
- platform: ultrasonic
update_interval: 5s
timeout: 4.0m
trigger_pin: D0
echo_pin: D7
name: Ray's Bay Distance
filters:
- median:
window_size: 5
send_every: 5
send_first_at: 3
# Use D3 for DHT22 and I don't need an external pull-up
- platform: dht
update_interval: 5s
pin: D3
model: AM2302
temperature:
name: "Garage Temperature"
filters:
- lambda: return x * (9.0/5.0) + 32.0;
- median:
window_size: 31
send_every: 6
send_first_at: 2
unit_of_measurement: "°F"
humidity:
name: "Garage Humidity"
filters:
- median:
window_size: 31
send_every: 6
send_first_at: 2
- platform: ads1115
update_interval: 6s
multiplexer: 'A0_GND'
gain: 6.144
name: "Garage Illuminance"
icon: mdi:candle
# Added device_class to customize icon.
device_class: ""
accuracy_decimals: 0
filters:
- lambda: return (x / 10000.0) * 2000000.0;
- median:
window_size: 15
send_every: 10
send_first_at: 3
unit_of_measurement: 'lx'
- platform: ads1115
update_interval: 6s
multiplexer: 'A1_GND'
gain: 6.144
name: "Garage CO Content"
icon: mdi:molecule-co
device_class: ""
accuracy_decimals: 2
unit_of_measurement: 'V'
filters:
- median:
window_size: 15
send_every: 10
send_first_at: 9
switch:
- platform: gpio
internal: true
pin:
number: D1
mode: OUTPUT
restore_mode: ALWAYS_OFF
on_turn_on:
- delay: 1500ms
- switch.turn_off: ray_button
cover:
name: Ray's Garage Door
device_class: garage
lambda: |-
if (id(closed_endstop).state) //Door at closed endstop
if (id(ray_s_garage_door).current_operation == esphome::cover::COVER_OPERATION_OPENING) //We should be opening
if (!id(performing_last_movement)) //Make sure we don't trigger this logic twice otherwise it will do unwanted things
delay(1000); //Wait for door to stop in case reed is triggered too early
id(ray_button).turn_on(); //Press button again
id(performing_last_movement) = true; //Set flag to indicate we madeknow where the door is
else if (id(ray_s_garage_door).current_operation == esphome::cover::COVER_OPERATION_CLOSING)
//We should be closing, so all is good
id(performing_last_movement) = false;
id(ray_s_garage_door).current_operation = esphome::cover::COVER_OPERATION_IDLE;
id(ray_s_garage_door).position = COVER_CLOSED;
id(ray_s_garage_door).publish_state();
return COVER_CLOSED;
else
//No operation in progress, just send state
if (!id(ray_s_garage_door).position == esphome::cover::COVER_CLOSED)
else if (id(open_endstop).state) //Door at open endstop
if (id(ray_s_garage_door).current_operation == esphome::cover::COVER_OPERATION_CLOSING) //We should be closing
else if (id(ray_s_garage_door).current_operation == esphome::cover::COVER_OPERATION_OPENING)
//We should be opening, so all is good
id(ray_s_garage_door).position = COVER_OPEN;
return COVER_OPEN;
else //Door not at any endstop
if (id(ray_s_garage_door).position != esphome::cover::COVER_OPEN)
return COVER_OPEN;
else
//The door is halfway open, so set it to OPEN
return COVER_OPEN;
return {};
open_action:
- lambda: |-
id(ray_s_garage_door).current_operation = esphome::cover::COVER_OPERATION_OPENING;
if (!id(open_endstop).state) {
if (id(closed_endstop).state) {
id(performing_last_movement) = true; //Set flag to indicate we know where the door is
close_action:
- lambda: |-
id(ray_s_garage_door).current_operation = esphome::cover::COVER_OPERATION_CLOSING;
if (!id(closed_endstop).state) {
if (id(open_endstop).state) {
stop_action:
- lambda: |-
if (id(ray_s_garage_door).current_operation == esphome::cover::COVER_OPERATION_CLOSING || id(ray_s_garage_door).current_operation == esphome::cover::COVER_OPERATION_OPENING )
//Stop the door if it is moving
binary_sensor:
name: Ray's Car Presence
lambda: |-
if (id(ray_s_bay_distance).state < 1.3) {
return true;
} else {
return false;
# D5 will need an external pull down, and reed switch goes to 3.3V
- platform: gpio
pin: D5
device_class: opening
internal: True
filters:
- delayed_on_off: 500ms
# D6 will need an external pull down, and reed switch goes to 3.3V
- platform: gpio
pin: D6
internal: True
filters:
Here are the boilerplate files.
esphome:
platform: ESP8266
board: ${board}
esp8266_restore_from_flash: ${restore_from_flash}
build_path: ./build/${node_name}
captive_portal:
logger:
level: ${log_level}
api:
password: ${api_password}
ota:
password: ${ota_password}
<<: !include common.button.yaml
<<: !include common.binary_sensor.yaml
<<: !include common.sensor.yaml
<<: !include common.text_sensor.yaml
common/common.button.yaml
button:
- platform: restart
name: ${friendly_name} Reset WiFi
on_press:
then:
- lambda: |-
WiFi.disconnect();
WiFi.begin();
common/common.binary_sensor.yaml
binary_sensor:
- platform: status
common/common.sensor.yaml
- platform: uptime
name: ${friendly_name} Uptime Raw
internal: true
update_interval: 30s
- platform: wifi_signal
name: ${friendly_name} WiFi Signal Strength
update_interval: 600s
common/common.text_sensor.yaml
text_sensor:
- platform: version
name: ${friendly_name} ESPHome Version
hide_timestamp: True
- platform: wifi_info
ip_address:
name: ${friendly_name} IP Address
icon: mdi:ip
ssid:
icon: mdi:access-point-network
mac_address:
icon: mdi:folder-key-network
lambda: |-
int seconds = (id(${node_name}_uptime_raw).state);
int days = seconds / (24 * 3600);
seconds = seconds % (24 * 3600);
int hours = seconds / 3600;
seconds = seconds % 3600;
int minutes = seconds / 60;
seconds = seconds % 60;
if ( days > 3650 ) {
return { "Starting up" };
} else if ( days ) {
return { (String(days) +"d " + String(hours) +"h " + String(minutes) +"m "+ String(seconds) +"s").c_str() };
} else if ( hours ) {
return { (String(hours) +"h " + String(minutes) +"m "+ String(seconds) +"s").c_str() };
} else if ( minutes ) {
return { (String(minutes) +"m "+ String(seconds) +"s").c_str() };
} else {
return { (String(seconds) +"s").c_str() };
icon: mdi:clock-start
BTW, my other garage door openers both include PIR motion sensors. That’s why this one doesn’t have them, it was intentionally designed this way because of my garage shape. If you only have one garage door opener DEFINITELY include a PIR sensor so you can see if something moves in the garage. Having that detection and reporting in HA is VERY nice.
Good luck!
