hey.
how do i add it if i use Brodlink IR [switch.fanspeedone? ant sample?
hey.
will you share your code. I believe you are using the zigbee fan remote I have as well!
Sure. Itās here https://github.com/prairiesnpr/Home-AssistantConfig/blob/7ecf19da9645665992cac13cda759f8d39e35366/www/custom_ui/fan-card.js
I have the Hampton Bay/King of Fans Zigbee controller.
Thanks thats mine too. I actually got it to work a second ago by not being lazy and reading the code lol. Working on getting colors to match my custom theme now. Happy Holidays
In case anyone wants this, I took @slipx06 code and customized it for my six speed fan.
class CustomFanCard extends Polymer.Element {
static get template() {
return Polymer.html`
<style>
.flex-container {
display: flex;
justify-content: center;
align-items: center;
@keyframes mdc-ripple-fg-radius-in{from{animation-timing-function:cubic-bezier(0.4, 0, 0.2, 1);transform:translate(var(--mdc-ripple-fg-translate-start, 0)) scale(1)}to{transform:translate(var(--mdc-ripple-fg-translate-end, 0)) scale(var(--mdc-ripple-fg-scale, 1))}}@keyframes mdc-ripple-fg-opacity-in{from{animation-timing-function:linear;opacity:0}to{opacity:var(--mdc-ripple-fg-opacity, 0)}}@keyframes mdc-ripple-fg-opacity-out{from{animation-timing-function:linear;opacity:var(--mdc-ripple-fg-opacity, 0)}to{opacity:0}}.mdc-ripple-surface--test-edge-var-bug{--mdc-ripple-surface-test-edge-var: 1px solid #000;visibility:hidden}.mdc-ripple-surface--test-edge-var-bug::before{border:var(--mdc-ripple-surface-test-edge-var)}.mdc-button{font-family:Roboto,sans-serif;-moz-osx-font-smoothing:grayscale;-webkit-font-smoothing:antialiased;font-size:.875rem;line-height:2.25rem;font-weight:500;letter-spacing:.0892857143em;text-decoration:none;text-transform:uppercase;--mdc-ripple-fg-size: 0;--mdc-ripple-left: 0;--mdc-ripple-top: 0;--mdc-ripple-fg-scale: 1;--mdc-ripple-fg-translate-end: 0;--mdc-ripple-fg-translate-start: 0;-webkit-tap-highlight-color:rgba(0,0,0,0);will-change:transform,opacity;padding:0 8px 0 8px;display:inline-flex;position:relative;align-items:center;justify-content:center;box-sizing:border-box;min-width:64px;height:36px;border:none;outline:none;line-height:inherit;user-select:none;-webkit-appearance:none;overflow:hidden;vertical-align:middle;border-radius:4px}.mdc-button::before,.mdc-button::after{position:absolute;border-radius:50%;opacity:0;pointer-events:none;content:""}.mdc-button::before{transition:opacity 15ms linear,background-color 15ms linear;z-index:1}.mdc-button.mdc-ripple-upgraded::before{transform:scale(var(--mdc-ripple-fg-scale, 1))}.mdc-button.mdc-ripple-upgraded::after{top:0;left:0;transform:scale(0);transform-origin:center center}.mdc-button.mdc-ripple-upgraded--unbounded::after{top:var(--mdc-ripple-top, 0);left:var(--mdc-ripple-left, 0)}.mdc-button.mdc-ripple-upgraded--foreground-activation::after{animation:225ms mdc-ripple-fg-radius-in forwards,75ms mdc-ripple-fg-opacity-in forwards}.mdc-button.mdc-ripple-upgraded--foreground-deactivation::after{animation:150ms mdc-ripple-fg-opacity-out;transform:translate(var(--mdc-ripple-fg-translate-end, 0)) scale(var(--mdc-ripple-fg-scale, 1))}.mdc-button::before,.mdc-button::after{top:calc(50% - 