Lovelace: mini graph card
how to make sure that the gray fill graph for displaying day and night does not disappear ?
Mini-Graph
wondering if someone can help me remove the rounded corners and the shadow. The card is inside a swiper card
type: custom:swipe-card
parameters:
  spaceBetween: 8
  scrollbar:
    hide: true
    draggable: true
    snapOnRelease: true
cards:
  - type: custom:mini-graph-card
    entities:
      - sensor.beaus_bedroom_average_temperature
    line_width: 2
    line_color: blue
    font_size_header: 10
    show:
      icon: true
      state: false
This really triggers my OCD…
I am having some trouble with a mini graph. I have a mini graph for my washer and my dryer. Here is the code for the washer.
entities:
  - entity: input_select.washer
    color: 'rgb(255,0,0)'
    show_legend: true
    show_line: false
    show_fill: true
  - entity: sensor.basement_aqara_washer_active_power
    color: '#3182b7'
    show_fill: true
    show_legend: false
    y_axis: secondary
line_width: 1
decimals: 0
hours_to_show: 24
points_per_hour: 60
hour24: true
lower_bound_secondary: 0
upper_bound_secondary: 500
state_map:
  - value: Empty
    label: Empty
  - value: Complete
    label: Complete
  - value: Running
    label: Running
show:
  state: false
  points: false
  icon: false
  extrema: false
  labels: false
  labels_secondary: false
card_mod:
  style: |
    ha-card {
      --ha-card-background: rgba(115, 115, 115, 0.25);
      --primary-text-color: '#97989c';
      border-radius: 10px;
      border: none;
    .graph__legend__item:nth-of-type(1) .ellipsis:after {
      content: ": {{states('input_select.washer')}}";
      color: '#97989c';
    .graph .graph__legend {
      font-size: 15px;
I have it in a stack-in-card with the dryer as seen below.
As you can see in my code, I am trying to have the legend at the top for the washer and dryer that shows the state of the input_select helper for each. No matter what I try though, it will not show up. Is it not possible to show the state of an Input_select helper or is there an error in my code that I am missing? Any help would be greatly appreciated. Thanks in advance.
I would say - you are a happy man & live in a healthy & peaceful society.
sorry for the maybe trivial question, I’m new to this card and to customization in general. Is there a way to get the colour gradient not on absolute thresholds but instead on percentages of the shown data?
Like top 75% of the graph is always red, bottom 25% green, middle 25-75% orange?
Thanks,
-E-
Unsupported.
MAY BE try adding a gradient mask by card-mod.
Hey,
it is posoble to reduce the gabs?
416037685_7310432232334376_8394963742747464180_n
Card Mod is installed, but i have no idear.
big Thanks Andi
I’m no CSS expert but I can give it a try. Thanks for the prompt response.
Can anyone help with showing the legend for the input-select helpers?
What is the best way to deal with NaN values? I can make myself a template sensor that returns zero instead of NaN, but that screws up other cards that have proper handling of NaN values.
Example: I have a machine connected to a Vodafone gateway that is somewhat unstable. So I have a binary ping sensor with a state attribute that gives me the ping time to Vodafone’s gateway and to Google’s DNS. When the connection is down, the ping time goes to NaN. HA’s built-in history and statistics graph cards draw an interrupted line in that case:
Mini-graph-card, on the other hand, continues the graph with the last value:
entities:
  - entity: binary_sensor.ping_vodafone
    attribute: round_trip_time_avg
    aggregate_func: last
    name: Vodafone 91.64.45.254 (last)
    color: red
    show_line: false
    show_legend: false
    attribute: round_trip_time_max
    aggregate_func: max
    name: Vodafone 91.64.45.254 (max)
    color: red
    show_state: false
  - entity: binary_sensor.ping_google_dns
    name: Google 8.8.8.8 (last)
    color: blue
    show_line: false
    show_legend: false
    show_state: true
    aggregate_func: max
    name: Google 8.8.8.8 (max)
    color: blue
    show_state: false
    color: orange
    show_line: false
    show_points: false
    show_legend: false
    show_state: false
    y_axis: secondary
show:
  labels: true
  extrema: false
  points: false
  fill: fade
state_map:
  - value: 'off'
    label: Nicht erreichbar
  - value: 'on'
    label: Erreichbar
name: Ping Vodafone & Google (1 Stunde)
icon: mdi:speedometer
line_color: orange
line_width: 1
font_size: 75
hours_to_show: 1
points_per_hour: 240
This is obviously undesirable, because the continuous graph makes it seem that ping is working when it’s obviously not. So what better way to handle NaN situations?
If some entity is unavailable / unknown within some period - history-graph shows gaps. Mini-graph shows a flatline. You cannot change it. There is an open FR in Github for this.
OK, thanks. So I made myself a template sensor that returns a ping time of 0 if the ping is unavailable, it’s not really optimal but at least it’s visually clear.
Is there a way for the secondary y-axis label to ignore one of the secondary y-axis? I have the temperature as primary then humidity and night state as 0 (day time) or 100 (night time) on the secondary. I want to ignore the day/night values for the labs because it will just show the min as 0 and max 100 and I want to see the humidity instead.
Each entity is either primary or secondary axis.
If you look at the lower right hand side, if I enable the secondary label, the max shows as 100 instead of the highest humidity because the night state is either 0 when it’s day or 100 when it’s night. Though I’m not sure why the min is showing as 53 instead of 0 which I assumed will be the case.
Edit: I figured out why it was showing 53. I put a lower bound on the secondary.
There is no sense to use same axis for values with diff nature.
Yeah but this is the only way I can think of to get a graph with temperature, humidity, and night state. Do you have a suggestion on how to accomplish the similar graph with a different approach?
I’ve had to do something similar. The best you can do in that case is to make the night sensor numeric, set its on and off to the min and max of one of your sensors (humidity, in this case, since it has boundaries) and display it on the same axis.
EDIT: Doesn’t seem like I still have that, unfortunately.
The only way to have 3-axis graph - placing 2-axis graph above 1-axis graph. Rather tricky.
