Lovelace-auto-entities: How to provide option for template filter
I’m parsing sensor attribute which contains a list of entityIds and trying to render them as Button cards inside grid using lovelace-auto-entities.
The sensor attribute looks like
light.yoga_room_lights, light.rohit_office_lights
and I’m able to render this value as entity cards using below
type: custom:auto-entities
card:
  type: entities
  title: Monitored Devices
filter:
  template: |
    {{ state_attr('sensor.monitored_entities','entities') }}
sort:
  method: last_changed
  ignore_case: true
  numeric: false
but as soon as I change type to grid and change it as per the doc as below, it does not render
card:
  type: grid
card_param: cards
filter:
  template: |
sort:
  ignore_case: true
  numeric: false
based on the doc it needs following:
options:
        type: button
but also as per the doc, the option field is only available to include and exclude filters and I’m using template filter here.
Please advise how to handle this.
Hi, this thread is a bit older, but I found it when I ran into the same issue and wanted to document my solution, maybe it is still relevant for @rlchandani.
After a bit of fiddling, I came up with a hack, formed by the following train of thoughts:
  • We can’t pass anything via options if we want to use template
  • The value of template (after evaluation of the template) is a list of entity_ids that is passed to cards, e.g. ['light.foo','light.bar']
  • To include the type:button, we would have to pass [{'entity':'light.foo','type':'button'},{'entity':'light.bar','type':'button}], so not a list of strings, but a list of key:value maps (dicts in python).
  • Which is not good, because we can’t (as far as I know) dynamically construct lists and dicts inside jinja templates and this is also where filter pipelines come to their limits.
  • But wait :bulb:, we don’t really pass a list, we pass a string that can be parsed as a list!
  • So we don’t have to generate a list of dicts, we have to generate a string that looks like it:
So:
filter:
  template: >
    {% for e in ['light.foo','light.bar'] %}
      {{ {'entity': e, 'type': 'button' } }}
    {% endfor %}
evaluates to
  {'entity': 'light.foo', 'type': 'button'}
  {'entity': 'light.bar', 'type': 'button'}
Which works good enough as a list of key:value maps for the entities in grid and we can have our type:button for each entity:light :white_check_mark:
The whole thing can now be tuned to get the list of entities from an attribute as above, use dict(k=v) for readabilty, look up more states on the way and also do everything in a single line:
filter:
  template: >
    [ {% for e in state_attr('sensor.monitored_entities','entities') %} {{ dict(entity=e, type='button', name=state_attr(e,'my_custom_name' ) }} , {% endfor %} ]
Now it reads (almost) like a list comprehension :yum:
(But remember, it does not actually create a list, just a string that looks like one, so we can’t append any filters for iterables (e.g. | select(...))
(( Which might be doable though, with a crazy construct of map, to_json(), format, and from_json :thinking: ))
I’ve been pulling my hair out for the past 8 hours trying to do this - your solution saved the day! What an elegant solution :smile:
Wow, this solved my problem. Thank you!
See the second code example in this posting for an example of how I used it to find all my Shelly devices in a filter template and build a custom:template-entity-row entity for each of them.
