omg… so simple and simply overlooked… the shame
Thank you!
Thank you!
i am having an issue when trying to add the secondary y-axis.
currently i am just pulling in my energy meter for hte past 24 hours and trying to overlay a "nightmode’ binary sensor to compare day/night visually.
the example shows an input number. must it be so or can in be on/off?
I would need your help. I start with HA. I’m trying to understand how custom cards work.
I wanted to install mini-graph-card.
Can you tell me or I’m wrong. I would like to keep the card configurator.
I sent the file mini-graph-card-bundle.js in / config.
I added at the top of the configuration editor the line:
Attractions:
- type: module
url: /local/mini-graph-card-bundle.js?v=0.5.0
- type: custom: mini-graph-card
entities:
- ssensor.processor_use
show:
labels: true
color_thresholds:
- value: 20
color: "# f39c12"
- value: 21
color: "# d35400"
- value: 21.5
color: "# c0392b"
The .js needs to be in /config/www
thank you for the answer.
it’s the same thing
The red error box is telling you the problem.
It says that your indentation is off. And it’s telling you exactly where the indentation is off - in line 2.
Look at line 2. You should see how bad the indentation starting there is compared to everything else.
sorry but what is indentation?
One thing I noticed, ssensor should be sensor
So basically it should be (once indentation is fixed):
entities:
- sensor.processor_use
show:
labels: true
color_thresholds:
- value: 20
color: "# f39c12"
- value: 21
color: "# d35400"
- value: 21.5
color: "# c0392b"
Yes, that’s by design.
No.
Yep, seems broken indeed, not sure when this broke, will look into it.
As long as it reports its state as a value 0-1 for example, I believe it should work.
If it doesn’t you would have to create a template sensor or similar of that entity, that treat on as 1 and off as 0 e.g.
thanks. i suspect that is the issue. i’ll create a template sensors to convert the on/off to 1/0. makes sense to me now as i see we need to convert the string to a numerical representation to graph
Just following up. That was that case. Now that I have my template sensor 1 for night and 0 for day, it displays just fine
Is their a way to display a different sensor data in the header for example have pi hole percentage senor listed instead of the number of ads blocked
Sure,
You could do something like this.
You can also display multiple sensor states in the header with the show_state
option.
- type: custom:mini-graph-card
entities:
- entity: sensor.percentage
show_graph: false
show_legend: false
- entity: sensor.ads_blocked
color: blue
- entity: sensor.queries
color: red
Hey there, I was trying this graph and I found a bug!
For some odd reason, the “show_legend: false” hide the “next” entity from the legend instead of the one that is “assigned to”
I was able to have the same behaviour on a different graph, so I guess it’s definetely abug
I actually just noticed that as well , it’s fixed in the development branch, could probably do a new release tomorrow!
@kalkih I’ve been trying to style my Mini Graph Cards and I would love for them to be a perfect square (not the actual graph, but the entire card).
The custom Button Card component solves this with an aspect_ratio
option. Any chance you would want, and be able to, to add exactly that configuration option?
I can understand you do not want to add too many configuration options, so if not, I’ll try to get this working with some custom CSS.
For a card with 2 line graphs for 2 different kind of sensors (Temperature and pH level) on different numeric ranges, can I establish different color_thresholds
for each graph line? Can’t find a way to do it…
Also, can the legend
color entries (the little color square) have also an adaptive color?
Just updated but the problem it’s still there unfortunately
