Try reversing the severity order from low to high, otherwise I don’t see anything wrong with your config.
@Gluwc low to high makes the bars that are green yellow, but the other bars show --bar-color:undefined
still.
Fixed it, had to set the value for green to 100.
Currently you can only set min and max values for the bar, but not for the target. I’ll consider adding a min and max for the target.
First time I am trying use a custom card since before lovelace and I can’t seem to get the card to work I am getting ‘No Card Type Found’ error.
I have followed instructions on github readme and rebooted home-assistant on my PI but keep getting same error message.
These are installation notes on github.
Step 1
Copy
bar-card.js
to<config directory>/www/custom-lovelace/bar-card/bar-card.js
.Step 2
Add
bar-card
resource toui-lovelace.yaml
.resources: - url: /local/custom-lovelace/bar-card/bar-card.js?v=1.0.0 type: js
Step 3
Add a custom card to your
ui-lovelace.yaml
- type: custom:bar-card entity: sensor.example
Placement of bar-card.js in my home-assistant
Code added to top of Lovelace
Attempting to create card
Slight alteration to card code, still no joy.
I am gathering it has something to do with the base of the url but I don’t know what to change it too is local meaning the www folder which is where you can see above in the screen grab the folder/file is.
Please format correctly the code, otherwise will be difficult to help you.
https://community.home-assistant.io/t/how-to-help-us-help-you-or-how-to-ask-a-good-question/114371
First of all replace local
with customcards
. It will link to www
as local
You have to do a correct indentation, use a text editor that supports yaml so that it will be easy to format.
I cannot seem to find a way to disable the animation of the bar-card. I have the following config:
entity: sensor.battery_voltage
title: Battery Voltage
animation: off
height: 50px
icon: mdi:gauge
show_icon: true
align: split
min: 49
max: 57
severity:
- value: 50.5
color: '#FF4500'
- value: 52
color: '#FFA500'
- value: 56.6
color: '#40bf40'
Any suggestions on how to disable the animation?
Yes this is most likely an issue with the resource. It’s possible you don’t have the raw version of the .js file. Double check the contents of this file it should start with class BarCard extends HTMLElement
When using off
in HA yaml files it needs to be quoted like so 'off'
, same goes for 'on'
. I’ve updated the documentation to include this.
Thanks - that works perfectly!
Cool I have opened up my notepad++ and had a look at spacing which is all good and I had a re-read of the how to ask good question guide (I was wondering how to indent on the forum for code now I got it).
I found the issue to be that I downloaded the .js file from github and chrome kindly added html markup to the header of the bar-card.js file, I just copied the code from github and replaced the existing code in my file and restarted hass and now my bar is working .
There is post above which says customcards only applies to those who have installed and activated custom_updater in configuration.yaml which I haven’t done yet, but looks like good idea. I have left my url as /local/custom-lovelace/bar-card/bar-card.js?v=1.1.0 and all is good now.
resources:
- type: js
url: /customcards/custom-lovelace/bar-card/bar-card.js?v=1.0.0
Release 1.2.0 adds the option to set the position of the icon to be outside of the bar. To avoid double config options show_icon
has been replaced by icon_position
Breaking Change
- Removed
show_icon
config option.
Updates
- Added
icon_position
config option. Set this toinside
to replace the removedshow_icon
true
config option.
Fixes
- Fixed
min
/max
per entity config defaulting to0
/100
when no mainmin
/max
card config is set.
Examples
title: Icon
title_position: inside
icon_position: left
align: split
icon: mdi:eye
I don’t get any icon at all…
- type: entities
show_header_toggle: false
entities:
entity: sensor.phone_battery
title_position: 'off'
icon_position: left
align: center
indicator: 'off'
height: 26px
icon: mdi:eye
card_style:
border-radius: 0px
background: 'rgba(0, 0, 0, 0.0)'
box-shadow: 'inset 2px 2px 3px 1px rgba(0, 0, 0, 0.0)'
background_style:
background: 'black'
severity:
- value: 25
color: red
- value: 50
color: orange
- value: 100
color: green
This is showing two bars each in a vertical-stack
both of which are in a horizontal-stack
(if that is relevant).
One of them has an explicit icon defined (for testing) the other doesn’t (but the entity itself does).
@klogg Can’t reproduce. You sure it’s not just a caching issue again?
- type: custom:vertical-stack-in-card
cards:
- type: horizontal-stack
cards:
entity: sensor.test_value1
icon_position: left
align: center
indicator: 'off'
height: 26px
icon: mdi:eye
severity:
- value: 25
color: red
- value: 50
color: orange
- value: 100
color: green
icon_position: left
align: center
indicator: 'off'
height: 26px
icon: mdi:eye
severity:
- value: 25
color: red
- value: 50
color: orange
- value: 100
color: green
You think I’d have learnt by now…
No worries, I don’t think you’re the only one forgetting about cache.
I’d recommend using custom updater and tracker card. This allows you to set the resource url to redirect to customcards
instead of local
, which makes it so you don’t have to add versioning to the resource url and just updates the cache whenever you update a card.
Wait, what? I do use custom updater and tracker card. Are you saying that means I shouldn’t have to be constantly pressing F5? That is why I am so surprised embarrassed at forgetting.
Mine don’t seem to (always) update the cache. I’m using F5 the whole time!
it doesn’t always do it. ctrl+f5 will do it all, all the time. Or if you have dev tools open, just a regular old f5.
I’m not sure, there might be cases where it doesn’t always work. But afaik if you use customcards
instead of local
in the resource url it should update the cache if you refresh the page.
Hi! I am trying to get mine to show like this;
But how do i add list on entities that i can individual config options per defined entity?
My code looks like this
- type: custom:card-modder
card:
entities:
- sensor.disk_free
- sensor.disk_use_percent
- sensor.disk_use
icon_position: left
columns: 2
align: right
title: Harddisk
show_icon: true
icon: mdi:harddisk
And this is the result:
Hope you can help with a sample code i can use.
