I am having an issue with an iframe card. I added it to the list for preload cards however I am still receiving this error:
preload_cards:
- iframe
Is there a way to resolve this?
preload_cards:
- iframe
Due to problem in the doorpi project running a custom card that is not ready for the new custom card version, I have installed this tool. From some reason it has the same issue the doorpi has eg. Custom card doesn’t exists. Any idea?
I am running on Verizon 0.108.6.
Hi @Steven_Rollason, I appear to have a similar issue that this card aims to fix, but I’m having no luck making it work. Do you think it’s due to me using browser_mod to achieve the popup card? I saw that you linked to a conditional card issue earlier, but that looks to have been fixed in 1.108.0 and I’m running 1.108.9.
This is the error:
Here is the code I’m using:
resources:
- url: /hacsfiles/lovelace-card-preloader/lovelace-card-preloader.js
type: js
preload_cards:
- entity-filter
title: Home
- title: Test2
panel: false
path: test2
popup_cards:
input_boolean.window_is_open:
title: Open Windows
card:
type: entity-filter
state_filter:
- "Open"
entities:
- sensor.win_lounge_top_left
- sensor.win_lounge_top_right
cards:
- type: conditional
conditions:
- entity: input_boolean.kiosk_cond_btt1
state: "on"
card:
type: button
name: Turn Off Lights
entity: input_boolean.window_is_open
tap_action:
action: more-info
Thanks.
after updating the HA stopped working custom:hui-conditional-card
I also seem to have trouble getting it to work. I have added the following to my lovelace config:
preload_cards:
- button-card
- mini-media-player
- mod-card
- stack-in-card
- auto-entities
- simple-weather-card
- simple-thermostat
- aarlo-glance
preload_rows:
- fold-entity-row
- slider-entity-row
Yet i still get red errors in my Lovelace views from time to time saying failed to load custom cards and forcing me to keep reloading the page until they finally show up. Anything i am doing wrong?
See if this works any better for you:
Is the preloader still needed in 0.118?
Yes, since lazy loading is still used in 0.118. However, you might find that hui-element (linked in the previous comment) is a better solution.
Same question, with the 2021 release is still needed this card?
Just try…
