Lovelace: Alarm card
Absolutely this should be the default.
Oh I forgot to mention, I removed the label for the paper-input, the word “Code”, as it causes significant lag when used on a low-powered tablet. When you press the keypad buttons, the first button press will cause the word “Code” to shrink, and while animating it, it causes unresponsiveness, and most of the time, the 2nd, and even 3rd button press is not registered. If I press my code in quickly, only 2 or 3 digits is shown.
That’s weird. I still get the old interface when trying the new code. Did update the version and tried a full restart… must be missing something obvious!
@quovadis I replace the content of alarm_control_card-panel.js with your post. Changed the version number, cleared the cache… and nevertheless the numbers are still super tiny.
I am using the latest hass.io version (0.96.4).
Any idea what I could do wrongly?
Thanks,
GV
The issue is that you are typing the alarm code directly with your keyboard.
To get it working, you have to enter the code using the buttons in the panel.
Sorry guys, it was me who made a mistake, I think I posted the wrong version. I used <button> instead of <mwc-button>. My apologies. Please find the correct code below
class AlarmControlPanelCard extends HTMLElement {
  constructor() {
    super();
    this.attachShadow({ mode: 'open' });
    this._icons = {
      'armed_away': 'mdi:shield-lock',
      'armed_custom_bypass': 'mdi:security',
      'armed_home': 'mdi:shield-home',
      'armed_night': 'mdi:shield-home',
      'disarmed': 'mdi:shield-check',
      'pending': 'mdi:shield-outline',
      'triggered': 'hass:bell-ring',
  set hass(hass) {
    const entity = hass.states[this._config.entity];
    if (entity) {
      this.myhass = hass;
      if(!this.shadowRoot.lastChild) {
        this._createCard(entity);
      if (entity.state != this._state) {
        this._state = entity.state;
        this._updateCardContent(entity);
  _createCard(entity) {
    const config = this._config;
    const card = document.createElement('ha-card');
    card.innerHTML = `
      ${this._iconLabel()}
      ${config.title ? '<div id="state-text"></div>' : ''}
    const content = document.createElement('div');
    content.id = "content";
    content.style.display = config.auto_hide ? 'none' : '';
    //`<paper-input label='${this._label("ui.card.alarm_control_panel.code")}' type="password"></paper-input>` : ''}
    content.innerHTML = `
      ${this._actionButtons()}
      ${entity.attributes.code_format ?
          `<paper-input type="number"></paper-input>` : ''}
      ${this._keypad(entity)}
    card.appendChild(this._style(config.style, entity));
    card.appendChild(content);
    this.shadowRoot.appendChild(card);
    this._setupInput();
    this._setupKeypad();
    this._setupActions();
  connectedCallback() {
  setConfig(config) {
    if (!config.entity || config.entity.split(".")[0] !== "alarm_control_panel") {
      throw new Error('Please specify an entity from alarm_control_panel domain.');
    if (config.auto_enter) {
      if (!config.auto_enter.code_length || !config.auto_enter.arm_action) {
        throw new
          Error('Specify both code_length and arm_action when using auto_enter.');
      this._arm_action = config.auto_enter.arm_action;
    if (!config.states) config.states = ['arm_away', 'arm_home'];
    if (!config.scale) config.scale = '15px';
    this._config = Object.assign({}, config);
    const root = this.shadowRoot;
    if (root.lastChild) root.removeChild(root.lastChild);
  _updateCardContent(entity) {
    const card = root.lastChild;
    const state_str = "state.alarm_control_panel." + this._state;
    if (config.title) {
      card.header = config.title;
      root.getElementById("state-text").innerHTML = this._label(state_str);
      root.getElementById("state-text").className = `state ${this._state}`;
    } else {
      card.header = this._label(state_str);
    root.getElementById("state-icon").setAttribute("icon",
      this._icons[this._state] || 'mdi:shield-outline');
    root.getElementById("badge-icon").className = this._state;
    var iconText = this._stateIconLabel(this._state);
    if (iconText === "") {
