Love the new Meteoalarm - how do I put the alert in a card?
HI,
there aren’t many template sensors really, the binary_sensor has attributes, and those are displayed using the code in the card using Markdown.
In my card, I use the sensor.weer_alarm, which is a template sensor:
      weer_alarm:
        friendly_name: Weeralarm
        value_template: >
          {% if is_state('binary_sensor.meteoalarm_brabant','on') %}
          {% set code = state_attr('binary_sensor.meteoalarm_brabant','awareness_level').split(';')[1] %}
          {{code|title}}
          {% else %} Green
          {% endif %}
        icon_template: >
          {% set code = state_attr('binary_sensor.meteoalarm_brabant','awareness_level').split(';')[0] %}
          {% else %} {% set code = '0' %}
          {% endif %}
          {{'mdi:numeric-' + code + '-box'}}
I customize both sensors using:
homeassistant:
  customize:
    sensor.weer_alarm:
      templates:
        icon_color: >
          return state;
    binary_sensor.meteoalarm_brabant:
      friendly_name: Meteoalarm Brabant
      templates:
        icon_color: >
          return entities['sensor.weer_alarm'].state;
the above customizations need custom-ui.
Thanks for showing me your config. I got something to do again. :+1:
I followed your indications and coded those templates regarding my needs and i get this:
45
Actually there is no alarm, but how to change the word ‘undefined’ in something else? And where is the related icon?
My template is:
  sensors:
    severita_meteo_abruzzo:
      friendly_name: Allarme Meteo Abruzzo
      value_template: >
        {% if is_state('binary_sensor.allarme_meteo_abruzzo','on') %}
        {% set param = state_attr('binary_sensor.allarme_meteo_abruzzo','severity') %}
          {% if param == 'Moderate' %} Yellow
          {% elif param == 'Severe' %} Orange
          {% elif param == 'Dangerous' %} Red
          {% else %} White
          {% endif %}
        {% else %} Grey
        {% endif %}
      icon_template: >
        {% set state = states('sensor.allarme_meteo_abruzzo') %}
        {% if state == 'Yellow' %} {% set code = '2' %}
        {% elif state == 'Orange' %} {% set code = '3' %}
        {% elif state == 'Red' %} {% set code = '4' %}
        {% endif %}
Hey Marius,
Are you still using this?
You mean this?
Yes exactly.
Can you posted the latest lovelace code?
I posted this a little while ago.
this is what I use:
type: conditional
conditions:
  - state: 'on'
    entity: binary_sensor.meteoalarm_brabant
card:
  type: custom:vertical-stack-in-card
  cards:
    - type: entities
      title: Weeralarm
      show_header_toggle: false
      theme: meteoalarm
      entities:
        - binary_sensor.meteoalarm_brabant
        - sensor.weer_alarm
      card:
        type: markdown
        content: >
          <font color= grey> {{state_attr('binary_sensor.meteoalarm_brabant','attribution')}} </font>
    - type: markdown
      content: >
        <font color= green> **Alarm code**</font>
        <font color= grey> - {{states('sensor.weer_alarm')}} </font>
        <font color= grey>  - Urgency: {{state_attr('binary_sensor.meteoalarm_brabant','urgency')}} </font>
        <font color= grey> - Level: {{state_attr('binary_sensor.meteoalarm_brabant','awareness_level')}} </font>
        <font color= grey> - Type: {{state_attr('binary_sensor.meteoalarm_brabant','awareness_type')}} </font>
        <font color= grey> - Severity: {{state_attr('binary_sensor.meteoalarm_brabant','severity')}} </font>
        <font color= grey> - Certainty: {{state_attr('binary_sensor.meteoalarm_brabant','certainty')}} </font>
        <font color= green> **Event**</font>
        <font color= grey> - {{state_attr('binary_sensor.meteoalarm_brabant','event')}} </font>
        <font color= green> **Headline**</font>
        <font color= grey> - {{state_attr('binary_sensor.meteoalarm_brabant','headline')}} </font>
        <font color= green> **Status**</font>
        <font color= grey> - {{state_attr('binary_sensor.meteoalarm_brabant','description')}} </font>
    - type: picture
      image: /local/weather/meteo_alarm/meteo_alarm_banner.jpg
      tap_action:
        action: url
        url_path: http://meteoalarm.eu/ne_NL/0/0/NL013-Noord-Brabant.html
and I use this button:
Schermafbeelding 2020-02-17 om 10.26.49
if an alert is on, displayed in my alert setup.
