Lovelace: Bar Card
Yes, still works for me
Hi how can I change the font color inside the bars?
Mine is white and can barely if the bar is yellow.
And also if how do I stack the circled part horizontally.
Is there some technique that can display a single card with bar elements next to a status element? Maybe like in a 30/70 column setup inside the card border that would result in something like this?
stack-in-card + card-mod
or
layout-card
What is the code I use to get these rounded bars?
How do I place these rounded battery bars?
        card_mod:
          style: |-
            ha-card{
              --bar-card-border-radius: 10px;
              box-shadow:
I would like to have a duration shown in the bar card. The problem is that I have a duration created with history_stats like this:
platform: history_stats
entity_id: media_player.tv
state: 'on'
type: time
start: '{{ now().replace(hour=0, minute=0, second=0, microsecond=0) }}'
end: '{{ now() }}'
When I display this entity with custom:bar-card like this:
    - type: custom:bar-card
      entities:
        - entity: sensor.wz_tv_time_today
          name: TV Zeit heute
          icon: mdi:television
          max: 12
          severity:
            - color: green
              to: 1
            - color: yellow
              to: 3
            - color: red
              to: 24
      height: 25px
      positions:
        icon: inside
        indicator: inside
      entity_row: true
      style: |
        bar-card-name { color: black}
        bar-card-iconbar { color: white }
        bar-card-value { padding-right: 10px; color: white; }
        bar-card-currentbar, bar-card-backgroundbar { border-radius: 0.5em; }
        bar-card-contentbar { font-size: 12px; }
        bar-card-indicator { display: none; }
        ha-card {
            --mdc-icon-size: 18px;
I get this:
What I would like to get is not having a floating point value like 2.03, but 02:02 (0.03*60 = 1.8) instead. How can I achieve this? Is it possible to internally use the entity for calculation and then define something else to be displayed in the bar?
Your only option is using card-mod & “:after” pseudo class:
type: entities
entities:
  - entity: input_number.test_level_1
    entities:
    positions:
      icon: off
      indicator: off
      value: inside
    entity_row: true
    style: |
      bar-card-value {
        font-size: 0px;
      bar-card-value:after {
        content: "00:20:00";
        font-size: var(--mdc-typography-body1-font-size,1rem);
and you need to specify an appropriate template inside the “content” value, like:
content: "{% set xyz = ... -%}
How do I hide the border?
Hello, everyone. I’m having difficulty with entities in the ‘unavailable’ state using ‘states(config.entity)’ in the style.
My code:
type: custom:auto-entities
card:
  title: Nível das Baterias
  type: entities
filter:
  template: |-
    {% for state in states.sensor -%}
      {%- if state.entity_id | regex_match("sensor.esp_kiwi_soil_sector_.*battery", ignorecase=False) -%}
            'entity_row': true,
            'entity': state.entity_id,
            'name': state.attributes.friendly_name.replace('ESP - Kiwi Soil ', '').replace(' Battery', ''),
            'type': 'custom:bar-card',
            'height': '32px',
            'max': "100",
            'positions': {
              'name': 'inside',
              'icon': "inside",
              'value': 'inside',
              'indicator': "off",
            'card_mod': {
              'style':
                'bar-card-name, bar-card-value {
                  font-size: 14px !important;
                  font-weight: bold !important;
                  margin-right: 20px !important;
                bar-card-currentbar, bar-card-targetbar, bar-card-backgroundbar {
                  border-radius: 10px !important;
                bar-card-row {
                  margin-bottom: 2px !important;
                bar-card-iconbar {
                  color: var(--bar-card-icon-color);
                ha-card {
                  border: none !important;
                ha-icon, bar-card-backgroundbar, bar-card-currentbar {
                  {% if states(config.entity) | int <= 10 %}
                    --card-mod-icon: mdi:battery-10 !important;
                    --bar-color: #FF1700 !important;
                  {% elif states(config.entity) | int <= 20 %}
                    --card-mod-icon: mdi:battery-20 !important;
                  {% elif states(config.entity) | int <= 30 %}
                    --card-mod-icon: mdi:battery-30 !important;
                  {% elif states(config.entity) | int <= 40 %}
                    --card-mod-icon: mdi:battery-40 !important;
                    --bar-color: #FF8E00 !important;
                  {% elif states(config.entity) | int <= 50 %}
                    --card-mod-icon: mdi:battery-50 !important;
                  {% elif states(config.entity) | int <= 60 %}
                    --card-mod-icon: mdi:battery-60 !important;
                    --bar-color: #FFE400 !important;
                  {% elif states(config.entity) | int <= 70 %}
                    --card-mod-icon: mdi:battery-70 !important;
                  {% elif states(config.entity) | int <= 80 %}
                    --card-mod-icon: mdi:battery-80 !important;
                    --bar-color: #06FF00 !important;
                  {% elif states(config.entity) | int <= 90 %}
                    --card-mod-icon: mdi:battery-90 !important;
                  {% elif states(config.entity) | int <= 100 %}
                    --card-mod-icon: mdi:battery !important;
                  {% else %}
                    --card-mod-icon: mdi:battery-alert-variant !important;
                  {% endif %}
      {%- endif -%}
    {%- endfor %}
If I remove this part of the code, the style already works:
                  {% else %}
                  {% endif %}
Try to use this:
ha-card {
Do you want unavailable to even be shown? if not i would just filter them out in your initial for state bit:
      | rejectattr('state','in',['unavailable','unknown']) %}
if you have to/want to show them add a default to your int conversion as that is what is failing - cant convert unknown/unavailable/none/undefined, etc. to an int.
