Lovelace: Alarm card
Still looks nice though :wink:
What i was meaning is that we should have a ticket open for this since it has changed the default look and feel which did work and is still advertised in the documentation of HA. Sadly i donā€™t know what changed otherwise i would prefer to send in a PR instead. Perhaps we/all can look into that and make it happen? Because the card itself is fine as it stand (except for the css)
could you show your config to enlarge the buttons on the stock alarm card?
Sure thing. This styling requires the plugin I linked above to be installed first.
        - type: 'custom:hui-alarm-panel-card' # alarm-panel #
          style:
              ha-card {
                --mdc-theme-primary: white;
            "#keypad mwc-button":
                :host {
                  background: transparent;
                button {
                  font-size: 27px !important;
            "#keypad mwc-button:nth-of-type(12)":
                button {
                  font-size: 17px !important;
                  --mdc-theme-primary: lime;
          entity: alarm_control_panel.ha_alarm
The styling for the pop-up card can be found here.
Cheersā€¦ shame it requires SO MUCH effort to tame those little buttonsā€¦ :\
Found that issue that was bound to be out thereā€¦ https://github.com/home-assistant/home-assistant-polymer/issues/2812
Yup, problem with the new mwc-button is, font styles doesnā€™t take effect, and the fonts are WAYYY to small. I ended up changing the mwc-buttons to stanard button. Looks much better now.
Alarm_panel
Care to share that config, presume others would want it too :wink:
Hi,Iā€™m interesting in that config for buttons, could you share it? Thanks
Itā€™s not changed by config, I modified the code for the alarm_control_panel-card.js
class AlarmControlPanelCard extends HTMLElement {
  constructor() {
    super();
    this.attachShadow({ mode: 'open' });
    this._icons = {
      'armed_away': 'mdi:shield-lock',
      'armed_custom_bypass': 'mdi:security',
      'armed_home': 'mdi:shield-home',
      'armed_night': 'mdi:shield-home',
      'disarmed': 'mdi:shield-check',
      'pending': 'mdi:shield-outline',
      'triggered': 'hass:bell-ring',
  set hass(hass) {
    const entity = hass.states[this._config.entity];
    if (entity) {
      this.myhass = hass;
      if(!this.shadowRoot.lastChild) {
        this._createCard(entity);
      if (entity.state != this._state) {
        this._state = entity.state;
        this._updateCardContent(entity);
  _createCard(entity) {
    const config = this._config;
    const card = document.createElement('ha-card');
    card.innerHTML = `
      ${this._iconLabel()}
      ${config.title ? '<div id="state-text"></div>' : ''}
    const content = document.createElement('div');
    content.id = "content";
    content.style.display = config.auto_hide ? 'none' : '';
    //`<paper-input label='${this._label("ui.card.alarm_control_panel.code")}' type="password"></paper-input>` : ''}
    content.innerHTML = `
      ${this._actionButtons()}
      ${entity.attributes.code_format ?
          `<paper-input type="number"></paper-input>` : ''}
      ${this._keypad(entity)}
    card.appendChild(this._style(config.style, entity));
    card.appendChild(content);
    this.shadowRoot.appendChild(card);
    this._setupInput();
    this._setupKeypad();
    this._setupActions();
  connectedCallback() {
  setConfig(config) {
    if (!config.entity || config.entity.split(".")[0] !== "alarm_control_panel") {
      throw new Error('Please specify an entity from alarm_control_panel domain.');
    if (config.auto_enter) {
      if (!config.auto_enter.code_length || !config.auto_enter.arm_action) {
        throw new
          Error('Specify both code_length and arm_action when using auto_enter.');
      this._arm_action = config.auto_enter.arm_action;
    if (!config.states) config.states = ['arm_away', 'arm_home'];
    if (!config.scale) config.scale = '15px';
    this._config = Object.assign({}, config);
    const root = this.shadowRoot;
    if (root.lastChild) root.removeChild(root.lastChild);
  _updateCardContent(entity) {
    const card = root.lastChild;
    const state_str = "state.alarm_control_panel." + this._state;
    if (config.title) {
      card.header = config.title;
      root.getElementById("state-text").innerHTML = this._label(state_str);
      root.getElementById("state-text").className = `state ${this._state}`;
    } else {
      card.header = this._label(state_str);
    root.getElementById("state-icon").setAttribute("icon",
      this._icons[this._state] || 'mdi:shield-outline');
    root.getElementById("badge-icon").className = this._state;
    var iconText = this._stateIconLabel(this._state);
    if (iconText === "") {
      root.getElementById("icon-label").style.display = "none";
    } else {
      root.getElementById("icon-label").style.display = "";
      if (iconText.length > 5) {