Will you share also this card button?
sure, here you go (please note the icon template is probably not perfect yet. This is because the possible states are somewhat different from the list on meteoalarm.eu. Since I havent seen all of them happen yet… I am not sure about all of them. If an icon doesn’t show, check the state of the sensor, and adapt accordingly)
Note2: I had a button with icons for the Type, Level and Sev at first, but took these out because I liked it better without icons. If you want these back in, simply swap the commented bit for the current setup
type: custom:button-card
template: button_body
entity: 'binary_sensor.meteoalarm_brabant'
aspect_ratio: 1/1
icon: >
  [[[ var icon = entity.attributes.headline.split(' ')[0];
      var weather = {'Fog':'fog',
                    'Wind':'windy',
                    'Snow-ice':'snowy-heavy',
                    'Thunderstorm':'lightning',
                    'Rain':'pouring',
                    'Rain-Flood':'home-flood'};
      var climate = {'Extreme high temperature':'thermometer-chevron-up',
                     'Extreme low temperature':'thermometer-chevron-down',
                     'Coastal Event':'waves',
                     'Forestfire':'camp-fire',
                     'Avalanches':'snowflake-alert',
                     'Rain-Flood':'home-flood',
                     'Flooding':'home-flood'};
      return weather[icon] ? 'mdi:weather-' + weather[icon] :
      climate[icon] ? 'mdi:' + climate[icon] :'mdi:alert';]]]
show_state: false
tap_action:
  action: more-info
hold_action:
  action: navigate
  navigation_path: weer_klimaat
styles:
  card:
    - padding: 5px
    - font-size: 10px
    - color: white
    - background: 'rgb(16,55,115)'
  grid:
    - grid-template-areas: '"i alert" "n n" "type type" "level level" "severity severity"'
    - grid-template-columns: 1fr 1fr
    - grid-template-rows: 1fr min-content min-content min-content min-content
  name:
    - align-self: middle
    - justify-self: start
    - padding-bottom: 4px
  img_cell:
    - margin: none
  icon:
    - color: >
        [[[ return entity.attributes.awareness_level.split(' ')[1].slice(0,-1) ]]]
    - width: 70%
    - margin-top: -5%
  custom_fields:
    alert:
      - padding: 5px
      - align-self: start
      - justify-self: end
      - --text-color-sensor: >
          [[[ var param = entity.attributes.severity;
             if (param == 'Safe') return 'green';
             if (param == 'Moderate') return 'yellow';
             if (param =='Severe') return 'orange';
             if (param == 'High') return 'red';
             return 'grey'; ]]]
    type:
#      - padding-bottom: 2px
    level:
      - text-transform: capitalize
    severity:
             return 'grey'; ]]]
custom_fields:
  alert: >
      return `<span>Alert:<span style='color: var(--text-color-sensor);'>${entity.attributes.awareness_level.split(';')[0]} </span></span>`
  type: >
      return `<span>Type: <span style='color: var(--text-color-sensor);'>${entity.attributes.awareness_type.split(';')[0]}: ${entity.attributes.headline.split(' ')[0]}</span></span>`
  level: >
      return `<span>Level: <span style='color: var(--text-color-sensor);'>${entity.attributes.awareness_level.split(' ')[1].slice(0,-1)}</span></span>`
  severity: >
      return `<span>Sev: <span style='color: var(--text-color-sensor);'>${entity.attributes.severity}</span></span>`
#  alert: >
#      return `<ha-icon
#        icon='mdi:alert'
#        style='width: 12px; height: 12px;'>
#        </ha-icon><span>Alert:<span style='color: var(--text-color-sensor);'>${entity.attributes.awareness_level.split(';')[0]} </span></span>`
#  type: >
#      return `<ha-icon
#        icon='mdi:comment-alert'
#        </ha-icon><span>Type: <span style='color: var(--text-color-sensor);'>${entity.attributes.awareness_type.split(';')[0]}: ${entity.attributes.headline.split(' ')[0]}</span></span>`
#  level: >
#      return `<ha-icon
#        icon=${'mdi:numeric-' + entity.attributes.awareness_level.split(';')[0] + '-box'}
#        </ha-icon><span>Level: <span style='color: var(--text-color-sensor);'>${entity.attributes.awareness_level.split(' ')[1].slice(0,-1)}</span></span>`
#  severity: >
#      return `<ha-icon
#        icon='mdi:alert'
#        </ha-icon><span>Sev: <span style='color: var(--text-color-sensor);'>${entity.attributes.severity}</span></span>`
#      - --color-name: >
#          [[[function capitalizeFirstLetter(string) {
#            return string.charAt(0).toUpperCase() + string.slice(1).toLowerCase();
#            var id = entity.attributes.awareness_level.split(' ')[1].slice(0,-1);
#            return capitalizeFirstLetter(id) ]]]
What is this sensor.weer_alarm I only have the one for meteoalarm?
well yes, I made that all myself, so you wouldn’t have it… :wink: It’s a template sensor to build the color and parameter coding for the button. Its built around the severity:
and deduced from the meteoalarm website clicking on the colored legenda
Hi Klogg. Have you managed to fix this problem and get Meteo working for London?
No I didn’t.
I use the Met Office now.
Is this integration still working?
I have tried East of Anglia - tried setting district to ‘East of Anglia’, ‘East-of-Anglia’, ‘East%20of%20Anglia’ and it never works.
