My problem is that these entities disappear from the dropdownlist ‘Entities of this node’ in HA zwave config panel after restarting HA multiple times. I no longer have access to the sensor sensative_strips_access_control (and others) even if the entity entries are still in entitty_registry.yaml.
Sometimes I’m able to recover the entities by waking up the Sensative strip but most of the time I need to remove then readd the strip in HA. I’m using version 0.74.2.
I’ve never had that happen when restarting HA, and I’ve been using Sensative strips since January 2017, upgrading at pretty much every release, and often restarting multiple times between releases.
You do have non-battery powered Z-Wave devices and the mesh is healthy?
Yes I have a Fibaro Universal Sensor but I had the problem even before I added this sensor. Can I ask you how I can check if the mesh is healthy ?
If you’ve only a single powered device then you don’t have a mesh. It’s those powered devices that build a mesh, and having only (or almost only) battery powered devices is a problem.
After removing and readding the strip then restarting HA I have something different now. The entites are gone as always after restarting my HA but the strip is no longer attach to the controller.
You’ll just have to add it in a place that improves the connectivity. That may not be a straight line, but taking into account the construction of your house, and what reduces the signal (metal, water, chipboard, thick stone walls, etc).
Good Day everyone, from the previous conversation I do understand that there needs to be some powered devices in order to get the sensative strips to work. In my case it directly connects to the hub eventhough there are powered devices. Can I somehow force the route?
There’s nothing to help with. Your sensor is connected and presumably working. You need powered devices (relays) when other devices are beyond direct reach.
Now, you do have 3 failed devices… but that’s a different problem.
Well actually I added the device created a binary sensor and things were working for a bit. Now they are not and I thought it would have been related to the connection.
Did I misread this from the earlier posts?
Any Z-Wave device has a number of entities, zwave. for the Z-Wave part, and then others for different features. Do any of those update? Usually at the very least I’d expect to see the receivedTS attribute of the zwave. entity update.
Depends on your timezone and what’s going on, but it shows that it last talked with the controller at 20:32 (your time). You’ve got one failed send, but one is no big deal.