100%);left:calc(50% - 100%);width:200%;height:200%}.mdc-button.mdc-ripple-upgraded::after{width:var(--mdc-ripple-fg-size, 100%);height:var(--mdc-ripple-fg-size, 100%)}.mdc-button::-moz-focus-inner{padding:0;border:0}.mdc-button:active{outline:none}.mdc-button:hover{cursor:pointer}.mdc-button:disabled{background-color:transparent;color:rgba(0,0,0,.37);cursor:default;pointer-events:none}.mdc-button.mdc-button--dense{border-radius:4px}.mdc-button:not(:disabled){background-color:transparent}.mdc-button:not(:disabled){color:#6200ee;color:var(--mdc-theme-primary, #6200ee)}.mdc-button::before,.mdc-button::after{background-color:#6200ee}@supports not (-ms-ime-align: auto){.mdc-button::before,.mdc-button::after{background-color:var(--mdc-theme-primary, #6200ee)}}.mdc-button:hover::before{opacity:.04}.mdc-button:not(.mdc-ripple-upgraded):focus::before,.mdc-button.mdc-ripple-upgraded--background-focused::before{transition-duration:75ms;opacity:.12}.mdc-button:not(.mdc-ripple-upgraded)::after{transition:opacity 150ms linear}.mdc-button:not(.mdc-ripple-upgraded):active::after{transition-duration:75ms;opacity:.16}.mdc-button.mdc-ripple-upgraded{--mdc-ripple-fg-opacity: 0.16}.mdc-button .mdc-button__icon{margin-left:0;margin-right:8px;display:inline-block;width:18px;height:18px;font-size:18px;vertical-align:top}[dir=rtl] .mdc-button .mdc-button__icon,.mdc-button .mdc-button__icon[dir=rtl]{margin-left:8px;margin-right:0}.mdc-button svg.mdc-button__icon{fill:currentColor}.mdc-button--raised .mdc-button__icon,.mdc-button--unelevated .mdc-button__icon,.mdc-button--outlined .mdc-button__icon{margin-left:-4px;margin-right:8px}[dir=rtl] .mdc-button--raised .mdc-button__icon,.mdc-button--raised .mdc-button__icon[dir=rtl],[dir=rtl] .mdc-button--unelevated .mdc-button__icon,.mdc-button--unelevated .mdc-button__icon[dir=rtl],[dir=rtl] .mdc-button--outlined .mdc-button__icon,.mdc-button--outlined .mdc-button__icon[dir=rtl]{margin-left:8px;margin-right:-4px}.mdc-button--raised,.mdc-button--unelevated{padding:0 16px 0 16px}.mdc-button--raised:disabled,.mdc-button--unelevated:disabled{background-color:rgba(0,0,0,.12);color:rgba(0,0,0,.37)}.mdc-button--raised:not(:disabled),.mdc-button--unelevated:not(:disabled){background-color:#6200ee}@supports not (-ms-ime-align: auto){.mdc-button--raised:not(:disabled),.mdc-button--unelevated:not(:disabled){background-color:var(--mdc-theme-primary, #6200ee)}}.mdc-button--raised:not(:disabled),.mdc-button--unelevated:not(:disabled){color:#fff;color:var(--mdc-theme-on-primary, #fff)}.mdc-button--raised::before,.mdc-button--raised::after,.mdc-button--unelevated::before,.mdc-button--unelevated::after{background-color:#fff}@supports not (-ms-ime-align: auto){.mdc-button--raised::before,.mdc-button--raised::after,.mdc-button--unelevated::before,.mdc-button--unelevated::after{background-color:var(--mdc-theme-on-primary, #fff)}}.mdc-button--raised:hover::before,.mdc-button--unelevated:hover::before{opacity:.08}.mdc-button--raised:not(.mdc-ripple-upgraded):focus::before,.mdc-button--raised.mdc-ripple-upgraded--background-focused::before,.mdc-button--unelevated:not(.mdc-ripple-upgraded):focus::before,.mdc-button--unelevated.mdc-ripple-upgraded--background-focused::before{transition-duration:75ms;opacity:.24}.mdc-button--raised:not(.mdc-ripple-upgraded)::after,.mdc-button--unelevated:not(.mdc-ripple-upgraded)::after{transition:opacity 150ms linear}.mdc-button--raised:not(.mdc-ripple-upgraded):active::after,.mdc-button--unelevated:not(.mdc-ripple-upgraded):active::after{transition-duration:75ms;opacity:.32}.mdc-button--raised.mdc-ripple-upgraded,.mdc-button--unelevated.mdc-ripple-upgraded{--mdc-ripple-fg-opacity: 0.32}.mdc-button--raised{box-shadow:0px 3px 1px -2px rgba(0, 0, 0, 0.2),0px 2px 2px 0px rgba(0, 0, 0, 0.14),0px 1px 5px 0px rgba(0,0,0,.12);transition:box-shadow 280ms cubic-bezier(0.4, 0, 0.2, 1)}.mdc-button--raised:hover,.mdc-button--raised:focus{box-shadow:0px 2px 4px -1px rgba(0, 0, 0, 0.2),0px 4px 5px 0px rgba(0, 0, 0, 0.14),0px 1px 10px 0px rgba(0,0,0,.12)}.mdc-button--raised:active{box-shadow:0px 5px 5px -3px rgba(0, 0, 0, 0.2),0px 8px 10px 1px rgba(0, 0, 0, 0.14),0px 3px 14px 2px rgba(0,0,0,.12)}.mdc-button--raised:disabled{box-shadow:0px 0px 0px 0px rgba(0, 0, 0, 0.2),0px 0px 0px 0px rgba(0, 0, 0, 0.14),0px 0px 0px 0px rgba(0,0,0,.12)}.mdc-button--outlined{border-style:solid;padding:0 14px 0 14px;border-width:2px}.mdc-button--outlined:disabled{border-color:rgba(0,0,0,.37)}.mdc-button--outlined:not(:disabled){border-color:#6200ee;border-color:var(--mdc-theme-primary, #6200ee)}.mdc-button--dense{height:32px;font-size:.8125rem}.material-icons{font-family:var(--mdc-icon-font, "Material Icons");font-weight:normal;font-style:normal;font-size:var(--mdc-icon-size, 24px);line-height:1;letter-spacing:normal;text-transform:none;display:inline-block;white-space:nowrap;word-wrap:normal;direction:ltr;-webkit-font-feature-settings:"liga";-webkit-font-smoothing:antialiased}:host{display:inline-flex;outline:none}.mdc-button{flex:1}
:host {
display: inherit;
.speeds button:host {
display: inline-flex;
outline: none;
.speeds button {
min-width: 34px !important;
width: 34px;
font-size: 11px !important;
</style>
<hui-generic-entity-row hass="[[hass]]" config="[[_config]]">
<div class='flex-container' on-click="stopPropagation">
<div class='speeds'>
<button
class='mdc-button mdc-button--raised mdc-ripple-upgraded'
toggles name="off"
on-tap='setSpeed'
disabled='[[_isOff]]'>
<span class="mdc-button__label">O</span>
</button>
<button
toggles name="1"
on-tap='setSpeed'
disabled='[[_isOneSpeed]]'>
<span class="mdc-button__label">1</span>
</button>
<button
toggles name="2"
on-tap='setSpeed'
disabled='[[_isTwoSpeed]]'>
<span class="mdc-button__label">2</span>
</button>
<button
toggles name="3"
on-tap='setSpeed'
disabled='[[_isThreeSpeed]]'>
<span class="mdc-button__label">3</span>
</button>
<button
toggles name="4"
on-tap='setSpeed'
disabled='[[_isFourSpeed]]'>
<span class="mdc-button__label">4</span>
</button>
<button
toggles name="5"
on-tap='setSpeed'
disabled='[[_isFiveSpeed]]'>
<span class="mdc-button__label">5</span>
</button>
<button
toggles name="6"
on-tap='setSpeed'
disabled='[[_isSixSpeed]]'>
<span class="mdc-button__label">6</span>
</button>
</div>
</div>
</hui-generic-entity-row>
static get properties() {
return {
hass: {
type: Object,
observer: 'hassChanged'
_config: Object,
_stateObj: Object,
_isOff: Boolean,
_isOneSpeed: Boolean,
_isTwoSpeed: Boolean,
_isThreeSpeed: Boolean,
_isFourSpeed: Boolean,
_isFiveSpeed: Boolean,
_isSixSpeed: Boolean
setConfig(config) {
this._config = config;
hassChanged(hass) {
const config = this._config;
const stateObj = hass.states[config.entity];
let speed;
if (stateObj && stateObj.attributes) {
speed = stateObj.attributes.speed || 'off';
this.setProperties({
_stateObj: stateObj,
_isOff: stateObj.state === 'off',
_isOneSpeed: speed === '1' && stateObj.state === 'on',
_isTwoSpeed: speed === '2' && stateObj.state === 'on',
_isThreeSpeed: speed === '3' && stateObj.state === 'on',
_isFourSpeed: speed === '4' && stateObj.state === 'on',
_isFiveSpeed: speed === '5' && stateObj.state === 'on',
_isSixSpeed: speed === '6' && stateObj.state === 'on',
stopPropagation(e) {
e.stopPropagation();
setSpeed(e) {
const speed = e.currentTarget.getAttribute('name');
this.hass.callService('fan', 'set_speed', {
entity_id: this._config.entity, speed: speed
customElements.define('custom-fan-card', CustomFanCard);
i have a fan (controlled by remote IR),
How can I edit this custom card to show 5 speed level and for each, on click, run a script where i set the IR code to send with a broadlink?
thanks
Hi all, Iāve seen it asked in some other posts but Iām not sure that if it ever was corrected. When using the custom-fan-card in my lovelace I keep getting this error that pops up at the bottom, everything seems to work with the exception of the Visual Editor, is everyone else getting this as well?
Error: Expected a value of type {entity,name,icon} | entity-id
for entities.0.type
but received "custom:custom-fan-card"
entities:
- entity: fan.lroom_fan
type: 'custom:custom-fan-card'
title: Fans
type: entities
Hi, can you share the code please I want to do just like you
See here.
Hi Tom,
Firstly, thanks for creating a custom fan controller with 6 speed. Iām new to Home assistant and donāt have much idea. Can you please show me step by step who to implement your code from scratch. I have played a little with configuration.yaml.
Reading all these articles and threads are only adding confusion.
Iāve a purchased Atomberg Gorilla Renesa Smart Plus. Used Tuya-convert to push Tasmota and able to use it with HA having three speeds as thatās the speed limit. Having 6 speeds will be fantastic and need your guidance on it.
Thanks in advance!
which version of tuya-convert did you use?
Hi everyone and thanks for your help
I have the file āfan-control-entity-row-5-button.jsā with the following content:
return Polymer.html `
<style is="custom-style" include="iron-flex iron-flex-alignment"></style>
<style>
:host {
line-height: inherit;
.speed {
min-width: 30px;
max-width: 30px;
height: 30px;
margin-left: 2px;
margin-right: 2px;
background-color:#759aaa;
border: 1px solid lightgrey;
border-radius: 4px;
font-size: 10px !important;
color: inherit;
text-align: center;
float: right !important;
padding: 1px;
</style>
<div class='horizontal justified layout' on-click="stopPropagation">
<button
class='speed'
style='[[_lowOnColor]]'
toggles name="low"
on-click='setSpeed'
disabled='[[_isOnLow]]'>LOW</button>