        root.getElementById("icon-label").className = "label big";
      } else {
	root.getElementById("icon-label").className = "label";
      root.getElementById("icon-text").innerHTML = iconText;
    const armVisible = (this._state === 'disarmed');
    root.getElementById("arm-actions").style.display = armVisible ? "" : "none";
    root.getElementById("disarm-actions").style.display = armVisible ? "none" : "";
  _actionButtons() {
    return `
      <div id="arm-actions" class="actions">
        ${this._config.states.map(el => `${this._actionButton(el)}`).join('')}
      </div>
      <div id="disarm-actions" class="actions">
        ${this._actionButton('disarm')}
      </div>`;
  _stateIconLabel(state) {
    const stateLabel = state.split("_").pop();
    return stateLabel === "disarmed" ||
      stateLabel === "triggered" ||
      !stateLabel
      : stateLabel;
  _iconLabel() {
    return `
      <ha-label-badge-icon id="badge-icon">
        <div class="badge-container" id="badge-container">
          <div class="label-badge" id="badge">
            <div class="value">
              <ha-icon id="state-icon"/>
            </div>
            <div class="label" id="icon-label">
              <span id="icon-text"/>
            </div>
          </div>
        </div>
    </ha-label-badge-icon>`;
  _actionButton(state) {
    return `<mwc-button outlined id="${state}">
      ${this._label("ui.card.alarm_control_panel." + state)}</mwc-button>`;
  _setupActions() {
    const card = this.shadowRoot.lastChild;
    if (config.auto_hide) {
      root.getElementById("badge-icon").addEventListener('click', event => {
        var content = root.getElementById("content");
        if (content.style.display === 'none') {
          content.style.display = '';
        } else {
          content.style.display = 'none';
      card.querySelectorAll(".actions mwc-button").forEach(element => {
        element.classList.remove('autoarm');
        if (element.id === this._arm_action || element.id === 'disarm') {
          element.classList.add('autoarm');
        element.addEventListener('click', event => {
          if (element.id !== 'disarm') this._arm_action = element.id;
    } else {
          const input = card.querySelector('paper-input');
          const value = input ? input.value : '';
          this._callService(element.id, value);
  _callService(service, code) {
    const input = this.shadowRoot.lastChild.querySelector("paper-input");
    this.myhass.callService('alarm_control_panel', `alarm_${service}`, {
      entity_id: this._config.entity,
      code: code,
    if (input) input.value = '';
  _setupInput() {
    if (this._config.auto_enter) {
      input.addEventListener('input', event => { this._autoEnter() })
  _setupKeypad() {
    const input = root.lastChild.querySelector('paper-input');
    root.querySelectorAll(".pad button").forEach(element => {
      if (element.getAttribute('value') ===
        this._label("ui.card.alarm_control_panel.clear_code")) {
          input.value = '';
      } else {
          input.value += element.getAttribute('value');
          this._autoEnter();
  _autoEnter() {
      const code = card.querySelector("paper-input").value;
      if (code.length == config.auto_enter.code_length) {
        const service = card.querySelector(".actions .autoarm").id;
        this._callService(service, code);
  _keypad(entity) {
    if (this._config.hide_keypad || !entity.attributes.code_format) return '';
    return `
      <div class="pad">
        <div>
          ${this._keypadButton("1", "")}
          ${this._keypadButton("4", "GHI")}
          ${this._keypadButton("7", "PQRS")}
        </div>
        <div>
          ${this._keypadButton("2", "ABC")}
          ${this._keypadButton("5", "JKL")}
          ${this._keypadButton("8", "TUV")}
          ${this._keypadButton("0", "")}
        </div>
        <div>
          ${this._keypadButton("3", "DEF")}
          ${this._keypadButton("6", "MNO")}
          ${this._keypadButton("9", "WXYZ")}
          ${this._keypadButton(this._label("ui.card.alarm_control_panel.clear_code"), "")}
        </div>
      </div>`
  _keypadButton(button, alpha) {
    let letterHTML = '';
    if (this._config.display_letters) {
      letterHTML = `<div class='alpha'>${alpha}</div>`
    return `<button value="${button}">${button}${letterHTML}</button>`;
  _style(icon_style, entity) {
    const style = document.createElement('style');
    style.textContent = `
      ha-card {
        ${(this._config.hide_keypad ||
	   !entity.attributes.code_format) ? 'padding-bottom: 16px;' : '' }
        position: relative;
        --alarm-color-disarmed: var(--label-badge-green);
        --alarm-color-pending: var(--label-badge-yellow);
        --alarm-color-triggered: var(--label-badge-red);
        --alarm-color-armed: var(--label-badge-red);
        --alarm-color-autoarm: rgba(0, 153, 255, .1);
        --alarm-state-color: var(--alarm-color-armed);
