Is it possible to sort the items in the list according to a value?
For instance I want to sort the battery list of my sensors depending on the battery value.
Lovelace: Bringing back entity-filter (monster-card)
monster-card appears to be broken in the latest version of HASS (0.80.3). There is the following Javascript error:
Uncaught (in promise) TypeError: localize is not a function
at computeStateDisplay (app-9adb0896.js:2830)
at HTMLElement.renderEntity (b79a536a7632adf704c1.chunk.js:1091)
at lit_element.c.entityConf (b79a536a7632adf704c1.chunk.js:1043)
at containerPart (3e07c1dec7bef00d5ca3.chunk.js:221)
at NodePart.commit (a889fa21cf4c29228072.chunk.js:133)
at TemplateInstance.update (a889fa21cf4c29228072.chunk.js:169)
at NodePart._commitTemplateResult (a889fa21cf4c29228072.chunk.js:133)
at render (a889fa21cf4c29228072.chunk.js:181)
at Function.shady_render_render [as render] (a889fa21cf4c29228072.chunk.js:61)
Edit: Was getting this error when using the glance card. It appears to be fine when using the entities card. I donāt know if other cards are affected.
so iām torn between whether i use built in entity-filter or monster.
my understanding is if you want an easy catch all (all lights that are on) to be displayed, monster may be easier because of the include / exclude feature that entity-filter doesnt have right? i see it being a huge PITA having to list every single entity manually. this becomes more challenging and problematic if you add new sensors, ad you would need to manually remember to add it into the card every time a new device is added.
isnāt the āunused entitiesā view essentially like a monster card that is a catch all?
could i use a built in entity filter to list all light that are currently on without having to statically assign every light i have? from what iāve been reading i think my answer is no, but things seem to change fast, so i figured iād check before diving deep into the config
Iād like to create a card that shows any guests in my house.
I use DHCP and all of my devices either have a static IP or a reserved IP.
If a guest gets on my network, they will get a DHCP address in a certain range⦠x.x.x.220-240
Can a monster-card show all devices with a certain range or is there any other way to do this?
thanks
Iām interested too in this awser.
The only way I found to do this is to create template sensors for each battery and filter on these template, but Iām too lazy to create +30 template sensors
Any idea ?
I guess this could be done with some update to the card logic to allow some sort of rudimentary regex to the card patterns. Can you please raise an issue on github?
Thanks, I had raised a bug regarding this, and it appears to have been fixed in 0.81.1
Something happened with the recent update to 0.81. Until 0.80x everything was perfectly working for the below configuration: whenever a light or an entity_id starting with switch.lightxxxxxx was ON, would appear in frontend.
After updating to 0.81.1 wy light āswitch.light_master_bathroomā when is ON does not show up ⦠any clue?
- id: bc6d27ee ccef05219 # Automatically created id
type: custom:monster-card
card:
type: Entities
title: Lights that are ON
show_header_toggle: false
filter:
include:
- domain: light
state: on
- entity_id: '*switch.light*'
state: on
exclude:
- entity_id: light.garden
- entity_id: light.hallway
Also tried to change as below, but same problems
include:
- domain: light
state: on
- entity_id: switch.light*
state: on
I want to show my climate devices only if the weather temperature is higher than 24 degrees. As I only use them for cooling.
- type: custom:monster-card
card:
type: entities
title: Climate Monster
filter:
include:
- domain: climate
when:
entity: sensor.dark_sky_temperature
state: '>= 24'
It seems that the state requires static numbering. Is it possible to have a number comparison?
Is it normal the monster cards donāt support media-control cards (or any other than entities and glance)?
I finally was able to create a card displaying any media_player.plex playing but I seem to be stuck using entities or glance which isnāt great for media playersā¦
- type: custom:monster-card show_empty: false card: type: glance title: Plex players filter: include: - entity_id: "media_player.plex*" state: 'playing'
Does anyone has any idea why the when option is not working? I have the following card and it is not working properly. It should hide all the card when my sensor is in that state, but nothing happens:
show_empty: false
card:
title: You forgot to turn off
type: entities
filter:
include:
- entity_id: switch.*
state: 'on'
- entity_id: media_player.*
state: 'on'
exclude:
- entity_id: media_player.*phTV*
- entity_id: switch.*phTV*
when:
entity: sensor.who_is_home
state: 'nobody'
Card is displayed as you can see:
but it should be hidden because the sensor is in itās value:
Let me know if someone has any idea or if i configured wrong something.
Cheers!
Loving the monster card. Iām about to make the empty cards hidden but before I do this is what Iām using it for:
EDIT:
Is there a better way to include all unavailable entities?
type: 'custom:monster-card'
show_empty: false
card:
type: glance
title: Unavailable
filter:
include:
- domain: sensor
state: unavailable
- domain: light
state: unavailable
- domain: switch
state: unavailable
HI @ciotlosm,
Iāve tried to combine your monster card with a custom:mini player from @kalkih but without success.
My goal is to have a filtered card that show which media player are playing arond the house.
This is the error I get:
http://myIP:8123/local/monster-card.js?v=0.2.3:112:22 Uncaught TypeError: this.lastChild.setConfig is not a function
Can you please help me?
Thank you in advance
Good day, using this card to automatically pull switches generated by ha-dockermon. all switches have the following syntax:
switch.ha_dockermon_appdaemon
switch.ha_dockermon_booksonic
switch.ha_dockermon_cloud9
using this configuration:
card:
type: glance
show_state: false
title: Support Services (HASS)
filter:
include:
- entity_id: "*dockermon_*"
the UI presents them as such:
HA Dockermon appdaemon
is there any configuration in the card that would allow removing the āHA Dockermonā part?
thank you
Hi All,
Iām trying to use the monster card but since updating Hassio I donāt have the ui-lovelace.yaml anymore. How or where do I insert the āresources:ā portion of this. Thanks for any help!!!
Scott
