Ahh⊠no, but I have nowâŠ
It seems to be objecting to the states
âŠ
Error handling message: Unknown error
File "/usr/src/homeassistant/homeassistant/components/websocket_api/decorators.py", line 20, in _handle_async_response
await func(hass, connection, msg)
File "/usr/src/homeassistant/homeassistant/components/lovelace/__init__.py", line 187, in send_with_error_handling
result = await func(hass, connection, msg)
File "/usr/src/homeassistant/homeassistant/components/lovelace/__init__.py", line 212, in websocket_lovelace_config
return await hass.data[DOMAIN].async_load(msg["force"])
File "/usr/src/homeassistant/homeassistant/components/lovelace/__init__.py", line 145, in async_load
self._load_config, force
File "/usr/src/homeassistant/homeassistant/components/lovelace/__init__.py", line 164, in _load_config
config = load_yaml(fname)
File "/usr/src/homeassistant/homeassistant/util/yaml/loader.py", line 62, in load_yaml
return yaml.load(conf_file, Loader=SafeLineLoader) or OrderedDict()
File "/usr/local/lib/python3.7/site-packages/yaml/__init__.py", line 114, in load
return loader.get_single_data()
File "/usr/local/lib/python3.7/site-packages/yaml/constructor.py", line 43, in get_single_data
return self.construct_document(node)
File "/usr/local/lib/python3.7/site-packages/yaml/constructor.py", line 47, in construct_document
data = self.construct_object(node)
File "/usr/local/lib/python3.7/site-packages/yaml/constructor.py", line 92, in construct_object
data = constructor(self, node)
File "/usr/src/homeassistant/homeassistant/util/yaml/loader.py", line 196, in _ordered_dict
nodes = loader.construct_pairs(node)
File "/usr/local/lib/python3.7/site-packages/yaml/constructor.py", line 147, in construct_pairs
value = self.construct_object(value_node, deep=deep)
File "/usr/src/homeassistant/homeassistant/util/yaml/loader.py", line 227, in _construct_seq
(obj,) = loader.construct_yaml_seq(node)
File "/usr/local/lib/python3.7/site-packages/yaml/constructor.py", line 399, in construct_yaml_seq
data.extend(self.construct_sequence(node))
File "/usr/local/lib/python3.7/site-packages/yaml/constructor.py", line 122, in construct_sequence
for child in node.value]
File "/usr/local/lib/python3.7/site-packages/yaml/constructor.py", line 122, in <listcomp>
File "/config/custom_components/lovelace_gen/__init__.py", line 54, in _include_yaml
return loader._add_reference(load_yaml(fname, args), ldr, node)
File "/config/custom_components/lovelace_gen/__init__.py", line 37, in load_yaml
return loader.yaml.load(config_file, Loader=loader.SafeLineLoader) or OrderedDict()
File "/config/custom_components/lovelace_gen/__init__.py", line 32, in load_yaml
stream = io.StringIO(jinja.get_template(fname).render({**args, "_global": llgen_config}))
File "/usr/local/lib/python3.7/site-packages/jinja2/asyncsupport.py", line 76, in render
return original_render(self, *args, **kwargs)
File "/usr/local/lib/python3.7/site-packages/jinja2/environment.py", line 1008, in render
return self.environment.handle_exception(exc_info, True)
File "/usr/local/lib/python3.7/site-packages/jinja2/environment.py", line 780, in handle_exception
reraise(exc_type, exc_value, tb)
File "/usr/local/lib/python3.7/site-packages/jinja2/_compat.py", line 37, in reraise
raise value.with_traceback(tb)
File "/config/lovelace/includes/irrigation/zone_duration_line.yaml", line 27, in top-level template code
name: "{{ states('input_text.irrigation_zone1_name') }}"
jinja2.exceptions.UndefinedError: 'states' is undefined
