Lovelace - !include files
Thank you! This is the first time I see a fine explanation of Anchor usage…
Going to try and implement this. Lovelace and regular ( or is this called legacy meanwhile …) HA.
Oh, I’ve never heard of the anchors! That looks like what I’m looking to do. Is there more documentation on it? This looks to be exactly what I’m looking to do
I have a bit about them written down here: http://thomasloven.com/blog/2018/08/YAML-For-Nonprogrammers/
(The anchors: part in the code is just something I put in. It’s not really “supported” but it works.)
https://blog.daemonl.com/2016/02/yaml.html
I used that as a starting point,
Currently working on a remote control for Harmony using a picture-elements card and using anchors has cut down on the repetition a lot. Makes it much easier to tweak the style for all buttons.
  - type: picture-elements
    image: /local/images/short-empty.png?v2.2
    elements:
      - type: image
        entity: switch.lounge_tv
        tap_action:
          action: toggle
        image: /local/images/remote/tv.svg?v1
        state_filter:
          "on": invert(.5) sepia(1) saturate(8) hue-rotate(10deg)
        style: &style_anchor # Reuse these values with <<: *style_anchor in any style section
          top: 50%
          left: 20%
          width: 2em
          height: 2em
          padding: 15px
          background-color: var(--paper-item-icon-color)
          border-radius: 50%
          box-shadow: 0 3px 5px -1px rgba(0,0,0,.2), 0 6px 10px 0 rgba(0,0,0,.14), 0 1px 18px 0 rgba(0,0,0,.12)
      - type: image
        entity: switch.soundbar
        tap_action:
          action: toggle
        image: /local/images/remote/music.svg?v1
        state_filter:
        style:
          <<: *style_anchor
          top: 50%
          left: 50%
      - type: image
        entity: switch.ps3
        tap_action:
          action: toggle
        image: /local/images/remote/ps4.svg?v1
        state_filter:
        style:
          <<: *style_anchor
          top: 50%
          left: 80%
  # Display full remote when TV Activity is on
  - type: conditional
    conditions:
    - entity: switch.lounge_tv
      state: "on"
    card:
      image: /local/images/empty.png?v2.1
      elements:
      - type: image  # Menu
        tap_action:
          action: call-service
          service: remote.send_command
          service_data:
            entity_id: remote.lounge
            device: 29590173
            command: SmartHub
        image: /local/images/remote/menu.svg?v1
        style:
          <<: *style_anchor
          top: 10%
          left: 20%
      - type: image  # Exit
        tap_action:
          service_data:
            device: 29590173
            command: Exit
        image: /local/images/remote/cast.svg?v1
        style:
          <<: *style_anchor
          top: 10%
          left: 50%
      - type: image  # Back
        tap_action:
          service_data:
            device: 29590173
            command: Return
        image: /local/images/remote/back.svg?v1
        style:
          <<: *style_anchor
          top: 10%
          left: 80%
      - type: image  # Play
        tap_action:
          service: input_text.set_value
          service_data:
            entity_id: input_text.remote_command
            value: Play
        image: /local/images/remote/play.svg?v1
        style:
          <<: *style_anchor
          top: 26%
          left: 20%
      - type: image  # Pause
        tap_action:
          service_data:
            value: Pause
        image: /local/images/remote/pause.svg?v1
        style:
          <<: *style_anchor
          top: 26%
          left: 50%
      - type: image  # Stop
        entity: input_boolean.remote_stop
        tap_action:
          service_data:
            value: Stop
        image: /local/images/remote/stop.svg?v1
        style:
          <<: *style_anchor
          top: 26%
          left: 80%
      - type: image  # Up
        tap_action:
          service_data:
            device: 29590173
            command: DirectionUp
        image: /local/images/remote/up.svg?v1
        style:
          <<: *style_anchor
          top: 44%
          left: 50%
      - type: image  # Left
        tap_action:
          service_data:
            device: 29590173
            command: DirectionLeft
        image: /local/images/remote/left.svg?v1
        style:
          <<: *style_anchor
          top: 58%
          left: 32%
      - type: image  # OK
        tap_action:
          service_data:
            device: 29590173
            command: Select
        image: /local/images/remote/return.svg?v1
        style:
          <<: *style_anchor
          top: 58%
          left: 50%
      - type: image  # Right
        tap_action:
          service_data:
            device: 29590173
            command: DirectionRight
        image: /local/images/remote/right.svg?v1
        style:
          <<: *style_anchor
          top: 58%
          left: 68%
      - type: image  # Down
        tap_action:
          service_data:
            device: 29590173
            command: DirectionDown
        image: /local/images/remote/down.svg?v1
        style:
          <<: *style_anchor
          top: 72%
          left: 50%
      - type: image  # Volume Up
        tap_action:
          service_data:
            device: 29590173
            command: VolumeUp
        image: /local/images/remote/volup.svg?v1
        style:
          <<: *style_anchor
          top: 90%
          left: 80%
      - type: image  # Mute
        tap_action:
          service_data:
            device: 29590173
            command: Mute
        image: /local/images/remote/mute.svg?v1
        style:
          <<: *style_anchor
          top: 90%
          left: 50%
      - type: image  # Volume Down
        tap_action:
          service_data:
            device: 29590173
            command: VolumeDown
        image: /local/images/remote/voldown.svg?v1
        style:
          <<: *style_anchor
          top: 90%
          left: 20%
  # Display volume controls when Music / PS4 is on
  - type: conditional
    conditions:
    - entity: remote.lounge
      state: "on"
      state: "off"
    card:
      image: /local/images/short-empty.png?v2.1
      elements:
        tap_action:
          service_data:
            device: 29590173
            command: VolumeUp
        style:
          <<: *style_anchor
          top: 50%
          left: 80%
        tap_action:
          service_data:
            device: 29590173
            command: Mute
        style:
          <<: *style_anchor
          top: 50%
          left: 50%
        tap_action:
          service_data:
            device: 29590173
            command: VolumeDown
        style:
          <<: *style_anchor
          top: 50%
          left: 20%
It’s long enough as it is :slight_smile:
The problem is, although what I’ve posted works and (I believe) is valid yaml. HA complains about duplicate top: and left: keys. Fills the log :frowning:
using this syntax
<<: *style_anchor
is supposed to let you import the anchor and add / override values. As I say, it works but HA complains.
Just had a brief look at @thomasloven blog - going to have to read that article tomorrow when I am more awake and have drunk less rum. Might find a different way to define the anchor and remove the duplication. A brief look shows it’s a really good explanation.
please let me ask here, since you started it :wink:
i have 13 template sensors like this:
      friendly_name_template: >
        Attic:
        {% set lux = states('sensor.attic_motion_sensor_lux')|int %}
        {% if lux <= 1 %} moonlight
        {% elif lux <= 2 %} night light
        {% elif lux <= 10 %} dimmed light
        {% elif lux <= 50 %} 'cosy' living room
        {% elif lux <= 150 %} 'normal' non-task light
        {% elif lux <= 350 %} working / reading
        {% elif lux <= 700 %} inside daylight
        {% elif lux <= 2000 %} maximum to avoid glare
        {% elif lux <= 10000 %} clear daylight
        {% elif lux <= 120000 %} direct sunlight
        {% else %} too bright!
        {% endif %}
could I use an anchor to this bit:
        {% endif %}
I obviously need the name of the sensor in the first set, but the rest could be replaced?
would appreciate any hits for this!
You can use a trick I describe in that blogpost where you define and unpack an anchor at the same time. Something like
style:
  top: 50%
  left: 20%
  <<: &style_anchor
    width: 2em
    height: 2em
    ... etc ...
style:
  top: 50%
  left: 80%
  <<: *style_anchor
Afraid not, but you may be able to turn it into a macro.
I’m not sure which jinja2 features home assistant supports, but this might give you some idea of what might be possible.
Thank you, it worked :slight_smile:
This is great, but I’m probably not fully understanding. I’m looking at it as a potential way to have some reusable snippets in Lovelace yaml.
Here is my question. I want to take this state icon and have the entire tap action stored as a node anchor.
- type: state-icon
  tap_action:
    action: toggle
  hold_action: more-info
  entity: light.office_lamp_32
not working but desired example result
    ACTION_TOGGLE: &ACTION_TOGGLE
    tap_action:
       action: toggle
- type: state-icon
  <<: *ACTION_TOGGLE
The goal is to be able to have central snippets of similar controls to cut down on the duplication of lines. 2) How do I put the ACTION_TOGGLE in a single lovelace yaml file like a constants class
Appreciate the help, and all that you do for HA.