      root.getElementById("icon-label").style.display = "none";
    } else {
      root.getElementById("icon-label").style.display = "";
      if (iconText.length > 5) {
        root.getElementById("icon-label").className = "label big";
      } else {
	root.getElementById("icon-label").className = "label";
      root.getElementById("icon-text").innerHTML = iconText;
    const armVisible = (this._state === 'disarmed');
    root.getElementById("arm-actions").style.display = armVisible ? "" : "none";
    root.getElementById("disarm-actions").style.display = armVisible ? "none" : "";
  _actionButtons() {
    return `
      <div id="arm-actions" class="actions">
        ${this._config.states.map(el => `${this._actionButton(el)}`).join('')}
      </div>
      <div id="disarm-actions" class="actions">
        ${this._actionButton('disarm')}
      </div>`;
  _stateIconLabel(state) {
    const stateLabel = state.split("_").pop();
    return stateLabel === "disarmed" ||
      stateLabel === "triggered" ||
      !stateLabel
      : stateLabel;
  _iconLabel() {
    return `
      <ha-label-badge-icon id="badge-icon">
        <div class="badge-container" id="badge-container">
          <div class="label-badge" id="badge">
            <div class="value">
              <ha-icon id="state-icon"/>
            </div>
            <div class="label" id="icon-label">
              <span id="icon-text"/>
            </div>
          </div>
        </div>
    </ha-label-badge-icon>`;
  _actionButton(state) {
    return `<mwc-button outlined id="${state}">
      ${this._label("ui.card.alarm_control_panel." + state)}</mwc-button>`;
  _setupActions() {
    const card = this.shadowRoot.lastChild;
    if (config.auto_hide) {
      root.getElementById("badge-icon").addEventListener('click', event => {
        var content = root.getElementById("content");
        if (content.style.display === 'none') {
          content.style.display = '';
        } else {
          content.style.display = 'none';
      card.querySelectorAll(".actions mwc-button").forEach(element => {
        element.classList.remove('autoarm');
        if (element.id === this._arm_action || element.id === 'disarm') {
          element.classList.add('autoarm');
        element.addEventListener('click', event => {
          if (element.id !== 'disarm') this._arm_action = element.id;
    } else {
          const input = card.querySelector('paper-input');
          const value = input ? input.value : '';
          this._callService(element.id, value);
  _callService(service, code) {
    const input = this.shadowRoot.lastChild.querySelector("paper-input");
    this.myhass.callService('alarm_control_panel', `alarm_${service}`, {
      entity_id: this._config.entity,
      code: code,
    if (input) input.value = '';
  _setupInput() {
    if (this._config.auto_enter) {
      input.addEventListener('input', event => { this._autoEnter() })
  _setupKeypad() {
    const input = root.lastChild.querySelector('paper-input');
    root.querySelectorAll(".pad button").forEach(element => {
      if (element.getAttribute('value') ===
        this._label("ui.card.alarm_control_panel.clear_code")) {
          input.value = '';
      } else {
          input.value += element.getAttribute('value');
          this._autoEnter();
  _autoEnter() {
      const code = card.querySelector("paper-input").value;
      if (code.length == config.auto_enter.code_length) {
        const service = card.querySelector(".actions .autoarm").id;
        this._callService(service, code);
  _keypad(entity) {
    if (this._config.hide_keypad || !entity.attributes.code_format) return '';
    return `
      <div class="pad">
        <div>
          ${this._keypadButton("1", "")}
          ${this._keypadButton("4", "GHI")}
          ${this._keypadButton("7", "PQRS")}
        </div>
        <div>
          ${this._keypadButton("2", "ABC")}
          ${this._keypadButton("5", "JKL")}
          ${this._keypadButton("8", "TUV")}
          ${this._keypadButton("0", "")}
        </div>
        <div>
          ${this._keypadButton("3", "DEF")}
          ${this._keypadButton("6", "MNO")}
          ${this._keypadButton("9", "WXYZ")}
