Looking for examples of "custom cover" from ESPHome.io
Sure thing! Although, about half of the entities from my screenshot above come from “boilerplate yaml” that is included with every ESPHome device (highly recommended). You’ll see the line device_base: !include common/device_base_esp8266.yaml which points at more files to build up the boilerplate. I’ve included all the important files at the bottom. I’m not including my wifi.yaml because it has some customizations in it but it’s only the wifi: block.
This build is using:
Here’s the big one: raygarage.yaml
substitutions:
  node_name: raygarage
  friendly_name: Ray's Garage
  board: d1_mini
  restore_from_flash: 'False'
  log_level: NONE
  library_priority: '0'
  garage_priority: '1'
packages:
  wifi: !include common/wifi.yaml
i2c:
  scl: D2
  sda: D4
  scan: True
ads1115:
  - address: 0x48
globals:
  - id: performing_last_movement
    type: boolean
    restore_value: no
    initial_value: 'false'
  - platform: ultrasonic
    update_interval: 5s
    timeout: 4.0m
    trigger_pin: D0
    echo_pin: D7
    name: Ray's Bay Distance
    filters:
      - median:
          window_size: 5
          send_every: 5
          send_first_at: 3
  # Use D3 for DHT22 and I don't need an external pull-up
  - platform: dht
    update_interval: 5s
    pin: D3
    model: AM2302
    temperature:
      name: "Garage Temperature"
      filters:
        - lambda: return x * (9.0/5.0) + 32.0;
        - median:
            window_size: 31
            send_every: 6
            send_first_at: 2
      unit_of_measurement: "°F"
    humidity:
      name: "Garage Humidity"
      filters:
        - median:
            window_size: 31
            send_every: 6
            send_first_at: 2
  - platform: ads1115
    update_interval: 6s
    multiplexer: 'A0_GND'
    gain: 6.144
    name: "Garage Illuminance"
    icon: mdi:candle
    # Added device_class to customize icon.
    device_class: ""
    accuracy_decimals: 0
    filters:
      - lambda: return (x / 10000.0) * 2000000.0;
      - median:
          window_size: 15
          send_every: 10
          send_first_at: 3
    unit_of_measurement: 'lx'
  - platform: ads1115
    update_interval: 6s
    multiplexer: 'A1_GND'
    gain: 6.144
    name: "Garage CO Content"
    icon: mdi:molecule-co
    device_class: ""
    accuracy_decimals: 2
    unit_of_measurement: 'V'
    filters:
      - median:
          window_size: 15
          send_every: 10
          send_first_at: 9
switch:
  - platform: gpio
    internal: true
    pin:
      number: D1
      mode: OUTPUT
    restore_mode: ALWAYS_OFF
    on_turn_on:
      - delay: 1500ms
      - switch.turn_off: ray_button
cover:
    name: Ray's Garage Door
    device_class: garage
    lambda: |-
      if (id(closed_endstop).state) //Door at closed endstop
        if (id(ray_s_garage_door).current_operation ==  esphome::cover::COVER_OPERATION_OPENING) //We should be opening
          if (!id(performing_last_movement)) //Make sure we don't trigger this logic twice otherwise it will do unwanted things
            delay(1000); //Wait for door to stop in case reed is triggered too early
            id(ray_button).turn_on(); //Press button again
            id(performing_last_movement) = true; //Set flag to indicate we madeknow where the door is
        else if (id(ray_s_garage_door).current_operation ==  esphome::cover::COVER_OPERATION_CLOSING)
          //We should be closing, so all is good
          id(performing_last_movement) = false;
          id(ray_s_garage_door).current_operation =  esphome::cover::COVER_OPERATION_IDLE;
          id(ray_s_garage_door).position = COVER_CLOSED;
          id(ray_s_garage_door).publish_state();
          return COVER_CLOSED;
        else
          //No operation in progress, just send state
          if (!id(ray_s_garage_door).position == esphome::cover::COVER_CLOSED)
      else if (id(open_endstop).state) //Door at open endstop
        if (id(ray_s_garage_door).current_operation ==  esphome::cover::COVER_OPERATION_CLOSING) //We should be closing
        else if (id(ray_s_garage_door).current_operation ==  esphome::cover::COVER_OPERATION_OPENING)
