I hope you know the different between a “button” and an “icon” as i referred to, in the “old” commend
http://homeassistant.local:8123/hacs/repository/186765704
( The Manual )
PS: And do also notice that this card seems “abandoned” !, latest fix was more than a year ago, and since then also PR are not “handled”, and simple questions not answered
Try use this Fork instead
Andy0G0
(Andrew Gerrard)
September 30, 2023, 4:15pm
315
Love your cards!
How did you manage to get backgrounds working for some reason I am unable to get mine to work. I have code as follows but they just stay blank…
type: custom:banner-card
background: url:("local/test2.jpg")
heading:
- mdi:bed-empty
- Test Room
entities:
- entity: light.flower_lamp
service: light.toggle
map_state:
'on':
color: deeppink
value: mdi:flower-outline
'off':
color: teal
Noblewolf
(Josh)
October 14, 2023, 12:23am
316
I’m sorry to say that I cannot help you. I rebuilt my whole home assistant when I moved a few weeks ago and did not go with banner cards this time. And, I don’t remember how I did it when it set it up a couple of years ago.
ranug
(ranug)
October 15, 2023, 3:21pm
317
Hi, have the same question and didn’t found anything helpful. Have you found a solution for your problem?
troy.hass
(Troy)
October 16, 2023, 8:58am
318
The syntax on your url method call is wrong - you need to remove the colon.
Try background: url("local/test2.jpg")
I’m not sure if you can reference local media like that, as I’ve always hosted externally, but it might help.
mason
(Mason)
October 16, 2023, 2:48pm
319
for me its working with : background: url(/local/flur.jpg) … loose the double quote also make sure you have your picture in ./config/www on the host
Maynstream
(Maynstream)
January 17, 2024, 12:23pm
320
Really like this banner-card, one question though.
I have a sensor/entity and it displays to up to 7 decimals. When I click on it > cog wheel > precision, I can change it to 2 decimals, but it doesn’t change in the graph itself. When I use another card (mini-card graph, for example) I do get the right figure (2 decimals).
Anyone got a solution?
ddavidd88
(David)
January 30, 2024, 11:02am
321
Can you type the conf in yaml for the thermostat? It’s looking amazing!
ddavidd88
(David)
January 30, 2024, 11:18am
322
Hi! How about show percentage of the lights in the card? thx
Wondering if anyone can help with code a button for a fan that cycles from Off => 40% => 70% => 100% => Off?
Looking for something like a singe icon button on this card that cycles through these setting with each tap.
I’m only able to get it to go from Off => 100% => Off which is just turning off and on.
Hey Guys,
it is posible to make in the heading directly a entity? and not only text and icon?
heading:
- mdi:calendar
- entity: sensor.date_complete
entities:
- entity: sensor.aussen_temperature
- entity: sensor.wohnzimmer_temperature
- entity: sensor.nachste_abholung
big thanks,
hello
Can anyone help me erase these lines?
I already tried adding reference code above but it didn’t work
devedsmith
(David Smith)
March 18, 2024, 11:40am
327
Hey mclaudiopt, how did you reduce the margins around the heading? I’ve tried using this card but it takes up too much blank space to be really useful. Reducing the margins on that heading would allow me to start using this.
Hi @jorge20rocha ,
Image:
Code:
- type: custom:banner-card
heading: "Living"
background: right / cover no-repeat url("/local/bg_area/banner_tv_navy.png")
link: /lovelace/living
style: |
ha-card .heading {
display: block;
margin-right: auto;
color: var(--primary-text-color);
font-size: 2.8em;
margin-top: 0.75em;
margin-bottom: 0.75em;
opacity: 0.9;
font-weight: 400;
ha-card .entities {
font-size: 1em;
opacity: 0.9;
background-color:rgba(255,255,255,0.1);
ha-card .entity-name {
font-size: 1em;
ha-card .entity-value {
font-size: 1.1em;
ha-card .entity-state {
box-shadow: none;
row_size: 4
entities:
- entity: light.living_hall
- entity: light.living_light
- entity: climate.living_ac
attribute: state
map_state:
"off": mdi:fan-off
"heat": mdi:white-balance-sunny
"dry": mdi:water-outline
"cool": mdi:snowflake
"fan_only": mdi:fan
"heat_cool": mdi:sun-snowflake
- entity: sensor.living_temperature
- entity: light.living_sofa
- entity: light.living_spot
- entity: binary_sensor.entrance_motion
attribute: state
map_state:
"on": mdi:motion-sensor
"off": mdi:motion-sensor-off
- entity: media_player.living_tv
attribute: source
map_state:
"off": mdi:television-off
- entity: light.balcony_light
- entity: light.balcony_grill
- entity: binary_sensor.balcony_window
attribute: state
map_state:
"on": mdi:window-open-variant
"off": mdi:window-closed-variant
- entity: cover.balcony_curtain
- entity: binary_sensor.entrance_door
attribute: state
map_state:
"on":
icon: mdi:door-open
color: firebrick
"off": mdi:door-closed
- entity: lock.entrance_lock
attribute: state
map_state:
"locked": mdi:lock
"unlocked":
icon: mdi:lock-open
color: firebrick
service: lock.unlock
- entity: sensor.living_plant_moisture_soil_moisture
value: mdi:sprout
when:
attributes:
soil_moisture: [">", 80]
value: mdi:sprout
color: firebrick
when:
attributes:
soil_moisture: ["<", 80]
- entity: sensor.living_voc
value: mdi:cloud-circle
color: firebrick
when:
state: [">", 500]
value: mdi:leaf-circle
when:
state: ["<", 500]
SHawn26
(Shawn)
June 1, 2024, 6:10pm
329
Why do i have the text “OFF” / “ON” instead of a toggle/switch.
Any ideas?
Many Thanx. Shawn
l3enjamin
(Benjamin)
July 21, 2024, 7:28pm
330
Same problem here, and i don’t know how to solve it
TM-8
(Thomas)
July 27, 2024, 8:41am
331
Hello, can you please share the code for this?. Thanks Tom
