Loratap SC500W repurposed and flashed, doorbell door opener
I wanted a small device for the doorbell ring/door opener, this required two relays, and since I swapped the loratap for a SONOFF dual r3 in the past for the curtain switch (position control) I had this loratap laying around.
I cut traces, MANY OF THEM, and soldered cables, and found some code online.
Now its working,
Flashing wiring:
Source: LoraTap In-Wall Curtain Module (SC500W) Configuration for Tasmota
Also for the code Its based on another code I found online with some modifications to modify the pushed times of the buttons and to enable the door opener.
Source: https://www.zuidwijk.com/esphome-based-doorbell/
esphome:
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
  password: "xxxxxxx"
ota:
  password: "xxxxxxxx"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Telefonillo Fallback Hotspot"
captive_portal:
text_sensor:
    name: Uptime Human Readable
    icon: mdi:clock-start
  - platform: wifi_info
    ip_address:
    ssid:
    bssid:
  - platform: wifi_signal
    name: "WiFi Signal Sensor"
    update_interval: 60s
  - platform: uptime
    on_raw_value:
      then:
        - text_sensor.template.publish:
            state: !lambda |-
              int seconds = round(id(uptime_sensor).raw_state);
              int days = seconds / (24 * 3600);
              seconds = seconds % (24 * 3600);
              int hours = seconds / 3600;
              seconds = seconds % 3600;
              int minutes = seconds /  60;
              seconds = seconds % 60;
              return (
                (days ? to_string(days) + "d " : "") +
                (hours ? to_string(hours) + "h " : "") +
                (minutes ? to_string(minutes) + "m " : "") +
                (to_string(seconds) + "s")
              ).c_str();
status_led:
  pin:
    number: GPIO3
    inverted: false
globals:
  - id: chime
    type: bool
    restore_value: true
    initial_value: 'true'
switch:
  - platform: restart
  - platform: gpio
    pin: GPIO12
    icon: mdi:door-closed
    restore_mode: always_off
    on_turn_on:
    - delay: 2000ms
    - switch.turn_off: r1
  - platform: gpio
    pin: GPIO14
    icon: mdi:bell
    on_turn_on:
    - delay: 2000ms
    - switch.turn_off: r2
    name: "Telefonillo Timbre Activado"
    icon: mdi:alarm-bell
    restore_state: false
    turn_on_action:
      - globals.set:
          value: 'true'
    turn_off_action:
      - globals.set:
          value: 'false'
    lambda: |-
      return id(chime);
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO13
#Externall pullup fitted, un-coment if using a decent board with proper internall pullups.
#      mode: INPUT_PULLUP
      inverted: True
    icon: mdi:gesture-tap-button
    on_press:
      then:
        if:
          condition:
            - switch.is_on: chime_active
          then:
            - switch.turn_on: r2
            - delay: 2000ms
    filters:
      - delayed_on: 35ms
      - delayed_off: 3000ms
  - platform: status
    name: "Status Telefonillo"
Panel
Device
