I’ve opened https://github.com/home-assistant/home-assistant/pull/15942 which should make 0.76. Please let me know of any further problems after 0.76 is released.
Great. Thank you very much.
Hi there.
Just to let you know that upgrading to 0.76 fixed my issue. Once again, thank you.
Same here, all good on 0.76.2. Thank you very much.
Good afternoon. Can you tell me, please, was this problem eventually solved? How to apply the solution? After 2-5 minutes, the following appears in my HA logs: 2021-08-11 15:39:48 DEBUG (MainThread) [mysensors.gateway_tcp] Connection lost with <_SelectorSocketTransport closing fd=24 read=idle write=<idle, bufsize=0>>
After this message, the information from the mysensors sensors is not transmitted until the HA core is restarted.
I’m not sure, I switched to using a MQTT gateway