          ${this._keypadButton(this._label("ui.card.alarm_control_panel.clear_code"), "")}
        </div>
      </div>`
  _keypadButton(button, alpha) {
    let letterHTML = '';
    if (this._config.display_letters) {
      letterHTML = `<div class='alpha'>${alpha}</div>`
    return `<button value="${button}">${button}${letterHTML}</button>`;
  _style(icon_style, entity) {
    const style = document.createElement('style');
    style.textContent = `
      ha-card {
        ${(this._config.hide_keypad ||
	   !entity.attributes.code_format) ? 'padding-bottom: 16px;' : '' }
        position: relative;
        --alarm-color-disarmed: var(--label-badge-green);
        --alarm-color-pending: var(--label-badge-yellow);
        --alarm-color-triggered: var(--label-badge-red);
        --alarm-color-armed: var(--label-badge-red);
        --alarm-color-autoarm: rgba(0, 153, 255, .1);
        --alarm-state-color: var(--alarm-color-armed);
        --base-unit: ${this._config.scale};
        font-size: calc(var(--base-unit));
        ${icon_style}
      ha-icon {
        color: var(--alarm-state-color);
	    width: 24px;
	    height: 24px;
      ha-label-badge-icon {
        --ha-label-badge-color: var(--alarm-state-color);
        --label-badge-text-color: var(--alarm-state-color);
        --label-badge-background-color: var(--paper-card-background-color);
        position: absolute;
        right: 12px;
        top: 12px;
      .badge-container {
        display: inline-block;
        text-align: center;
        vertical-align: top;
      .label-badge {
        position: relative;
        display: block;
        margin: 0 auto;
        width: var(--ha-label-badge-size, 2.5em);
        text-align: center;
        height: var(--ha-label-badge-size, 2.5em);
        line-height: var(--ha-label-badge-size, 2.5em);
        font-size: var(--ha-label-badge-font-size, 1.5em);
        border-radius: 50%;
        border: 0.1em solid var(--ha-label-badge-color, var(--primary-color));
        color: var(--label-badge-text-color, rgb(76, 76, 76));
        white-space: nowrap;
        background-color: var(--label-badge-background-color, white);
        background-size: cover;
        transition: border 0.3s ease-in-out;
      .label-badge .value {
        font-size: 90%;
        overflow: hidden;
        text-overflow: ellipsis;
      .label-badge .value.big {
        font-size: 70%;
      .label-badge .label {
        position: absolute;
        bottom: -1em;
        /* Make the label as wide as container+border. (parent_borderwidth / font-size) */
        left: -0.2em;
        right: -0.2em;
        line-height: 1em;
        font-size: 0.5em;
      .label-badge .label span {
        box-sizing: border-box;
        max-width: 100%;
        background-color: var(--ha-label-badge-color, var(--primary-color));
        color: var(--ha-label-badge-label-color, white);
        border-radius: 1em;
        padding: 9% 16% 8% 16%; /* mostly apitalized text, not much descenders => bit more top margin */
        font-weight: 500;
        overflow: hidden;
        text-transform: uppercase;
        transition: background-color 0.3s ease-in-out;
        text-transform: var(--ha-label-badge-label-text-transform, uppercase);
      .label-badge .label.big span {
        font-size: 90%;
        padding: 10% 12% 7% 12%; /* push smaller text a bit down to center vertically */
      .badge-container .title {
        margin-top: 1em;
        font-size: var(--ha-label-badge-title-font-size, 0.9em);
        width: var(--ha-label-badge-title-width, 5em);
        font-weight: var(--ha-label-badge-title-font-weight, 400);
        overflow: hidden;
        line-height: normal;
      .disarmed {
        --alarm-state-color: var(--alarm-color-disarmed);
      .triggered {
        --alarm-state-color: var(--alarm-color-triggered);
        animation: pulse 1s infinite;
      .arming {
        --alarm-state-color: var(--alarm-color-pending);
      .pending {
      @keyframes pulse {
        0% {
        100% {
          --ha-label-badge-color: rgba(255, 153, 0, 0.3);
      paper-input {
        margin: auto;
        max-width: 200px;
      .state {
        margin-left: 20px;