        --base-unit: ${this._config.scale};
        font-size: calc(var(--base-unit));
        ${icon_style}
      ha-icon {
        color: var(--alarm-state-color);
	    width: 24px;
	    height: 24px;
      ha-label-badge-icon {
        --ha-label-badge-color: var(--alarm-state-color);
        --label-badge-text-color: var(--alarm-state-color);
        --label-badge-background-color: var(--paper-card-background-color);
        position: absolute;
        right: 12px;
        top: 12px;
      .badge-container {
        display: inline-block;
        text-align: center;
        vertical-align: top;
      .label-badge {
        position: relative;
        display: block;
        margin: 0 auto;
        width: var(--ha-label-badge-size, 2.5em);
        text-align: center;
        height: var(--ha-label-badge-size, 2.5em);
        line-height: var(--ha-label-badge-size, 2.5em);
        font-size: var(--ha-label-badge-font-size, 1.5em);
        border-radius: 50%;
        border: 0.1em solid var(--ha-label-badge-color, var(--primary-color));
        color: var(--label-badge-text-color, rgb(76, 76, 76));
        white-space: nowrap;
        background-color: var(--label-badge-background-color, white);
        background-size: cover;
        transition: border 0.3s ease-in-out;
      .label-badge .value {
        font-size: 90%;
        overflow: hidden;
        text-overflow: ellipsis;
      .label-badge .value.big {
        font-size: 70%;
      .label-badge .label {
        position: absolute;
        bottom: -1em;
        /* Make the label as wide as container+border. (parent_borderwidth / font-size) */
        left: -0.2em;
        right: -0.2em;
        line-height: 1em;
        font-size: 0.5em;
      .label-badge .label span {
        box-sizing: border-box;
        max-width: 100%;
        background-color: var(--ha-label-badge-color, var(--primary-color));
        color: var(--ha-label-badge-label-color, white);
        border-radius: 1em;
        padding: 9% 16% 8% 16%; /* mostly apitalized text, not much descenders => bit more top margin */
        font-weight: 500;
        overflow: hidden;
        text-transform: uppercase;
        transition: background-color 0.3s ease-in-out;
        text-transform: var(--ha-label-badge-label-text-transform, uppercase);
      .label-badge .label.big span {
        font-size: 90%;
        padding: 10% 12% 7% 12%; /* push smaller text a bit down to center vertically */
      .badge-container .title {
        margin-top: 1em;
        font-size: var(--ha-label-badge-title-font-size, 0.9em);
        width: var(--ha-label-badge-title-width, 5em);
        font-weight: var(--ha-label-badge-title-font-weight, 400);
        overflow: hidden;
        line-height: normal;
      .disarmed {
        --alarm-state-color: var(--alarm-color-disarmed);
      .triggered {
        --alarm-state-color: var(--alarm-color-triggered);
        animation: pulse 1s infinite;
      .arming {
        --alarm-state-color: var(--alarm-color-pending);
      .pending {
      @keyframes pulse {
        0% {
        100% {
          --ha-label-badge-color: rgba(255, 153, 0, 0.3);
      paper-input {
        margin: auto;
        max-width: 200px;
      .state {
        margin-left: 20px;
        font-size: calc(var(--base-unit) * 0.9);
        position: relative;
        bottom: 16px;
        animation: none;
      .pad {
        display: flex;
        justify-content: center;
      .pad div {
        display: flex;
        flex-direction: column;
      .pad button {
        position: relative;
        padding: calc(var(--base-unit)*0.5);
        font-size: calc(var(--base-unit) * 1.6);
        width: calc(var(--base-unit) * 6);
        margin: 8px;
        #background-color: var(--primary-background-color);
        background-color: var(--primary-color);
        border-width: 2px;
        border-style: solid;
        border-color: var(--primary-color);
        border-radius: 4px;
        #color: var(--primary-color);
        color: var(--text-primary-color);
      .pad button:focus {
        background-color: var(--dark-primary-color);
        border-width: 2px;
        outline: none;
      .actions {
        margin: 0 8px;
        display: flex;
        flex-wrap: wrap;
        font-size: calc(var(--base-unit) * 1);
      .actions mwc-button {
        min-width: calc(var(--base-unit) * 9);
		margin-top: 0px;
		margin-right: 4px;
		margin-bottom: 0px;
		margin-left: 4px;
      .actions .autoarm {
        background: var(--alarm-color-autoarm);
      mwc-button#disarm {
        color: var(--google-red-500);
      .alpha {
        position: absolute;
        text-align: center;
        bottom: calc(var(--base-unit) * 0.1);
        color: var(--secondary-text-color);
        font-size: calc(var(--base-unit) * 0.7);
    return style;
  _label(label, default_label=undefined) {
    // Just show "raw" label; useful when want to see underlying const
    // so you can define your own label.
