Lovelace: custom sidebar card
same thing here
Same Issue here. Is this a recent issue with one of the updates or is there something special we are meant to do?
i really don’t know
same problem here. @DBuit: Any solution?
I hope that @DBuit is doing well. He hasn’t been heard from here for a while and his Github repos are pretty inactive as well. Maybe/hopefully he just took some time off :slight_smile:
Seems the problem is somewhere in the firstUpdated() function?!
I love this idea, but being a NOOB I cant seem to figure out how to get this into my lovelace panel. I added with HACS so not sure how to confg the card, or if I’m not adding it right? Do I add a new card, then manual, or will I need to add something the the main RAW lovelace UI? Examples would be useful or any step by step process.
Thank you all.
Yes, you need to add it in the RAW lovelace UI
Dumb question, but what do I put and where in the lovelace config? This is what I put at the very top in the lovelace raw configuration editor and nothing changes
sidebar:
title: MyHome
date: true
clock: true
digitalClock: true
twelveHourVersion: true
hideTopMenu: true
showTopMenuOnMobile: true
width:
mobile: 0
tablet: 25
desktop: 20
title: Home
lovelace-background-image: >-
center / cover no-repeat
url("/local/R7f81ce29a09f47eb1dcf030dbafa317f.png")fixed
compact_mode: true
config:
hide_header: true
hideTopMenu is not working at the moment. See comments above
Still not working I tried an example listed on the GitHub just to see what it will do, but still does nothing and getting messages Your configuration is not valid: TypeError: Expected a value of type Array<Object> for views but received undefined. Would it be possible to supply more details for someone that does not know coding? Assume that I know noting.
sidebar:
  width:
    mobile: 0
    tablet: 25
    desktop: 20
and this
sidebar:
sidebarMenu:
- action: navigate
navigation_path: ā€œ/lovelace/homeā€
active: true
Hello Guys,
So i got an update :slight_smile:
It should fix the hideTopMenu, i also added hideHassSidebar when both are true you got no menu’s
If you wanna use the menu’s when this is enabled you can add ?sidebarOff to show the hidden menu’s
Thx for the update ! Will it also work now with multiple dashboards ?
I can’t get this right, even after the update. Topmenu is is stil there and it’s overlapping with sidebar, whatever I do:
sidebar:
  title: null
  clock: true
  digitalClock: true
  digitalClockWithSeconds: true
  date: true
  hideTopMenu: true
  width:
    mobile: 0
    tablet: 25
    desktop: 20
#  breakpoints:
#    mobile: 768
#    tablet: 1024
  sidebarMenu:
    - action: navigate
      navigation_path: "/lovelace/home"
      active: true
    - action: navigate
      navigation_path: "/lovelace/weather"
    - action: navigate
      navigation_path: "/lovelace/info"
    - action: navigate
      navigation_path: "/lovelace/electricity-sensors"
    - action: toggle
      entity: light.namron_cinema_dimmer
      state: light.namron_cinema_dimmer
      icon: mdi:lightbulb
  template: |
    <li>
      {% if now().hour  < 5 %} Good Night {{'\U0001F634'}}
      {% elif now().hour < 12 %} Good Morning {{'\u2615\uFE0F'}}
      {% elif now().hour < 18 %} Good Afternoon {{'\U0001F44B\U0001F3FB'}}
      {% else %} Good Evening {{'\U0001F44B\U0001F3FB'}}{% endif %}
    </li>
    {% if "i dag" in states('sensor.posten_next_delivery') %} <li>Mail delivery today!</li> {% endif %}
  bottomCard:
    type: horizontal-stack
    cardOptions:
      cards:
        - type: "custom:button-card"
          color_type: card
          color: rgb(255, 255, 255)
          icon: mdi:home
        - type: "custom:mini-graph-card"
          entities:
            - entity: sensor.real_time_consumption_xxxx
              #color: "#2D92F7"
          hours_to_show: 1
          points_per_hour: 60
          animate: true
          line_width: 3
          show:
            fill: true
            icon: true
            labels: true
            #extrema: true
            name_adaptive_color: true
            #state: true
          height: 150
          color_thresholds:
            - color: "#039BE5"
              value: 0
            - color: "#0da035"
              value: 1100
            - color: "#e0b400"
              value: 3200
            - color: "#e45e65"
              value: 6400
          color_thresholds_transition: smooth
          #color_thresholds:
          #  - value: 0.55
          #    color: "#2D92F7"
          #  - value: 0.9
          #    color: "#bf5f0b"
          #  - value: 1.3
          #    color: "#fc0505"
          hour24: true
          font_size: 100
          font_size_header: 16
          align_header: center
          align_state: center
    cardStyle: |
      :host {
        width: 100%;
        background-color:#FFF;
  style: |
    :host {
        --sidebar-background: 'rgba 50, 50, 50, .5';
        --sidebar-text-color: #B9B9B9;
        --face-color: 'rgba 50, 50, 50, .5';
        --face-border-color: 'rgb 84, 84, 84';
        --clock-hands-color: #000;
        --clock-seconds-hand-color: #216491;
        --clock-middle-background: 'rgb 4, 84, 84';
        --clock-middle-border: #000;
        --border-radius: 5px;
            .sidebarMenu li.active ha-icon {
        color: #d6b55a!important;
use this, works for me https://github.com/maykar/kiosk-mode
Is this broken for you since the update?
The bottom bar now does not go all the way to the bottom again
it never worked for me, that’s why I use kiosk-mode and still doesn’t work the TopMenu
Thanks, that is working for the topbar.
But still issues, have to force ctrl+f5 to load sidebar every time a page is loaded.
Bottom bar not showing at all…
I’ve only had to do the ctrl+F5 when moving to a different dashboard, the initially loaded dashboard always loads the sidebar. Try removing the clock or reducing its size, maybe it is pushing the bottom bar off the edge?
Hi, is there someone using transparent background or play with opacity, or is it impossible?
Cannot find a clear answer in the topic.
Thxs
