did you get any response on this? running in to the same issue myself.
thanks!
thanks!
Need help please. Here is self-contained snippet from one of dashboards that does not render as expected. What was expected is the cards each display the device, index j
, and name, index i
, based on their respective index values.
What actually happens is the entity is the right one, I have verified that by tapping on each of them to check info. But, the name displayed is always the first one. See picture below.
In this case the index values would be the same. But this is a simplified example to demo the issue in my real use case the value of i
would not be equal to j
Why is this not working and how can I make this work?
Thank you.
- square: false
type: grid
columns: 3
cards:
{% set i = -1 %}
{% set e = ['binary_sensor.dining_multisensor_motion_detection', 'binary_sensor.hue_motion_sensor_1_motion_2', 'binary_sensor.hue_motion_sensor_main_door_motion'] %}
{% set eN = ['Entity 1', 'Entity 2', 'Entity 3'] %}
{% for j in range(3) %}
{% set i = i + 1 %}
- type: custom:button-card
template: standard
entity: {{ e[j] }}
name: {{ eN[i] }}
styles:
icon:
- color: >
return (states['{{ e[j] }}'].state === 'on' ? 'red' : 'green');
tap_action:
action: more-info
{% endfor %}
@thomasloven || @petro since you both are the most prolific responders in this thread tagging you both for a solution to the issue in my post above.
Sorry about tagging you guys, but have spent hours trying to figure this one out, without any luck.
Any help would be much appreciated.
Thank you.
Is there any way to do a conditional based on an entities supported features? For example, I may want to format a card slightly differently based on whether a light supports brightness, color temp, etc.
I know itās pretty useless to be able to use state and attributes in general, but this is a static value, so Iām hoping thereās a chance?
I have a lovelace_gen configuration of ~2100 lines of code that gets expanded to >10000 lines of code - I use a lot of macros and for loops.
Is there a way to see the expanded code for debugging? I get an error on line 6798 but I donāt know what is really there.
you can just use j instead of i? if you want to add a name to an entity, they must be the same length lists, so not sure how j & i would ever be different.
I donāt know what happened but I just rebooted twice without lovelace trying to load before lovelace_gen
I am currently trying to change my frontend a little bit. As I am now working a lot with custom cards where it is not possible to use the ui editor I am trying to switch to the yaml mode. I saw lovelace_gen allows me to use jinja2 templates for my lovelace configuration.
So I tried it out.
So it seems like with this I can do a lot stuff but for now I am not able to print now().
Or I need a different syntax.
This is my smallest example which does not work:
# lovelace_gen
- title: Home
cards:
primary: '{{now()}}'
secondary: ''
icon: mdi:home
I am not sure if this does work with lovelace_gen. But how can I build a Dashboard with this values with lovelace_gen?
Is there also a safe way for other cards? I have one card where I want to include different cards in separated files:
quickinfo.yaml
quickinfo_licht.yaml
quickinfo_fenster.yaml
quickinfo.yaml:
# lovelace_gen
type: custom:swipe-card
card_width: auto
start_card: 1
reset_after: 10
cards:
!include 'quickinfo_licht.yaml'
!include 'quickinfo_fenster.yaml'
quickinfo_licht.yaml looks similar to this:
# lovelace_gen
- type: conditional
conditions:
- condition: screen
media_query: '(max-width: 600px)'
card:
type: custom:mushroom-template-card
tap_action:
action: navigate
navigation_path: licht
- type: conditional
conditions:
- condition: screen
card:
tap_action:
action: navigate
And quickinfo_fenster.yaml as well. So I have multiple files with a list of elements and I want to include them.
Or isnāt this possible at all? So do I have to include either all cards in one file or define one yaml per type and then i am able to include multiple files?
Banging my head against a wall for day. Need input from experts!
I am trying to pass the state of climate.porch_ac_windfree_3_0e
to the climate_device_state variable. But no-matter what I do, it doesnāt work. All works in the test markdown card shown below. But I canāt figure out a way of passing the result to the !include variable.
Please, pretty please, help! Iāve tried inline, indentation frenzies, filters ā all to no avail. It MUST be possible!
# lovelace_gen
{% set climate_entity = 'climate.porch_ac_windfree_3_0e' %}
{% set card_bg = card_bg or "var(--primary-background-color)" %}
{% set card_margin = card_margin or "12px auto 12px auto" %}
{% set ac_state_off = "off" %}
{%- macro offState() -%}
{%- raw -%}
{%- if (states({% endraw %}"{{climate_entity}}"){% raw %} == {% endraw %}"off"{% raw %}) -%}
{%- endraw -%}
{{"off"}}
{%- raw -%}
{%- else -%}
{%- endraw -%}
{{"on"}}
{%- raw -%}
{%- endif -%}
{%- endraw -%}
{%- endmacro -%}
type: custom:stack-in-card
group: true
card_mod:
style: |
ha-card {
max-width: 388px !important;
margin: {{card_margin}};
background: {{ card_bg }} !important;
padding: 8px;
cards:
- type: vertical-stack
cards:
- !include
- ../components/mini-climate.yaml
- entity: {{climate_entity}}
name: "Porch AC (Samsung)"
climate_device_state: "I AM STUCK"
buttons: ["cool", "heat", "auto"]
- type: markdown
title: "WTF"
content: |
"Hello from Markdown"
{% raw %}
So I can tell that my light is {{ states('climate.porch_ac_windfree_3_0e') }}!