The definition of the anchor must be in the same file as and before any reference to it.
heya, was this ever addressed - i’m having the same issue (always need to edit ui_lovelace.yaml to enable a refresh to see my !included yaml lovelace views)
Nowadays I can use the refresh button in the ui (not the browser refresh).
yep, that works thank you!
Hello Marius
I hope you dont mind me asking, as I cant get this to work. I have a horizontal header, that is going in on every card. My main file looks, as far as I can see, the same as yours, but I expect I have the identation wrong in the include file, as Lovelace, keeps coming up saying “no card type configured”. If I paste the code from the header.yaml file directly into the waze.yaml file, it works.
waze.yaml
#---------------HEADER-------------------------------------------------------------------------------------
path: waze
background: center / cover no-repeat url("/local/lovelace/dark_ripple.png") fixed
title: waze
panel: true
cards:
- type: vertical-stack
  cards:
    - !include header.yaml
    - type: horizontal-stack
      cards:
        - type: custom:card-modder
          style:
            --paper-card-background-color: rgba(0, 0, 0, 0.5)
            --paper-item-icon-color: white
            border-radius: 5px
            color: rgb(137, 193, 137)
          card:
            type: custom:waze-card
            entities:
              - entity: sensor.waze_louise
              - entity: sensor.waze_eltel_herlev
              - entity: sensor.waze_eltel_vejle
              - entity: sensor.waze_region_sjaelland
              - entity: sensor.waze_sjaellands_odde
header.yaml
      cards:
          style:
            border-radius: 5px
            height: 100px
            color: rgb(255, 255, 255)
            report_size: 5
          card:
            type: "custom:clock-card"
        - type: "custom:button-card"
          icon: mdi:food-variant
          show_label: false
          color: auto
          tap_action:
            action: navigate
            navigation_path: /lovelace/kokken
          styles:
            card:
              - height: 100px
              - width: 100px
              - background-color: rgba(0, 0, 0, 0.5)
          icon: mdi:volume-high
          show_label: false
          color: auto
          tap_action:
            action: navigate
            navigation_path: /lovelace/musik_volume
          styles:
            card:
              - height: 100px
              - width: 100px
Regards Michael
think the issue is that in fact you use two dashes now (-). the first in the calling file with the !include header.yaml, and the second in the included file.
Your include file should have all aligned left, without indent and dash on the type: horizontal-stack.
Jumping in late here…
But is there any way to combine the use of anchors and includes?
As far as I understand, and anchor currently needs to be defined in the same file as it is used. This greatly reduces the usability, as I would love to have my lovelace-config split up in nice blocks, while still having most common settings in one place.
title: Foo Title
common: !include lovelace/common.yaml
  - !include lovelace/view_page_1.yaml
  - !include lovelace/view_page_2.yaml
And in common.yaml:
color1: &blue '#0000ff'
color2: &cyan '#00ffff'
If I need to define all the stuff in all the included files, it does not really help that much in case I want to modify things consistantly in all the views.
take a look at loevlace_gen.
Hi, guys. I need an advice. I’m using non-YAML Lovelave and want to build a second Dasboard for the tablet.
Everything is going fine until I want to use !include tag.
# YAMLException: unknown tag !<!include> message was returned.
this is the piece of code
          - type: icon
            icon: bha:roborock
            title: Vacuum CLeaner
            style:
              top: 87.41%
              left: 4.8%
              color: rgba(255, 255, 255, 0.10)
              padding: 0.8vw
              --iron-icon-height: 4vw
              --iron-icon-width: 4vw
            tap_action: !include popup/sidebar_vacuum.yaml
sidebar_vacuum.yaml is created.
I installed levelace_gen and I switched to yaml mode, but the results were unchanged
What can I do?
Does anyone know if it’s possible to combine multiple cards (but not a whole view) into a file using !include? I have a view that’s getting too big for one file, but I don’t want to make files for each card either… I’d like to split the view into 2-3 files, each with multiple cards… What do you think, is there a way to do this?