          //We should be opening, so all is good
          id(ray_s_garage_door).position = COVER_OPEN;
          return COVER_OPEN;
        else //Door not at any endstop
          if (id(ray_s_garage_door).position != esphome::cover::COVER_OPEN)
            return COVER_OPEN;
      else
        //The door is halfway open, so set it to OPEN
            return COVER_OPEN;
      return {};
    open_action:
      - lambda: |-
          id(ray_s_garage_door).current_operation =  esphome::cover::COVER_OPERATION_OPENING;
          if (!id(open_endstop).state) {
            if (id(closed_endstop).state) {
              id(performing_last_movement) = true; //Set flag to indicate we know where the door is
    close_action:
      - lambda: |-
          id(ray_s_garage_door).current_operation =  esphome::cover::COVER_OPERATION_CLOSING;
          if (!id(closed_endstop).state) {
            if (id(open_endstop).state) {
    stop_action:
      - lambda: |-
          if (id(ray_s_garage_door).current_operation ==  esphome::cover::COVER_OPERATION_CLOSING || id(ray_s_garage_door).current_operation ==  esphome::cover::COVER_OPERATION_OPENING )
            //Stop the door if it is moving
binary_sensor:
    name: Ray's Car Presence
    lambda: |-
      if (id(ray_s_bay_distance).state < 1.3) {
        return true;
      } else {
        return false;
    # D5 will need an external pull down, and reed switch goes to 3.3V
  - platform: gpio
    pin: D5
    device_class: opening
    internal: True
    filters:
      - delayed_on_off: 500ms
    # D6 will need an external pull down, and reed switch goes to 3.3V
  - platform: gpio
    pin: D6
    internal: True
    filters:
Here are the boilerplate files.
common/device_base_esp8266.yaml:
esphome:
  platform: ESP8266
  board: ${board}
  esp8266_restore_from_flash: ${restore_from_flash}
  build_path: ./build/${node_name}
captive_portal:
logger:
  level: ${log_level}
api:
  password: ${api_password}
ota:
  password: ${ota_password}
<<: !include common.button.yaml
<<: !include common.binary_sensor.yaml
<<: !include common.sensor.yaml
<<: !include common.text_sensor.yaml
common/common.button.yaml:
button:
  - platform: restart
    name: ${friendly_name} Reset WiFi
    on_press:
      then:
        - lambda: |-
            WiFi.disconnect();
            WiFi.begin();
common/common.binary_sensor.yaml:
binary_sensor:
  - platform: status
common/common.sensor.yaml:
  - platform: uptime
    name: ${friendly_name} Uptime Raw
    internal: true
    update_interval: 30s
  - platform: wifi_signal
    name: ${friendly_name} WiFi Signal Strength
    update_interval: 600s
common/common.text_sensor.yaml:
text_sensor:
  - platform: version
    name: ${friendly_name} ESPHome Version
    hide_timestamp: True
  - platform: wifi_info
    ip_address:
      name: ${friendly_name} IP Address
      icon: mdi:ip
    ssid:
      icon: mdi:access-point-network
    mac_address:
      icon: mdi:folder-key-network
    lambda: |-
      int seconds = (id(${node_name}_uptime_raw).state);
      int days = seconds / (24 * 3600);
      seconds = seconds % (24 * 3600);
      int hours = seconds / 3600;
      seconds = seconds % 3600;
      int minutes = seconds /  60;
      seconds = seconds % 60;
      if ( days > 3650 ) {
        return { "Starting up" };
      } else if ( days ) {
        return { (String(days) +"d " + String(hours) +"h " + String(minutes) +"m "+ String(seconds) +"s").c_str() };
      } else if ( hours ) {
        return { (String(hours) +"h " + String(minutes) +"m "+ String(seconds) +"s").c_str() };
      } else if ( minutes ) {
        return { (String(minutes) +"m "+ String(seconds) +"s").c_str() };
      } else {
        return { (String(seconds) +"s").c_str() };
    icon: mdi:clock-start
BTW, my other garage door openers both include PIR motion sensors. That’s why this one doesn’t have them, it was intentionally designed this way because of my garage shape. If you only have one garage door opener DEFINITELY include a PIR sensor so you can see if something moves in the garage. Having that detection and reporting in HA is VERY nice.
Good luck!
Ray - many thanks for this. A huge help for me :grinning:
