I am not 100% sure on how it exactly works, maybe the user still cache it but the system send a new tag for it when there is an updated version? That would make lot of sense and is actually how the caching layers do work
Any possible way to do the following?
- Adjust height of the card. I have a bunch of temperature sensors that I want to view, but I have to scroll a lot now. If I could shrink the height of the card, that would help.
- Have 2 labels on card. If I have 2 sensors (temp, humidity), and want to see the current value with the big bold number on the card, Iâd like to have temperature readout on the left side of the card, and maybe humidity on the right side. Currently, we can have multiple sensors per card, but only one big number shows.
Hi, you can use:
height to adjust the height, default is 150
For the second bit you add on each identity that you want to see the value on the top:
show_state: true
Technically, is always true for the first identity, so you can add it on the second (the second will be showen on the right side)
Example:
Let me know
Thanks! That definitely helps. Any suggestions on the graph? Individually, the graphs look good when the sensors change, but once put together since the numbers (temp/humidity) are vastly different, they are pretty much flat. Is there a specific way I should be configuring the axis to display it better? or is it just the downfall with the 2 sensors im putting into each box?
Also, the moment I add the height info to all of the cards, I now get a vertical scroll bar immediately to the right of my vertical stack that has all of the cards in it.
Thatâs strange, the heigh shoul be just for the single graph card oO
Regarding the two different unit, I was facing a similar issue for speedtest, between donwload/upload and ping.
I ended up using two differeng graph one above the other.
It might be a little complex to write, but the result is good, here is what it looks like on mine for speedtest:
This is basically 4 graph-card put togheter, I didnât do something like this for temp/humidity, I actually let them separate because my idea is that I will have more temp sensors and more humidity sensor on each graph (per room or zone in the house), in that case to donât mess things up too much I think two separated graph is a better soution
You have the two options upper_bound and lower_bound to customize the y-axis, but wouldnât really help achieve what you are after, you could also increase the height.
I would however recommend you to just keep them in two separate cards though.
Strange, never seen that, you are using the cards height option and not card modder or anything else to set the height right?
Iâve looked at the documentation but I canât figure this out. Iâm trying to figure out how to use dynamic line color on a two-entity card, but no matter where I try to put color_thresholds: in the code below I get an error like this:
while parsing a block mapping in â/config/ui-lovelace.yamlâ, line 177, column 21 expected <block end>, but found â-â in â/config/ui-lovelace.yamlâ, line 179, column 21
Code in ui-lovelace.yaml:
- type: custom:mini-graph-card
icon: mdi:thermometer
entities:
- entity: sensor.family_room_temperature
show_state: true
- entity: sensor.main_floor_temperature
show_state: true
Can someone show me how itâs supposed to be formatted? Iâd like the line to go dark blue when the temperature goes below 60 for both graph lines and stay the default color when above. Thanks!
You can achieve this in a few ways, here are two examples:
entities:
show_state: true
show_state: true
line_color:
- navy # first graph entry color
- navy # second graph entry color
color_thresholds:
- value: 60 # color when above 60
color: insert_default_color_here # 'var(--primary-color)' for example
entities:
show_state: true
show_state: true
color_thresholds:
- value: 0 # or any other value the temp won't go below
color: navy # color when above 0
- value: 60
color: insert_default_color_here # color when above 60
line_color:
- blue
- blue
color_thresholds:
- value: 60
color: red
entities:
show_state: true
show_state: true
This should work technically
@kalkih @SeLLeRoNe Thanks so much for the help! Iâve used the first version by Kalkih and it works (threshold is set at 65 just to make the colors change, and thereâs a lack of data on the right side of the lower dip) :
except both entities have the same line colors - and I donât see that any of the other versions would change this. Can I have the Main Floor line be, say, orange, and the Family Room line be, say, light blue, and have each of those turn blue below 60?
color thresholds are applied to the whole graph at the moment, so thatâs not possible, no.
You can override the color_thresholds for either entity by setting the color option in either entity object, but that would skip the thresholds completely and render that entity in a single color.
Okay, thanks, Iâve got that working as you described by using the color option so only one graph will change color. Not exactly what I wanted but it will do for now
If thereâs any chance that at some point the the color thresholds could be on a per-graph basis, that would be really nice, but I understand that it may not be possible or easy to do. Thanks for all your hard work on this card, and your responsiveness in this thread - both are very much appreciated!
Thanks for the kinds words.
Could possibly be made available on an entity basis in the future, itâs definitely âdoableâ.
Agree, would be very nice
Andrea
@SeLLeRoNe - great graph, would you be willing to share the latest config - trying to do similar and yours is way ahead. No point in reinventing.
Sure, no problem at all
Here it is:
- type: entities
show_header_toggle: false
entities:
more_info: false
group: true
height: 0
hour24: true
hours_to_show: 24
points_per_hour: 4
animate: true
decimals: 0
show:
icon: true
state: true
graph: line
fill: false
points: false
legend: true
extrema: false
labels: false
entities:
- entity: sensor.speedtest_download
color: "#3399ff"
show_state: true
- entity: sensor.speedtest_upload
color: "#ff6600"
show_state: true
- entity: sensor.speedtest_ping
color: "#33cc33"
show_state: true
more_info: false
height: 150
group: true
hour24: true
hours_to_show: 24
points_per_hour: 4
animate: true
decimals: 1
show:
icon: false
state: false
graph: line
fill: false
points: false
legend: false
extrema: false
labels: false
entities:
color: "#3399ff"
color: "#ff6600"
more_info: false
group: true
height: 25
hour24: true
hours_to_show: 24
points_per_hour: 4
animate: true
decimals: 0
show:
icon: false
state: false
graph: line
fill: false
points: false
legend: false
extrema: false
labels: false
entities:
color: "#33cc33"
more_info: false
group: true
height: 0
hour24: true
hours_to_show: 24
points_per_hour: 4
animate: true
decimals: 0
show:
icon: false
state: false
graph: line
fill: false
points: false
legend: false
extrema: true
labels: false
entities:
color: "#3399ff"
color: "#ff6600"
color: "#33cc33"
I am looking forward for the additional info in the âextremaâ part
I was trying to get my solar output sensor to show as a bar chart. This sensor reports once a day and I wanted the chart to show 12 days output, one bar per day.
I have
entities:
- entity: sensor.power_gen_cum_prior
name: ENERGY GENERATION
show:
graph: bar
hours_to_show: 288
points_per_hour: 0.041666667
lower_bound: 0
- type: history-graph
title: Power use Vs Gen
entities:
- sensor.energy_generation
hours_to_show: 288
refresh: 3600
and I get
The bar chart is accurate for the first 4 and the last 4 days, but the middle portion is somehow averaged?
(History-graph is shown for comparison).
Anybody tried to do a monthly graph?
Is it possible that you donât have correct data for those days?
I do have correct data, which is rendered correctly by the history graph.
