MY LORD IS THIS USEFUL. it is so quick and snappy. I love the custom actions as well. I feel like i don’t even need a frontend on ios anymore. Just this card!
Is it possible to hide disabled entities?
Is it possible to add a search that only searches within this page, such as the name of a search card
Just incredible ! Bravo !!
I wait the next relase (if you have some plan to update your fabulous idea.)
In my part i wait the possibility to exclude some entities / domaine…
Since the November update, the search card is displaying like this and is unselectable. Is there a fix for this?
Currently no, but I’ve noticed it as well. I don’t actively maintain the card (I’m no web dev by any means), but if someone comes up with a solution, I will merge it.
Well I’m at least glad to know it’s not just me
have the same issue and would be interested in a solution too. I played a bit around but without any success
It is fixed since a few days. I had to clear the fronted cache for it to work though (in the iOS app).
im still having the problem, im using android and a chrome on windows machine. I Cleaned the cache and it still not working… i’ll appreciated if any of you guys have a solution for this.
thank you
I’m looking for a way to implement a card in Home Assistant that functions like this search card. Ideally, I’d like it to filter and display results dynamically based on user input, but the results should be sourced only from:
- the options defined in an
input_selecthelper, - the state or payload of an MQTT sensor, or
- the attributes of a template sensor.
The goal is to have a text input where I can start typing, and it will suggest or display matching food recipes from one of these predefined data sources.
Is this in any way possible with this card? Or does another solution exist that I could look into?
Thank you in advance.
regarding HA or something else…?
Thank you for asking for clarification. July 1, 2025 is the official release date for my new Home Assistant Lovelace card. On that day, the card - with its rapid search, intelligent sorting, spatial design and full responsiveness - will become publicly available. It does not refer to any other product or event.
Nice!
Will it be possible to set an input select helper as the “data source” for searching results?
it will be something like this yes. but it could changed, i will not promise…
Unfortunately, I’m not quite satisfied with my code yet, and it will be a little while longer until I’m finished. Therefore, I ask for your patience.
