Sure - It’s fairly simple stuff though:
The theme is not mine - I found it somewhere on the forum. Also, I’m now using the Lovelace UI editor to do everything frontend. Just for clarity, I don’t use custom cards as these do not work on my Kindle fire 7 tablet which I use as my primary interface in the house.
dark_theme:
# Main colors
primary-color: '#383C45' # Header
accent-color: '#5eb3e4' # Accent color
dark-primary-color: 'var(--accent-color)' # Hyperlinks
light-primary-color: 'var(--accent-color)' # Horizontal line in about
# Text colors
primary-text-color: '#b8b8b8' # Primary text colour, here is referencing dark-primary-color was #fff
text-primary-color: 'var(--primary-text-color)' # Primary text colour
secondary-text-color: '#5294E2' # For secondary titles in more info boxes etc.
disabled-text-color: '#7F848E' # Disabled text colour
label-badge-border-color: 'green' # Label badge border, just a reference value
# Background colors
primary-background-color: '#383C45' # Settings background
secondary-background-color: '#383C45' # Main card UI background
divider-color: 'rgba(0, 0, 0, .12)' # Divider
# Table rows
table-row-background-color: '#353840' # Table row
table-row-alternative-background-color: '#3E424B' # Table row alternative
# Nav Menu
paper-listbox-color: 'var(--primary-color)' # Navigation menu selection hoover
paper-listbox-background-color: '#2E333A' # Navigation menu background
paper-grey-50: 'var(--primary-text-color)'
paper-grey-200: '#414A59' # Navigation menu selection
# Paper card
paper-card-header-color: 'var(--accent-color)' # Card header text colour
paper-card-background-color: '#434954' # Card background colour
paper-dialog-background-color: '#434954' # Card dialog background colour
paper-item-icon-color: 'var(--primary-text-color)' # Icon color
paper-item-icon-active-color: '#F9C536' # Icon color active
paper-item-icon_-_color: 'green'
paper-item-selected_-_background-color: '#434954' # Popup item select
paper-tabs-selection-bar-color: 'green'
# Labels
label-badge-red: 'var(--accent-color)' # References the brand colour label badge border
label-badge-text-color: 'var(--primary-text-color)' # Now same as label badge border but that's a matter of taste
label-badge-background-color: '#2E333A' # Same, but can also be set to transparent here
# Switches
paper-toggle-button-checked-button-color: 'var(--accent-color)'
paper-toggle-button-checked-bar-color: 'var(--accent-color)'
paper-toggle-button-checked-ink-color: 'var(--accent-color)'
paper-toggle-button-unchecked-button-color: 'var(--disabled-text-color)'
paper-toggle-button-unchecked-bar-color: 'var(--disabled-text-color)'
paper-toggle-button-unchecked-ink-color: 'var(--disabled-text-color)'
# Sliders
paper-slider-knob-color: 'var(--accent-color)'
paper-slider-knob-start-color: 'var(--accent-color)'
paper-slider-pin-color: 'var(--accent-color)'
paper-slider-active-color: 'var(--accent-color)'
paper-slider-container-color: 'linear-gradient(var(--primary-background-color), var(--secondary-background-color)) no-repeat'
paper-slider-secondary-color: 'var(--secondary-background-color)'
paper-slider-disabled-active-color: 'var(--disabled-text-color)'
paper-slider-disabled-secondary-color: 'var(--disabled-text-color)'
# Google colors
google-red-500: '#E45E65'
google-green-500: '#39E949'
##The following is my lovelace config for the first card:
title: My House
- background: center / cover no-repeat url("/local/background_light2.jpg")
badges: []
cards:
- cards:
- cards:
- entities:
- entity: group.lounge
- entity: group.kitchen
- entity: group.hall_downstairs
icon: 'mdi:stairs'
name: Hall Downstairs
- entity: group.downstairs_toilet
icon: 'mdi:toilet'
- entity: group.outside
- name: Heating
type: section
- entity: switch.boiler_bot
service: light.toggle
show_header_toggle: false
theme: dark_theme
title: Downstairs
type: entities
- entities:
- entity: group.master_bedroom
- entity: group.erins_bedroom
- entity: group.hall_upstairs
icon: 'mdi:stairs'
- entity: group.clares_office
icon: 'mdi:desk-lamp'
- entity: group.ensuite
icon: 'mdi:toilet'
theme: dark_theme
title: Upstairs
type: entities
type: horizontal-stack
type: vertical-stack
- cards:
- cards:
- entity: script.good_morning
icon: 'mdi:weather-sunset-up'
tap_action:
action: call-service
service: script.turn_on
service_data:
entity_id: script.good_morning
theme: dark_theme_lighter_card
type: entity-button
- entity: script.home_mode_day
icon: 'mdi:weather-sunset-down'
tap_action:
service_data:
entity_id: script.home_mode_day
type: entity-button
- entity: script.night_night
icon: 'mdi:weather-night'
tap_action:
service_data:
entity_id: script.night_night
type: entity-button
- cards:
- cards:
- entity: script.night_time_panic
hold_action:
action: more-info
icon: 'mdi:shield-remove-outline'
tap_action:
action: toggle
theme: dark_theme_pink_icons
type: entity-button
- entity: alarm_control_panel.ha_alarm
tap_action:
action: navigate
navigation_path: /lovelace/2
theme: dark_theme
type: entity-button
- entity: script.earlybird
hold_action: more-info
icon: 'mdi:alarm'
tap_action:
action: toggle
theme: dark_theme
type: entity-button
- cards:
- entities:
- entity: input_boolean.martin_occupancy
icon: 'mdi:account-circle'
show_state: true
tap_action:
action: toggle
theme: dark_theme
type: glance
- entity: sensor.house_temperature
graph: line
theme: dark_theme
type: sensor
- entity: sensor.simple_time_date
icon: 'mdi:clock'
theme: dark_theme
type: sensor
icon: 'mdi:home'
theme: dark_theme
title: Home