        font-size: calc(var(--base-unit) * 0.9);
        position: relative;
        bottom: 16px;
        animation: none;
      .pad {
        display: flex;
        justify-content: center;
      .pad div {
        display: flex;
        flex-direction: column;
      .pad button {
        position: relative;
        padding: calc(var(--base-unit)*0.5);
        font-size: calc(var(--base-unit) * 1.6);
        width: calc(var(--base-unit) * 6);
        margin: 8px;
        #background-color: var(--primary-background-color);
        background-color: var(--primary-color);
        border-width: 2px;
        border-style: solid;
        border-color: var(--primary-color);
        border-radius: 4px;
        #color: var(--primary-color);
        color: var(--text-primary-color);
      .pad button:focus {
        background-color: var(--dark-primary-color);
        border-width: 2px;
        outline: none;
      .actions {
        margin: 0 8px;
        display: flex;
        flex-wrap: wrap;
        font-size: calc(var(--base-unit) * 1);
      .actions mwc-button {
        min-width: calc(var(--base-unit) * 9);
		margin-top: 0px;
		margin-right: 4px;
		margin-bottom: 0px;
		margin-left: 4px;
      .actions .autoarm {
        background: var(--alarm-color-autoarm);
      mwc-button#disarm {
        color: var(--google-red-500);
      .alpha {
        position: absolute;
        text-align: center;
        bottom: calc(var(--base-unit) * 0.1);
        color: var(--secondary-text-color);
        font-size: calc(var(--base-unit) * 0.7);
    return style;
  _label(label, default_label=undefined) {
    // Just show "raw" label; useful when want to see underlying const
    // so you can define your own label.
    if (this._config.show_label_ids) return label;
    if (this._config.labels && this._config.labels[label])
      return this._config.labels[label];
    const lang = this.myhass.selectedLanguage || this.myhass.language;
    const translations = this.myhass.resources[lang];
    if (translations && translations[label]) return translations[label];
    if (default_label) return default_label;
    // If all else fails then pretify the passed in label const
    const last_bit = label.split('.').pop();
    return last_bit.split('_').join(' ').replace(/^\w/, c => c.toUpperCase());
  getCardSize() {
    return 1;
customElements.define('alarm_control_panel-card', AlarmControlPanelCard);
Is it possible to configure this card to only show the keypad when the alarm is armed? I am using a manual alarm with code_arm_required set to false and I do not want to show the keypad when the alarm is disarmed.
Try using the auto_hide option. Click on the state icon to show the keypad when required.
I’d like to make this into a HACs addon once the button font can be improved. Is there a definitive code change to achieve this?
Is any chance to add this card to HACS Community ?
That’s exactly what I want to do. But I want to fix the font issue first.
Thanks for maintaining this card! One question, how do you get the alarm code to show asterisks when entering the code? regardless of using the keypad that’s part of the alarm, the keypad on my android phone or on my iPad the numbers is always showing when disarming.
I’m feeling rather stupid here. I cannot seem to get the keypad to appear even after reading and making changes based on this thread. Here is my code:
  • entity: alarm_control_panel.43155
    show_keypad: true
    code: ‘0000’
    states:
    - arm_home
    - arm_away
    title: Alarm
    type: ‘custom:alarm_control_panel-card’
Any help would be greatly appreciated.
Try: hide_keypad: false
Sadly, no change.
try indenting the states 2 spaces in (arm_home & arm_away) so the dashes are under the letter a of the word states. It would help as well if you formatted your bits with 3 ```.
I figured it out and it had more to do with how I initially added my alarm system (SimpliSafe) than my code. When I originally added it, I did it through the auto-discovery system. Well, that never added it to the configuration.yaml file so this had nothing to reference. I added it through the configuration.yaml file and it now works. Thank you for attempting to help.