                    {% if states(config.entity) | int(default=0) <= 10 %}
                    {% elif states(config.entity) | int(default=0) <= 20 %}
                    {% elif states(config.entity) | int(default=0) <= 30 %}
                    {% elif states(config.entity) | int(default=0) <= 40 %}
                    {% elif states(config.entity) | int(default=0) <= 50 %}
                    {% elif states(config.entity) | int(default=0) <= 60 %}
                    {% elif states(config.entity) | int(default=0) <= 70 %}
                    {% elif states(config.entity) | int(default=0) <= 80 %}
                    {% elif states(config.entity) | int(default=0) <= 90 %}
                    {% elif states(config.entity) | int(default=0) <= 100 %}
                    {% else %}
                    {% endif %}
this should do it :slight_smile: default = 0 just means that if an error occurs in the template it will default the if to be 0. so false, so it will be false all the way down until it reaches the else.
ran into the same problem when making my battery card too :slight_smile:
need to update the post with the solution :slight_smile:
Thanks for your help it’s working now with a little bug. :crazy_face:
The else statement does not work as expected…
{% else %}
  --bar-color: #61677A !important;
The color and the icon not change the entities unavailable
It’s using the other statements in the code in this case:
yes. my mistake i have misunderstood how the default works. you set a default and then you can test for that default so the default you can set to something like:
(default=unknown)
and then your very first if statement should be:
{% if states(config.entity) | int(default=unknown) == unknown %}
you can then do the rest if your elifs without the default :slight_smile:
the default sets a default value rather than the default result of the if statement, i had misunderstood that bit :slight_smile:
it just so happened that i had my error check at the top rather than at the bottom like you did.
Thanks very much for your help, it’s working flawless!
I’m almost finishing, and I have anothers obstacles.
  • Customizing the name ‘unavailable’ to something different, for example, ‘n/a.’ using bar-card-value
  • Adding another value from diferent entities.
In this code, it filters the entities of the batteries with their percentage values, and I have other entities that mention the voltage of the batteries. I would like to combine the values so that they appear on each bar. For example, on the right side of the bar, it should mention ‘100% - 4.2V’
card:
  title: Baterias
  type: entities
filter:
  template: |-
            'entity_row': true,
            'height': '34px',
            'max': '100',
            'positions': {
              'name': 'inside',
              'icon': 'inside',
              'value': 'inside',
              'indicator': 'off',
            'card_mod': {
              'style':
                  #text-shadow: 0px 0px 6px black;
                bar-card-row {
                bar-card-iconbar {
                ha-card {
                    --card-mod-icon: mdi:alert-circle-outline !important;
                    --bar-color: #9E9E9E !important;
                  {% elif states(config.entity) | int(default=0) <= 10 %}
                    --card-mod-icon: mdi:battery-off-outline !important;
                    --bar-color: #E74C3C !important;
                    --bar-color: #FF9800 !important;
                    --bar-color: #FFEB3B !important;
                    --bar-color: #4CAF50 !important;
                  {% endif %}
      {%- endif -%}
    {%- endfor %}
Inserting the below should do this.
                {% if states(config.entity) == "unavailable" %}
                bar-card-value {
                  color: transparent !important;
                bar-card-value::after {
                  content: "n/a";
                  color: var(--primary-text-color) !important;
                {% endif %}
For this i would highly recommend you create a new template sensor that has the 2 states as attributes instead and then do your auto entities based on the new template sensors. You can then just combine the attributes of the same already filtered entity rather than trying to apply the state of one entity with the other (which will be almost impossible to do dynamically.)
To be clear the main state of your new template sensor should be your battery percentage, but it could have as an attribute the voltage as per your other entity.
It works! The issue is that I use the Shadow configuration in the “name” and “value” text :stuck_out_tongue_closed_eyes:
just overwrite it for the ones that are unavailable then :slight_smile:
                bar-card-value {
                  #text-shadow: 0px 0px 6px transparent;
                  content: "n/a";
                {% endif %}
