Relly nice lovelace card! Great work!
I’m publishing the current time to the mqtt topic through an AppDaemon app and it works but anytime I do this, I get “Entity config outdated. Update?” in the frontend and I have to click it. Is this expected behaviour?
Yes it is expected behaviour, however this shouldn’t be happening. At some point I introduced a version check in the MQTT payload to help people upgrade from an older version. I don’t think this is needed anymore so I’ve removed it from the latest version 0.1.2.
This card is now also on HACS to make it easier to upgrade.
Works perfect now! Thanks a lot!
Is there a way to keep and show info who pressed the button ?
Great way to organize household activities, also keep track who does what and how often
Is this still working I’m not getting any success but probably on my end.
Here is the payload I’m getting back
11/24/2019, 10:50:01 PMnode: c561b706.2bc688
msg.payload : string[147]
"{"timestamp":1574664601,"visibility_timeout":"none","visible":true,"unit_of_measurement":"timestamp","version":"0.1.0","friendly_name":"feed_time"}"
Currently not possible as far as I know. The underlying architecture is not ready for this yet.
Did you update the check-button card to the latest version? The “version” is not required anymore in the payload. For me it works with AppDaemon. What kind of error do you get?
The payload seems correct, however it appears you are publishing to the wrong topic. Try homeassistant/sensor/feed_time
instead.
The version will probably still be in the payload if you’ve set up the button before I removed it in the latest version. It just doesn’t check for a version match anymore.
Ok I changed the topic still no errors but no update to the actual button. any thoughts why?
Ok got it figured needed to add state to end of topic
homeassistant/sensor/feed_time/state
Also did a Pull Request on github for the Readme
I would love to control this with Alexa (we use it mainly for tracking nappies and baby feeding, and handsfree control is preferable) . How can I create a button out of the sensor that’s generated by the extension?
Here’s how I did it
- Define a new virtual device that can be used with Alexa. If you’re only running HA, then emulated hue is a good solution. i’m using Nodered with a special node in order to do so :
- Create a routine that triggers the virtual device. If you’re using a light as the device, you can adjust the brightness in order to ‘filter’ options : if bri=3% then run script_1, if bri=4% then run script_2 and so on.
- From then it’s fairly easy, you just publish an mqtt message with the topic & value required, and your sensor (hence the card) will be updated.
It works great ! I’m at the office so I can’t record anything now but basically, I have a list of chores to do, for example clean furnitures :
And when I’m done I just say “Alexa, I’ve cleaned the furnitures” and the sensor adjusts itself:
Awesome tool so thank you very much!
Has anyone been able to get the check-button-cards to display within a single card and if so how?
I have a vertical stack of 5 buttons but would like all to show under and single “Chores” card and so far i have been unable to achieve this.
You can either use vertical-stack-in-card or just define a list of entities.
- align: split
animation: 'off'
entities:
- entity: sensor.glances_cpu_used
title: CPU
- entity: sensor.glances_disk_used_percent
title: Disk
- entity: sensor.glances_ram_used_percent
title: RAM
icon_position: inside
indicator: 'off'
padding: 2px
severity:
- color: var(--bar-green)
value: 33
- color: var(--bar-yellow)
value: 66
- color: var(--bar-red)
value: 100
type: 'custom:bar-card'
thank you,
it currently is a vertical-stack but displays as seperate cards;
- type: vertical-stack
title: Chores
cards:
- type: custom:check-button-card
title: Hoovering
entity: sensor.hoovering
severity:
- value: 3 days
hue: '140'
- value: 5 days
hue: '55'
- value: 7 days
hue: '345'
title: Dusting
entity: sensor.dusting
severity:
- value: 3 days
hue: '140'
- value: 5 days
hue: '55'
- value: 7 days
hue: '345'
title: Clean Desk
entity: sensor.desk
severity:
- value: 3 days
hue: '140'
- value: 5 days
hue: '55'
- value: 7 days
hue: '345'
title: Bathrooms
entity: sensor.bathrooms
severity:
- value: 3 days
hue: '140'
- value: 5 days
hue: '55'
- value: 7 days
hue: '345'
title: Windows
entity: sensor.windows
severity:
- value: 3 months
hue: '140'
- value: 6 months
hue: '55'
- value: 9 months
hue: '345'
https://github.com/custom-cards/vertical-stack-in-card you can also find it on HACS. I use it for loads of things.
nice work!
any ideas how to do some automations when the button is pressed?
for example I want to create an event in my google calender to have a history
It should just work like any other sensor based automation, since every button is defined as a sensor.
The card updates correctly on a click without issue, I created a script for some automations and when this is run the card updates. However on HASS restart the update from script is forgotten but the update from click stored.
Any ideas?
update_windows:
sequence:
- data_template:
payload_template: '{"timestamp": {{ as_timestamp (now()) | int }},"visible":true,"unit_of_measurement":"timestamp"}'
topic: homeassistant/sensor/windows/state
service: mqtt.publish
alias: Update Windows