Try this one, it works you just need to change the entity to your alarm panel name.
entity: alarm_control_panel.ha_alarm
show_keypad: true
title: My Alarm
states:
  - arm_home
  - arm_away
glad to hear you fix it.
My card looks different than the examples. I replaced “paper-button” with “mwc-button” to get the square buttons rather than just numbers, and left everything else alone. The “Arm Home” and “Arm Away” buttons are touching, and the status icon at the top right never loads, no matter the status. I disabled the theme thinking that might be it, but it made no difference.
I’ve dug through the js file and saw that it is calling icons from mdi, but nothing is showing. Anyone have any advice on what is going on here?
Thanks to all of you who shared their work. This is why Home Assistant is the best Home-Automation-System out there; it’s the community!
I did a one more change to the last commit:
  • Changed input-type to “password” to not display the code at input
alarm_control_panel-card.js
  constructor() {
    super();
    this._icons = {
  set hass(hass) {
    if (entity) {
      this.myhass = hass;
    card.innerHTML = `
    this._setupInput();
  setConfig(config) {
        throw new
    if (config.title) {
    } else {
    } else {
      } else {
  _actionButtons() {
    return `
      </div>
      </div>`;
      !stateLabel
      : stateLabel;
  _iconLabel() {
    return `
            <div class="value">
            </div>
            </div>
          </div>
        </div>
  _setupActions() {
        } else {
    } else {
      code: code,
  _setupInput() {
  _setupKeypad() {
          input.value = '';
      } else {
          this._autoEnter();
  _autoEnter() {
  _keypad(entity) {
    return `
      <div class="pad">
        <div>
        </div>
        <div>
        </div>
        <div>
        </div>
      </div>`
      ha-card {
        position: relative;
        ${icon_style}
      ha-icon {
	    width: 24px;
	    height: 24px;
        position: absolute;
        right: 12px;
        top: 12px;
      .badge-container {
        text-align: center;
      .label-badge {
        position: relative;
        display: block;
        margin: 0 auto;
        text-align: center;
        border-radius: 50%;
        font-size: 90%;
        overflow: hidden;
        font-size: 70%;
        position: absolute;
        bottom: -1em;
        left: -0.2em;
        right: -0.2em;
        line-height: 1em;
        font-size: 0.5em;
        max-width: 100%;
        border-radius: 1em;
        font-weight: 500;
        overflow: hidden;
        font-size: 90%;
        margin-top: 1em;
        overflow: hidden;
      .disarmed {
      .triggered {
      .arming {
      .pending {
      @keyframes pulse {
        0% {
        100% {
      paper-input {
        margin: auto;
        max-width: 200px;
      .state {
        margin-left: 20px;
        position: relative;
        bottom: 16px;
        animation: none;
      .pad {
        display: flex;
      .pad div {
        display: flex;
      .pad button {
        position: relative;
        margin: 8px;
        border-width: 2px;
        border-radius: 4px;
      .pad button:focus {
        border-width: 2px;
        outline: none;
      .actions {
        margin: 0 8px;
        display: flex;
        flex-wrap: wrap;
		margin-top: 0px;
		margin-right: 4px;
		margin-bottom: 0px;
		margin-left: 4px;
      .actions .autoarm {
      mwc-button#disarm {
      .alpha {
        position: absolute;
        text-align: center;
    return style;
  getCardSize() {
    return 1;
In the Lovelace-UI:
entity: alarm_control_panel.alarmanlage
labels:
  ui.card.alarm_control_panel.arm_away: Unterwegs
  ui.card.alarm_control_panel.arm_home: Zuhause
  ui.card.alarm_control_panel.arm_night: Nachtmodus
  ui.card.alarm_control_panel.clear_code: ←
  ui.card.alarm_control_panel.code: Code
states:
  - arm_home
  - arm_away
  - arm_night
title: Alarmanlage
type: 'custom:alarm_control_panel-card'
My (german) output (with the midnight-theme):
I would like to change the font-size (e.g. clear-button) to match bigger words. Anyone knows how to do this for just one keypad-button?
Kind regards!
