Yes, set showRelativeTime
to false
No i believe this is a bug since HA updated the Calendar API I have requested this be added back in:
This was a bug, should be fixed in the latest version, if you still have issues let me know along with a copy of your config
Hello there,
I have just discovered your post and wondering if you have found the solution already. I can cast the calendar to different types of Nest Hub and may be able to support you if it is still relevant.
Csaba
Sorry if this has been answered and I missed it - there’s a lot of great info here!
I have things working nicely, but I have one more calendar I cannot get into HA. Apple automatically generate my ‘Birthdays’ calendar based on people’s dates of birth in my Contacts. When I try to add this calendar to HA the same way I did my other ones, no calendar entity is created for it. Anyone done this or got any ideas how I go about it?
Many thanks
The events in Calendar View do not show an end time, i.e. 15:00 -
They show up in the Event View, just not Calendar.
Settings showMultiDay: 'false'
in either the entry or for each calendar entity doesn’t seem to remove multi day events from the agenda. Is there something more I need to do? Thanks!
ShowMultiDay doesn’t remove the events, it splits them up into individual events for each day with numbering.
Oh that’s good to know.
I’m running a dashboard on a spare phone number my monitor, and it’s only got enough space to display 5 events, so it would be great to not show all day events. Is there any way to do that?
Thanks!
Please post in English, thank you.
Unfortunately, English is mandatory here.
Use google translator just to help
Hello
Would it be possible to display the calendar name of each entity ? Prior to the event name or below… ?
I have tried showCalendarName but it seems not working…
Indeed, I have several calendars display in envent mode and I would distinguish easily each of them.
Thank you in advance for your help
I’m trying to remove the (border?)line that’s in between days in de event view. I’ve tried this code but that doesn’t work. Anyone who can help me? Thanks in advance.
type: custom:atomic-calendar-revive
enableModeChange: true
entities:
- entity: calendar.gft_afval
color: green
- entity: calendar.restafval
color: grey
- entity: calendar.papier
color: blue
- entity: calendar.onzeagenda
color: green
- entity: calendar.feestdagen_in_nederland
name: Feestdagen in nederland
color: purple
sortByStartTime: true
compactMode: false
showEventDate: true
showAllDayHours: false
maxEventCount: 7
maxDaysToShow: 30
showDate: true
showWeekDay: true
showRelativeTime: false
showMultiDayEventParts: true
hoursOnSameLine: false
showCurrentEventLine: false
showProgressBar: false
showDescription: false
card_mod:
style: |
ha-card {
border: none;
finally found this great card, thanks for an oustanding work! It works great, though is it possible to change the actual text for the word “Week” to my native language? I currently have:
showWeekNumber: true
and then I get that sexy box on top where it currently states “Week 31”. Now I would like to change that text to “Vecka 31” instead if that’s possible please?
Liking this so far (thanks!), but cannot get one of the main pieces of functionality I wanted to work:
Examples I would like to use:
Blocklist: I would like to block the phrases “activity club” AND “shift”
(this would ignore all events containing the phrase “activity club” or the word “shift” in their title)
BlockistLocation: I would like to block “123 my road my town”
Is this possible? From testing it seems like the blocklist only accepts a single word?
I looked in the documentation and it says this about the blocklist: “Simple case insensitive regex to ignore events that match title”
For the blocklist I it works for me like this:
entities:
- entity: calendar.gmail_termine
color: var(--state-icon-active-color)
max_results: 50
- entity: calendar.feiertage_in_deutschland
color: var(--primary-text-color)
blacklist: >-
Fronleichnam,Palmsonntag,Gründonnerstag,Weltkindertag,Reformationstag,Volkstrauertag,Totensonntag,Reformationstag,Buß-
und Bettag (regional)
firstDayOfWeek: 1
maxDaysToShow: 7
I haven’t testet placeholders so far
Hello
Anyone have a solution about my demand in order to display the agenda name ?
Do I need to create an enhancement on github?
Thx
You have different colors per calendar, so you can distinguish it by colors:
Is it possible to make the dates more compact and appear in one line only?
Confirming this format doesn’t work for me