<button
class='speed'
style='[[_medOnColor]]'
toggles name="medium"
on-click='setSpeed'
disabled='[[_isOnMed]]'>MED</button>
<button
class='speed'
style='[[_medHighOnColor]]'
toggles name="medium_high"
on-click='setSpeed'
disabled='[[_isOnMedHigh]]'>MHI</button>
<button
class='speed'
style='[[_highOnColor]]'
toggles name="high"
on-click='setSpeed'
disabled='[[_isOnHigh]]'>HIGH</button>
<button
class='speed'
style='[[_offColor]]'
toggles name="off"
on-click='setSpeed'
disabled='[[_isOffState]]'>OFF</button>
</div>
return {
hass: {
type: Object,
_config: Object,
_stateObj: Object,
_lowOnColor: String,
_medOnColor: String,
_medHighOnColor: String,
_highOnColor: String,
_offColor: String,
_isOffState: Boolean,
_isOnState: Boolean,
_isOnLow: Boolean,
_isOnMed: Boolean,
_isOnMedHigh: Boolean,
_isOnHigh: Boolean
setConfig(config) {
hassChanged(hass) {
let speed;
let low;
let med;
let medHigh;
let high;
let offstate;
if (stateObj.state == 'on' && stateObj.attributes.speed == 'low') {
low = 'on';
} else if (stateObj.state == 'on' && stateObj.attributes.speed == 'medium') {
med = 'on';
} else if (stateObj.state == 'on' && stateObj.attributes.speed == 'medium_high') {
medHigh = 'on';
} else if (stateObj.state == 'on' && stateObj.attributes.speed == 'high') {
high = 'on';
} else {
offstate = 'on';
let lowcolor;
let medcolor;
let medhighcolor;
let hicolor;
let offcolor;
if (low == 'on') {
lowcolor = 'background-color: #43A047';
} else {
lowcolor = '';
if (med == 'on') {
medcolor = 'background-color: #43A047';
} else {
medcolor = '';
if (medHigh == 'on') {
medhighcolor = 'background-color: #43A047';
} else {
medhighcolor = '';
if (high == 'on') {
hicolor = 'background-color: #43A047';
} else {
hicolor = '';
if (offstate == 'on') {
//offcolor = 'background-color: #43A047';
offcolor = 'background-color: #f44c09';
} else {
offcolor = '';
_isOffState: stateObj.state == 'off',
_isOnLow: low === 'on',
_isOnMed: med === 'on',
_isOnMedHigh: medHigh === 'on',
_isOnHigh: high === 'on',
_lowOnColor: lowcolor,
_medOnColor: medcolor,
_medHighOnColor: medhighcolor,
_highOnColor: hicolor,
_offColor: offcolor
setSpeed(e) {
speed: speed
customElements.define('fan-control-entity-row-5-button', CustomFanCard);
I added the following script to āconfiguration.yamlā to make a stove work:
script:
thermorossi_velocita_1:
sequence:
- service: remote.send_command
entity_id: remote.telecomando_wifi_broadlink_remote
delay_secs: 2
command:
- b64: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
- b64: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
thermorossi_velocita_2:
sequence:
delay_secs: 2
command:
- b64: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
- b64: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
thermorossi_velocita_3:
sequence:
delay_secs: 2
command:
- b64: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
- b64: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
thermorossi_velocita_4:
sequence:
delay_secs: 2
command:
- b64: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
thermorossi_spegni:
sequence:
command:
- b64:scCwBOKeBgAaDg0ODhtEDhs3NjwINhwODQ4NHEQNGzc2Nw42Gw4ODg0bRA4bNzY3DTcbDg4NDhtEDhs3NjcNNxsODQ4OG0QOGzc2Nw03Gw4NDg0cRA4bNzY3DTcbDg0ODRxEDho3NjcONhwNDg4NHEMOGzc2Nw03Gw4NDg4bRA4bNzY3DTcbDg0ODhtEDhs3NjcNNxsODQ4NHEQOGzc2Nw03Gw0ODg0cQw8aNzY3DjcbDQ4ODRtEDhs3NjcONxoODg4NG0QOGzc2Nw03Gw4ODQ4bRA4bNzY3DTcOD4gODg4NHEMPGjc2Nw03Gw4ODg0bRA4bNzY3DTcbDg4NDhtEDhs3NjcNNxsODQ4NHEQOGzc2Nw03Gw0ODg0cQw8aNzc2DjcbDg0ODRtEDhs3NjcONhwNDg4NG0QOGzc2Nw03Gw4ODQ4bRA4bNzY3DTcbDg0ODhtEDhs3NjcNNxsODQ4NHEQOGjg2Ng43Gw0ODg0cQw8aNzY3DjcaDg4ODRtEDhs3NjcNNxsODg0OG0QOGzg1Nw03Gw4NDg0cRA4bNzY3DTcbDg0ODRxEDhs3NjYONxsNDg4NHEQOGjc2Nw42Gw4ODQ4bRA4bNzY3DjYbDg4NDhtEDhs3NjcNNxsODQ4OG0QOGzc2Nw03Gw4NDg0cRA4bNzY2DjcO84gODQ4NHEQOGzY3Nw03Gg8NDg0cRA4aNzc2DjYcDQ4NDhtEDhs3NjcONhsODg0OG0QOGzc2Nw03Gw4ODQ4bRA4bNzY3DTcbDg0ODhtEDhs2NzYONhwODQ4NHEQOGjc3Ng42HA0ODg0cQw8aNzY3DjYbDg4NDhtEDhs3NjcONhsODQ4OG0QOGzc2Nw03Gw4NDg4bRA4bNzY3DTcbDg0ODRxEDhs2NzYONhwNDg4NHEMPGjc2Nw42Gw4ODQ4bRA4bNzY3DjYbDg4ODRtEDhs3NjcNNxsODQ4OG0QOGzc2Nw03Gw4NDg0cRA4bNjc2DjcbDg0ODRxEDho3NzYONhsODg4NG0QPGjc2Nw42Gw4NDg4bRA4bNzY3DTcOD4gPDQ4NHEMPGjc3Ng42Gw4ODg0bRQ0bNzc2DjYbDg4NDhtEDhs3NjcNNxsODg0OG0QOGzc2Nw03Gw4NDg4bRA4bNjc3DTcbDg0ODRxEDho3NzYONhwNDg4NHEMOGzc2Nw42Gw4ODQ4bRA4bNzY3DTcbDg4NDhtEDhs3NjcNNxsODQ4OG0QOGzY3Nw03Gw4NDg0cRA4bNjc2DjYcDQ4ODRxDDxo3NjcONhsODg0OG0QOGzc2Nw42Gw4ODQ4bRA4bNzY3DTcbDg0ODhtEDhs3NjcNNxsODQ4OG0QOGzY3Ng43Gw0ODg0cQw4bNzY3DjYcDQ4ODRxDDhs4NTcONhsODg0OG0QOGzc2Nw03Gw4NDg4bRA4bNzY3DTcO84gODQ4OG0QOGzc2Nw03Gw4NDg0cRA4bNjc3DTcbDg0ODRxEDho3NjcONxsNDg4NG0QOGzc2Nw03Gw4ODQ4bRA4bNzY3DTcbDg0ODhtEDhs3NjcNNxsODQ4NHEQOGzc2Nw03Gw4NDg0cRA4aNzY3DjcbDg0ODRtEDhs3NjgNNxoODg0OG0QOGzc2NwAAAAAAAA==
I canāt figure out how I can link the various buttons to the script:
Low --> Thermorossi_velocita_1
Med --> Thermorossi_velocita_2
Hmi --> Thermorossi_velocita_3
High --> Thermorossi_velocita_4
Off --> Thermorossi_spegni
Can anyone help me?
hay bro
just wrote this
mite point you down the right path
Maybe it is a dumb question, maybe notā¦ but can I use this card for a Central Ventilation Unit (Itho CVE) with 3 speeds (no off setting)?
Itās been awhile since I visited this thread put I recently noticed a sh#t ton of errors that are apparently emanating from this resource in my log file as follows:
http://192.168.1.126:8123/local/fan-control-entity-row.js:191:25 Uncaught TypeError: Cannot read property āstateā of undefined
Is anyone else experiencing this? Any idea how to fix it?
I get those occassionally for some other entities but never my fan controls.
I believe itās only when you are restarting HA and not everything has completely initialized yet. Or I guess your devices could be dropping off HA and the entity will then be undefined.
If so itās not really something that I can control.
Does the control still work as expected?
It does work as expected, it just seems weird that I see over 250+ errors? Iāll keep an eye on it. Thanks for the quick response! Appreciate it!
disregard, answered above.
Is there a need to setup input_boolean entities in Helpers for this to work? Iāve used the code posted by @tscibilia and modified it for my 5 speed tuya fan. I have a fan template to do the service calls to the fan, which works fine. But the card doesnāt do anything when I click on any of the speed buttons.
Did you manage to fix it somehow?
I am at the same point as you.
