You cannot display raw data, but can reduce interpolation:
aggregate_func: last
points_per_hour: equal to a real scan_interval
smoothing: false
And surely this is not for bar graph.
HelloâŚ
i have a questionâŚ
Iâd like to have just the max value on every day⌠Is this possible?
Iâd like to format the displayed extrema values. No need for time and date. Possible to remove this?
Thanks so far
Use search here for âcard-modâ keyword.
Use the aggregate and group by settings as in the docs.
aggregate_func: max
group_by: date
Already in my code:
type: custom:mini-graph-card
entities:
- entity: sensor.sma_device_daily_yield
hours_to_show: 168
aggregate_func: max
group_by: date
name: Produktion Solarstrom
show:
graph: bar
extrema: true
labels: true
50+ results⌠any keyword more for what to look?
card-mod extrema
Search MY posts - you will find a huge post for styling the card.
Or go to card-mod thread â 1st post â link at the bottom â styles for mini-graph-card.
Puh thats too much for me.
Canât get this even to change color. Display: none is also not working
Also to display the daily values inside the bars i have no idea. I think i need to study this
Another way is to use the delta function if you have a summation delivered on your electricity meters, or you have a Riemann sum. You will get a daily usage breakdown then as it will minus todayâs value with yesterdayâs
So i was trying to make a graph that has both the humidity and the temperture on it and that has the color thresholds has well. Is it possible ? because when i put theme on the same graph the color fonction is not taken into consideration
Thaks for you help
HI all,
I have three entities in my graph card, temp, humidity and battery, but there is only one thermometer icon and there is not really a visible difference between the other entities.
Is there a way to add extra icons with the other entities, at the places of the arrows in the image?
is there a hint to get the graph away from the card border? I want to have a little free area and not the lines till the border line?
Thanks, Steffen
Imitating statistics card:
Code
entities:
- entity: sensor.xxx
aggregate_func: max
color: lightblue
aggregate_func: median
color: blue
show_fill: false
aggregate_func: min
color: lightblue
card_mod:
style: |
mask:nth-of-type(2) .fill {
opacity: 1 !important;
animation: none;
.fill--rect:nth-of-type(2) {
fill: var(--card-background-color);
Note: take into account this issue - [bug] min/max/avg values are wrong for the graph start (before first point).
Hi all.
Maybe Iâm doing something wrong but I canât figure out what.
I have a graph with a temperature from a Netatmo Valvle
The current and desired temperatures work well.
I want to add the indication about on\off of the valve.
I have create a sensor for the state (idle and heat) and a binary_sensor to mapping idle\heat of sensor in on\off value.
You can see the state on the history below the graph, but I donât see the state of sensor on graph.
In the image, the yellow line in bottom indicate the sensor, but all with the same colors.
This is my code.
entities:
- entity: climate.bagno
attribute: current_temperature
attribute: temperature
- entity: binary_sensor.stato_valvola_bagno_onoff
color: yellow
unit: ''
show_state: false
show_indicator: false
show_graph: true
show_line: false
show_fill: true
show_points: false
show_legend: false
state_adaptive_color: false
fixed_value: false
aggregate_func: min
y_axis: secondary
smoothing: true
show:
labels: true
labels_secondary: true
state_map:
- value: 'off'
label: 'Off'
- value: 'on'
label: 'On'
If I add the points_per_hour: 10 to code, I have this result.
I see the off\on state, but the graph is âsquaredâ
Can you help me?
Should be at least the same as the biggest update interval of displayed sensors.
I usually set it to at least 60 (every minute) to reduce an interpolation effect.
âSquared graphâ - create a history-graph and compare.
I have setting points_per_hour: 60 but the result is similar.
The historical and the mini-chart have an identical trend, but I donât like the âSquared graphâ, but the on\off state appears only on this graph type.
Iâm probably doing something wrong
I more or less understood how it works.
Unfortunately points_for_hour works on all lines the same way.
The problem is that binary_sensor only have 2 states and go from 0 to 1 immediately, the temperature, for example, no, the movement is gradual. Combining the two doesnât seem possible.
You have either only âsquaredâ and in this case the binary_sensor are correctly display
or only âcurvilinearâ graphics which are not good for on / off.
Unclear what you call a âsquare graphâ.
Check this and tell what is a more precise graph for a sensor updating every 30 sec:
type: vertical-stack
cards:
- type: history-graph
entities:
- entity: sensor.xiaomi_cg_1_pm25
hours_to_show: 1
- type: custom:mini-graph-card
entities:
hours_to_show: 1
entities:
hours_to_show: 1
points_per_hour: 5
line_width: 1
entities:
hours_to_show: 1
points_per_hour: 120
line_width: 1
entities:
hours_to_show: 1
line_width: 1
smoothing: false
People are battling about â2022.11 shows statistical data in more-info - i.e. not precise data, instead of precise history-graphâ - and even this âgreat improvementâ has itâs adepts.
Itâs clear.
It is clear, but perhaps I have explained myself badly.
The classic graph is the broken line or âinterpolate lineâ, but, for certain type of infomation (temperature for example), the âcubic interpolateâ or âakima interpolateâ, like this.
itâs just a matter of âvisual fulfillmentâ
I see your point.
Currently there are options like âsmoothingâ, âpoints_per_hourâ, âaggregate_funcâ which are related to a presentation. Only the âaggregate_funcâ option may be defined per entity; others are global.
Probably at least the âsmoothingâ option could be changed to per entity too. Please create an issue (FR) for this on GitHub if you are interested.
As for âpoints_per_hourâ - I do not see myself any scenarios where it may be different per entity. But anyway - you may create an issue for this option too and please describe cases where it may be useful.
Meanwhile - try to use these options:
smoothing: true (since you like smooth curves),
points_per_hour - define big value like 60 (or even 120) - then probably binary curve will be âsquare-ishâ (as it should be), sensor curve will be âcurvedâ.
BTW - since you have âstate_mapâ for ONE graph, your browserâs log (in code inspector) is full of errors. Check Github for a related issues (this, this) - also see my workaround with using a sensor â0 / 1â instead of âoff /onâ.
