IMHO the situation is strange.
Yes, this HA version has some issues with Recorder, history-graph & Logbook.
From other side, it is strange that - w/o any reboots - history-graph
shows SOMETHING and mini-graph-card
does NOT.
Whose fault it is? Bugs in HA? Or mini-graph-card
is just NOT ADAPTED to some new requirements, I don’t know…
Then it is strange that rebooting HA (all-in-one) could not help.
I agree. I don’t remember if I just restarted HA or restarted the Container. This time I rebooted the host.
Btw, correct your code:
extrema: true
is used inside “show
” option.
index: 0
is not a supported option.
And consider either closing your issue or commenting about your current status & possible reasons.
OK, thanks.
Only after the third restart did it somehow be fixed.
The question is what is wrong and how long it will last
Do not know… Myself experienced some issues with history-graph
. The glitch came after some time after restart and gone after next restart.
I have a stupid question: I see peoples’ examples and they show the world MIN and MAX but I don’t know how to show these in my card? I see the code and I can’t find it so I’m confused. I will continue to play but if I am missing something basic (which I am sure I am) can you point me in the right direction?
Thanks!
Neil
show:
extrema: true
Thank you! I don’t know how or why but I popped up after I checked your recommendation! Thanks!
Maybe related.
I have a nice-looking card at the minute but want it to show the time of the next high/ low tide.
Would be great if I can show the data points on the peaks, or combine these to have a single graph with the visible time. Something in the top right that shows the next high/low tide.
Any help on here would be great
type: custom:stack-in-card
keep:
margin: false
box_shadow: false
background: false
cards:
- type: grid
square: false
columns: 2
cards:
style: |
ha-card {
padding-bottom: 1px !important;
primary: Filey Tides
icon: mdi:waves
icon_color: blue
tap_action: none
- type: custom:mushroom-chips-card
style: |
ha-card {
--chip-box-shadow: none;
--chip-background: none;
alignment: left
style: |
ha-card {
alignment: left
chips:
- type: template
double_tap_action:
action: none
content: State - {{ states(entity) }}
entity: sensor.filey_tide
icon: |
{% if is_state("sensor.filey_tide", "Falling") %}
mdi:arrow-down-thin
{% else %}
mdi:arrow-up-thin
{% endif %}
icon_color: red
tap_action:
action: none
hold_action:
action: none
- type: custom:mini-graph-card
entities:
- entity: sensor.filey_tide
attribute: next_high_tide_in
color: '#2196f3'
attribute: next_low_tide_in
color: '#f44336'
hours_to_show: 24
line_width: 3
font_size: 50
animate: true
show:
icon: false
state: false
legend: true
fill: fade
labels: true
hour24: true
Can you please share the code for these cards?
Hello at all, I think I don’t unterstand the feature of an input_number helper for displaying night and day ? maybe you can explain how to get this nice desing online ?
Wouldn’t it be a good idea to allow a setting for maybe
show_daynight: true
show_daycoloer: #42344 (ex.)
show_nightcolor: #98644 (ex.)
to get this bars dynamic drawn ?
Greetings from austria
Kilowatt
Quick question. How can I show 2 values in a mini-graph. One aligned to the left and one aligned to the right?
Just specify 2 entities (take any example from here) - automatically one state will be on the left, another - on the right.
What are you using to do your speed test can you share your code?
Speedtest integration!
Hi All, just starting out to use mini graph and working through the examples, just wondering if anyone can share how I can set the temp and humidity within the “style” to change color based on state? Would I also be able to use 2 different ranges? one for temp and the other for humidity.
entities:
- entity: sensor.mbr_heatindex
show_line: false
show_points: false
show_legend: false
state_adaptive_color: true
- entity: sensor.rm4mini_temperature_round
show_line: false
show_points: false
show_legend: false
- entity: sensor.rm4mini_humidity_round
show_line: false
show_points: false
show_legend: false
y_axis: secondary
decimals: 1
hours_to_show: 72
points_per_hour: 6
icon: ' '
icon_adaptive_color: true
line_width: 1
color_thresholds:
- value: 20
color: '#f39c12'
- value: 30
color: '#d35400'
- value: 40
color: '#c0392b'
show:
labels: false
labels_secondary: false
style: |
ha-card .states.flex::after {
content: "{{states('sensor.rm4mini_temperature_round')}} °C \A {{states('sensor.rm4mini_humidity_round')}} %";
white-space: pre;
background-color: rgba(80,80,80,0.1);
padding: 5px 5px 5px 5px;
border-radius: 5px;