    if (this._config.show_label_ids) return label;
    if (this._config.labels && this._config.labels[label])
      return this._config.labels[label];
    const lang = this.myhass.selectedLanguage || this.myhass.language;
    const translations = this.myhass.resources[lang];
    if (translations && translations[label]) return translations[label];
    if (default_label) return default_label;
    // If all else fails then pretify the passed in label const
    const last_bit = label.split('.').pop();
    return last_bit.split('_').join(' ').replace(/^\w/, c => c.toUpperCase());
  getCardSize() {
    return 1;
customElements.define('alarm_control_panel-card', AlarmControlPanelCard);
I think this should be the default, i would send it back as a PR :stuck_out_tongue: thanks for the code
Absolutely this should be the default.
Oh I forgot to mention, I removed the label for the paper-input, the word ā€œCodeā€, as it causes significant lag when used on a low-powered tablet. When you press the keypad buttons, the first button press will cause the word ā€œCodeā€ to shrink, and while animating it, it causes unresponsiveness, and most of the time, the 2nd, and even 3rd button press is not registered. If I press my code in quickly, only 2 or 3 digits is shown.
Thatā€™s weird. I still get the old interface when trying the new code. Did update the version and tried a full restartā€¦ must be missing something obvious!
@quovadis I replace the content of alarm_control_card-panel.js with your post. Changed the version number, cleared the cacheā€¦ and nevertheless the numbers are still super tiny.
I am using the latest hass.io version (0.96.4).
Any idea what I could do wrongly?
Thanks,
GV
The issue is that you are typing the alarm code directly with your keyboard.
To get it working, you have to enter the code using the buttons in the panel.
Sorry guys, it was me who made a mistake, I think I posted the wrong version. I used <button> instead of <mwc-button>. My apologies. Please find the correct code below
  constructor() {
    super();
    this._icons = {
  set hass(hass) {
    if (entity) {
      this.myhass = hass;
    card.innerHTML = `
    this._setupInput();
  setConfig(config) {
        throw new
    if (config.title) {
    } else {
    } else {
      } else {
  _actionButtons() {
    return `
      </div>
      </div>`;
      !stateLabel
      : stateLabel;
  _iconLabel() {
    return `
            <div class="value">
            </div>
            </div>
          </div>
        </div>
  _setupActions() {
        } else {
    } else {
      code: code,
  _setupInput() {
  _setupKeypad() {
          input.value = '';
      } else {
          this._autoEnter();
  _autoEnter() {
  _keypad(entity) {
    return `
      <div class="pad">
        <div>
        </div>
        <div>
        </div>
        <div>
        </div>
      </div>`
      ha-card {
        position: relative;
        ${icon_style}
      ha-icon {
	    width: 24px;
	    height: 24px;
        position: absolute;
        right: 12px;
        top: 12px;
      .badge-container {
        text-align: center;
      .label-badge {
        position: relative;
        display: block;
        margin: 0 auto;
        text-align: center;
        border-radius: 50%;
        font-size: 90%;
        overflow: hidden;
        font-size: 70%;
        position: absolute;
        bottom: -1em;
        left: -0.2em;
        right: -0.2em;
        line-height: 1em;
        font-size: 0.5em;
        max-width: 100%;
        border-radius: 1em;
        font-weight: 500;
        overflow: hidden;
        font-size: 90%;
        margin-top: 1em;
        overflow: hidden;
      .disarmed {
      .triggered {
      .arming {
      .pending {
      @keyframes pulse {
        0% {
        100% {
      paper-input {
        margin: auto;
        max-width: 200px;
      .state {
        margin-left: 20px;
        position: relative;
        bottom: 16px;
        animation: none;
      .pad {
        display: flex;
      .pad div {
        display: flex;
      .pad button {
        position: relative;
        margin: 8px;
        border-width: 2px;
        border-radius: 4px;
      .pad button:focus {
        border-width: 2px;
        outline: none;
      .actions {
        margin: 0 8px;
        display: flex;
        flex-wrap: wrap;
		margin-top: 0px;
		margin-right: 4px;
		margin-bottom: 0px;
		margin-left: 4px;
      .actions .autoarm {
      mwc-button#disarm {
      .alpha {
        position: absolute;
        text-align: center;
    return style;
  getCardSize() {
    return 1;
Is it possible to configure this card to only show the keypad when the alarm is armed? I am using a manual alarm with code_arm_required set to false and I do not want to show the keypad when the alarm is disarmed.
Try using the auto_hide option. Click on the state icon to show the keypad when required.
Iā€™d like to make this into a HACs addon once the button font can be improved. Is there a definitive code change to achieve this?
Is any chance to add this card to HACS Community ?
Thatā€™s exactly what I want to do. But I want to fix the font issue first.
