azel_inc
(azel inc)
May 17, 2019, 3:03am
21
I did. i m using GUI, so i include the resources the “GUI” method, which clicking the 3 dots when opening the GUI.
THen i proceed with the code after using “toggle editor”
- title: Horizontal
panel: true
cards:
- type: custom:layout-card
layout: horizontal
cards:
- type: entities
entity: binary_sensor.door_window_sensor_158d0001f3a162
- type: entities
This is what i uses to see whether it works or not.
This is the error i m getting.
No card type found
"title": "Horizontal",
"panel": true,
"cards": [
"type": "custom:layout-card",
"layout": "horizontal",
"cards": [
"type": "entities",
"entity": "binary_sensor.door_window_sensor_158d0001f3a162"
"type": "entities",
petro
(Petro)
May 17, 2019, 3:06am
22
Your top card is missing a card type, unless that is the view
azel_inc
(azel inc)
May 17, 2019, 3:12am
23
I dont think i follow you here. Tbh, i m pretty new at this thing. Lol
I would think that the card type is the custom:layout-card.
then, my two entities card (in this example, same cards) are the one being stacked horizontally?
petro
(Petro)
May 17, 2019, 3:14am
24
Is that your entire configuration?
azel_inc
(azel inc)
May 17, 2019, 3:16am
25
Yes, that is all. i m assuming that it is no different with how i would write for simple entities type card?
petro
(Petro)
May 17, 2019, 3:18am
26
azel_inc:
title: Horizontal panel: true cards: - type: custom:layout-card layout: horizontal cards: - type: entities entity: binary_sensor.door_window_sensor_158d0001f3a162 - type: entities entity: binary_sensor.door_window_sensor_158d0001f3a162
try this:
- title: Horizontal
panel: true
cards:
layout: horizontal
cards:
- type: entities
entities:
- binary_sensor.door_window_sensor_158d0001f3a162
- type: entities
entities:
azel_inc
(azel inc)
May 17, 2019, 3:22am
27
petro:
title: Horizontal panel: true cards: - type: custom:layout-card layout: horizontal cards: - type: entities entities: - binary_sensor.door_window_sensor_158d0001f3a162 - type: entities entities: - binary_sensor.door_window_sensor_158d0001f3a162
I tried that actually. but, anyway tried that again n still wont work.
Still got this;
No card type found
"panel": true,
"cards": [
"cards": [
"type": "entities",
"entities": [
"type": "entities",
"entities": [
petro
(Petro)
May 17, 2019, 3:23am
28
So where is your resource located and what string did you put in to the resource section? (layout-card)
azel_inc
(azel inc)
May 17, 2019, 3:30am
29
petro:
I put in raw config editor…which is using GUI (three dots)
the .js file is at /config/www/plugins
initially, i use below (which is copied directly from the guide;
resources:
- type: js
url: /local/plugins/card-modder.js?v=1
THen i tried changing to below, thinking i might have different location of the file.
resources:
- type: js
url: /local/www/plugins/card-modder.js?v=1
update: i have tried renaming the resources to
resources:
- type: js
url: /local/www/plugins/card-tools.js?v=1
because apparently the js file name is card-tool.js… i cant figure out the ?v=1 is needed or not, but i tried putting both with and without, n result is still the same… i m at dead end now… anyway, thanks for the helps so far!
petro
(Petro)
May 17, 2019, 12:02pm
30
resources:
- type: js
is correct. but the card you are installing in the layout-card no? So the js file should be the contents of the layout-card and it should be named layout-card.js
azel_inc
(azel inc)
May 23, 2019, 10:02am
31
again, i dont think i can understand you…i might have to give up trying this now…haha…
when i look at it again, i m a little bit confused now…got mixed up with card-tools.js and card-layout.js
i just realised that what i done is actually installed card-tools.js …only this…
because when i refer to this link https://github.com/thomasloven/lovelace-layout-card
first thing it says is to install card-tools.s by following this instruction here https://github.com/thomasloven/hass-config/wiki/Lovelace-Plugins
that link let me install card-tools.js only. i m lost what should i done after that…because after that, it only says “If you are using custom updater”, which i m not sure i do.
petro
(Petro)
May 23, 2019, 12:48pm
32
layout-card just requires card-tools. You are over complicating this. Install card-tools, then install layout-card.
kajmaj
September 30, 2020, 11:00am
33
I would like to reactivate this older tread with a question:
Is it possible to arrange cards on the page in the following way?
petro
(Petro)
September 30, 2020, 1:49pm
34
You can with the custom layout-card, but it won’t be easy and it will look terrible on mobile.
kajmaj
September 30, 2020, 3:58pm
35
Would you be so kind to point me to the right direction?
I need it for wall panel (tablet) homescreen, with layout 8 columns and 5 rows. so I do not care mobile.
I tried some options with custom layout-card
w/o success.
It seems that I cannot adjust width/height of particular cards.