{% endraw %}
{{offState()}}
raw
/endraw
keywords in my lovelace code. {% macro lightswitch(entity, x, y) -%}
- entity: {{entity}}
style: { left: {{x}}%, top: {{y}}%, width: 4% }
type: image
tap_action: {# action: toggle #}
action: call-service
service: script.zwave_switches_toggle
service_data:
entity: {{entity}}
hold_action: { action: more-info }
state_image: { 'off': /local/images/BulbOff.png, 'on': /local/images/BulbOn.png }
{%- endmacro %}
Then, apply your macro as follows:
{{ lightswitch('switch.front_porch_sconces', 65.0, 20.3 ) }}
which will render the result of the macro in your dashboard.
Caution: # lovelace_gen causes the custom:state-switch card not to render and to return Unknown Error on the Dashboard.
I did a super bad job of explaining my conundrum. Apologies. Your reply was educational though. Thank you.
Let me simplify with a different example.
I have included yaml file in my yaml dashboard for a climate-card that is fed by variables.
The !include, looks like this:
- !include
- entity: {{govee_entity}}
name: "Porch Space Heater"
buttons: ["heat", "auto", "swing", "presets"]
hvac_show_buttons: ["auto", "heat", "fan", "swing_mode", "custom_1"]
hvac_mode: {{govee_hvac_modes}}
indicators: {{govee_indicators}}
secondary_info: {"type": "fan-mode-dropdown"}
{# override defaults #}
hvac_auto: {"icon": "mdi:sun-snowflake-variant", "is_active": "auto",
"hvac_mode": "auto", "activeColor": "var(--state-climate-auto-color) !important"}
hvac_custom_1: {"type": "dropdown", "icon": "mdi:lightbulb",
"active": "(value !== '' && entity.attributes.nightlight == 'on')",
"state": {"attribute": "selected_scene"}, "activeColor": "var(--state-light-active-color) !important",
"source": {"off":"Light Off", "Coffee": "Coffee", "Sleep":"Sleep", "Warm": "Warm"},
"action": {"domain": "mqtt", "service": "publish",
"options": "{ topic: 'gv2mqtt/DB2A6074F445163C/set-mode-scene', payload: selected }"
Inside the included yaml file, we use the hvac_custom_1.source
variable like this:
source:
{{item.source}}
It works.
The rendered output (with the dropdown fed by hvac_custom_1.source
) is:
Now, instead of hard-coding that hvac_cutom_1.source
variable, I want to create the options, from an attribute of an entity:
I have an entity: climate.porch_spaceheater
. It has an attribute that looks like this (abbreviated):
nightlight_scenes:
- name: Reading
value: 1
- name: Movie
value: 2
- name: Work
value: 3
- name: Night Light
value: 4
- name: Party
value: 5
- name: Sports
value: 6
- name: Music
value: 7
- name: Warm
value: 8
To test my jinja to get the data from that attribute, I have created a āDebug Markdown Cardā in the dashboard yaml that looks like this:
- type: markdown
title: "Debug Markdown Zone"
content: |
{% raw %}
{% set scenes = state_attr('climate.porch_spaceheater', 'nightlight_scenes') | map(attribute='name')|list %}
{% set source = '[' ~ (scenes | map('regex_replace', '^(.*)$', '{ "\\1": "\\1" }') | join(", ")) ~ ']' %}
{{ source }}
{% endraw %}
It works. And outputs this (I know thatās a hairy xform, but it works!):
So, my question is how the heck do I get that {%raw%}ā¦{%endraw%} block to feed the source prop in hvac_custom_1.source
- !include: - ../..etc... - entity: .... hvac_custom_1: { ... "source": //STUFF FROM %RAW% %ENDRAW% GOES HERE! }
I have tried everything. doing it inline, creating a source
variable at the top of the file, creating a macro, but all to avail. I hope I explained this well enough, and hoping someone can teach me the way. If you need more info, please shout!
TIA.
Iām passing tap_action
into a custom:button-card
ātemplateā and it all works as expected.
(Note that it is not literally a button-card-template
but something I use as a template for button-card
using lovelace-gen
Iād like it to use a default tap_action
of toggle
when none is provided.
An illustaration:
Here is how I include the button ātemplateāā¦
- !include
- ../templates/button_on_off.yaml
- entity: binary_sensor.ld2410_presence
tap_action:
action: fire-dom-event
browser_mod:
service: browser_mod.popup
content:
type: entities
entities:
- entity: binary_sensor.ld2410_status
- more entities etc. etc....
And here is the (relevant parts of) button template itself (button_on_off.yaml
)ā¦
aspect_ratio: {{ aspect_ratio | default('1/1') }}
entity: {{ entity }}
name: {{ name }}
tap_action: {{ tap_action | default({'action': 'toggle'}) }}
Whatever I try with that tap_action
I cannot get the editor to approve the default
and nor will it work (I always tried, thinking it might just be a syntax format that the syntax checker couldnāt handle).
Just to be clear if I provide the tap_action
it works.
Iāve tried several variations and even ended up guessing a few.
Is it possible?
Yes, you need to return valid JSON, not a yaml dictionary.
Thanks, can you expand a little?
If the yaml I want to be the default tap_action
is
action: toggle
i.e.
tap_action:
action: toggle
the JSON for that is:
"action": "toggle"
So to pass that in I would use
As in my original example.
Which is obviously wrong.
What am I missing?
tap_action: {{ tap_action | default({'action': 'toggle'} | to_json) }}
Iām afraid that doesnāt workā¦
I wonder if lovelace_gen can handle the colon?
Whatās the error in the logs?
it might be tojson
No you were right first time.
There are no log messages, itās a dashboard.
The VS Code editor complains too.
It works in the template tools
