Lovelace Lightning Detector Card for AS3935
This Lovelace card for Home Assistant displays lightning detections from you own inexpensive AS3935 Lightning Detection Sensor.
Install the sensor interface script the Raspberry Pi connected to your AS3935 sensor board.
Live Cards
GitHub: The card: Lovelace Lightning Detector Card shows data reported by your sensor.
GitHub: The Sensor Script lightning-detector-MQTT2HA-Daemon interfaces with the AS3935 sensor on your RPi and sends the accumulated data via MQTT to your HA installation.
Links to videos showing detections: (pls, pardon the lack of sound on the videos)
Can this be made to work with other lightning sensors that have direction, range and count (no kA)?
As of this moment, one would have to adapt my lightning-detector-MQTT2HA-Daemon script to pull data from one of those services, accumulate it as needed for this card, and then send the data to the card. It can be done. I’m writing a document which I’ll add to that same repo detailing how the data accumulated and what is sent to the card and why. With this document in hand (again, coming soon) it wouldn’t be a difficult task to make an adapter to feed this card.
I’ll post here to let you know when the new document has arrived and how to get to it.
this is awesome! i have one of these but have been trying to figure out how to just use it with an ESP rather than RPi. just haven’t had time!
OK, the new document is in the REPO for the MQTT Daemon (since it does the sending to the card.)
See: https://github.com/ironsheep/lightning-detector-MQTT2HA-Daemon/blob/974d7c4e300a99afac39cd0627c910aff6d4ef4e/THEOPS.md
This should help with the “how to…” portion of the problem…
I just got my sparkfun as3935 lightning detector, but I am struggling to get it to work.
It seems to be a newer hardware version with i2c unsupported by default, but still being able to activate by “switching” two jumpers.
https://learn.sparkfun.com/tutorials/sparkfun-as3935-lightning-detector-hookup-guide-v20
I cut SE and connected CS and connected the right one of i2c PU, ADR unchanged.
correct?
it does show up now:
 sudo i2cdetect -y 1
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          03 -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
but the script gives me an error:
python3 /opt/ISP-lightning-mqtt-daemon/ISP-lightning-mqtt-daemon.py
  File "/opt/ISP-lightning-mqtt-daemon/ISP-lightning-mqtt-daemon.py", line 174, in <module>
    i2c_address = int(config['Sensor'].get('i2c_address', default_i2c_address))
ValueError: invalid literal for int() with base 10: '0x03'
i2c_address needs to be in decimal, not hexadecimal. So set it to "3"
@Fugazzy, @lightmaster is correct. My example in the config.ini.dist uses the 0x prefix but should not!
Why not add a check to the script to accept both decimal and hex, and convert to whichever the script already uses?
Could someone please post a wire diagram of how the AS3935 is connected to the pi I think I have mine right but not sure. Thank you
Is the table in the README sufficient or do you need something more? See: https://github.com/ironsheep/lightning-detector-MQTT2HA-Daemon#connecting-the-as3935-to-your-raspberry-pi
I’m a visual person so sometimes I’m dumb :slight_smile: Here is how mine is currently connected
This is what my mqtt output looks like.
“settings”: {
“timestamp”: “2020-08-30T02:14:19-04:00”,
“hardware”: {
“min_strikes”: 5,
“afe_inside”: true,
“disp_lco”: false,
“noise_floor”: 1
“script”: {
“period_minutes”: 5,
“end_minutes”: 60,
“number_rings”: 5,
“distance_units”: “mi”
I got my system up and running, that means I see the entities in my homeassistant,
But I am not sure if the sensor itself is working correct?
Manually starting the script I do get a lot these outputs:
[2020-08-30 23:10:30] << INTR(17) >> Noise level too high - adjusting
Is that normal?
@Fugazzy there are a number of things to look at here… make sure your sensor is away from your RPi as far as it can be. Move your RPi and sensor away from other electrical equipment, etc.
Also, new in the latest version of the script there’s an Antenna fine tuning feature so you can better dial-in your detector board.
GitHub: The Sensor Script lightning-detector-MQTT2HA-Daemon :
  • NOW Supports SPI connections to AS3935
  • Has new feature for automatic determination of Antenna Fine-tuning value
See the README at the repo!
Hello
I have a different lightning detector.
I would like to know if it is compatible.
Greetings Andre
The post directly above yours says:
This is your sensor.
Hello Tom
Yes that is my sensor.
Would that work for me on the project?
greetings
André
That’s what the word “supports” means, yes.
