Lovelace: mini graph card
Sorry but I’m really out of ideas then :man_shrugging:
I did a test with the code you shared, and still doesn’t work… like it is not mapping on/off to 1/0 in my opinion.
     - type: vertical-stack
        cards:
          - type: custom:mini-graph-card
            hours_to_show: 168
            points_per_hour: 0.25
            entities:
              - sensor.house_temperature
              - entity: binary_sensor.night_time
                color: '#FFFFFF'
                y_axis: secondary
                smoothing: false
                aggregate_func: min
                show_state: true
                show_line: false
                show_points: false
            state_map:
              - value: "off"
                label: "Day"
              - value: "on"
                label: "Night"
It will take a transition from day to night or vice-versa before you see anything.
Yep I got that but I had this binary_sensor for a few days already, so technically speaking the data should already be there :slight_smile:
At some point I will figure that out… doesn’t make any sense to me :smiley: I have also tried to re-install the card… mistery! :smiley:
@tom_l i did some more work :smiley:
Now it also consider the per-day base-cost of the electricity bill (configurable in the tariffs) and I will add the VAT and other costs calculation soon to have what it should look (once I monitor literally everything, or simply the mains) a monthly cost which is very close (if not exact) to what I got in the bill :slight_smile:
I did some tests with you graph and realized that yes, with bars looks cleaner at least for now, but I have used your colors thresholds adaptim them to the costs aswell (daily/monthly/yearly)… I still have to do the same for Watts, Ampere and Volts, but there is no rush…
I think I can say I have accomplished quite a bit in the past 2/3 days thanks to your code as a baseline (and I also managed to fix the reset issue using a custom MQTT Automation with Sensor to keep the total updated and not reset it on every restart)
So, thank you very much! :slight_smile:
I was thinking sth like this
ha_minuty
If I have 1 hour for the show, then at the bottom of the minute section to see.
Yesterday I realized that the binary_sensor with tod platform you’ve suggested isn’t working for me…
For some odd reason it’s always off…
So what I did remember was to check check the input_number I was using before but never the logbook for the binary_sensor… bad Andrea! :smiley:
I have now removed it and returned back to the input_number with the automations, removed the state_map (even if technically that wasn’t required) and updated all the graphs…
And now I can see it:
I did debug a bit, and I have also found out why it wasn’t working!!!
If I set animate: true, it stop working while if it’s false or commented out, it works!.
I guess that might be a bug? ^^
No, that’s currently not possible.
@SeLLeRoNe Nice!
The tod platform is fairly new I think, so if you haven’t updated HA in a while I guess that might be the reason.
I’ll take a look at the animate issue, exactly what is not working when it’s set to true?
I am actually on the latest stable release, go figure :slight_smile:
The secondary axis is not loaded when animate is set to true :wink:
Thanks, should be fixed in the next release.
I got a question :slight_smile:
Is there a way to show an annual graph with a per-month bar?
hour_to_show 8760
what about points_per_hour? :slight_smile:
Found another bug (at least I think :wink: )
If you have fill set to false in show, the secondary axis doesn’t show :slight_smile:
Not really, closest you could do is 30 day basis I guess, hours_to_show = 1 / (24 * 30) = 0,001388888888889.
Data points would be calculated from the current date so not grouped by month.
Can’t reproduce that one, do you have an example config?
I’d like to bring up one of my earlier posts here to see if anything has changed:
Essentially, I’m graphing my net energy usage, which can be both positive and negative (solar), and there are a couple of issues that I’ve found with the presentation of that kind of data.
First, there’s no clear way to denote zero, which I’ve sorta solved by using a separate data series that always returns zero, and the second is that the fill always starts from the bottom of the graph. I would like to see it fill from zero to the value, positive or negative, with the fill following the line color (green for negative, red for positive).
Is there a way to solve either issue, or should I file them as feature requests in github?
None of those features are available and I don’t think they will ever be in this project, I would recommend you to look for a more mature/advanced graph solution such as Grafana.
Looking at your prev posted pic of the graph, I would recommend setting a fixed lower and upper bound, so 0 always stays in the center of the graph, use color thresholds to make the line switch color depending on > 0 or < 0.
I’m actually doing that already, even though it’s not obvious from the graph. I have the line changing color from green to red at zero and I’ve set upper and lower bounds to put the center at zero, and that works fine. I just have to add another “fake” series fixed at zero to add the (purely aesthetic) zero-line and fill doesn’t work as I’d expect. It’s really very close to what I’d like to see, and “zero-aware fill” is the only part that I can’t address. It’s not critical and I’ve just disabled fill for now, but I’m hoping that there are kindred souls who are looking for something similar.
Thanks for the value, I’ll give it a try.
For the config is the same I provided before:
                    icon: "${vars[0] > 30 ? 'fas:thermometer-full' : vars[0] > 25 ? 'fas:thermometer-three-quarters' : vars[0] > 20 ? 'fas:thermometer-half' : vars[0] > 10 ? 'fas:thermometer-quarter' : 'fas:thermometer-empty' }"
                    more_info: false
                    height: 150
                    line_width: 4
                    hours_to_show: 168
                    aggregate_func: max
                    group_by: hour
                    group: false
                    hour24: true
#                    animate: false
                    decimals: 1
                    font_size: 100
                    font_size_header: 14
                    align_header: default
                    align_icon: right
                    align_state: center
                    lower_bound: -5
                    upper_bound: 40
                    show:
                      icon: true
                      state: true
                      graph: line
                      fill: false
                      points: false
                      legend: false
                      extrema: false
                      labels: false
                      name_adaptive_color: true
                      icon_adaptive_color: true
                    color_thresholds:
                      - value: 5
                        color: "#0055FF"
                      - value: 15
                        color: "#FF6600"
                      - value: 20
                        color: "#FFAA00"
                      - value: 22.5
                        color: "#FF7700"
                      - value: 25
                        color: "#FF3700"
                    style: |
                      ha-card {
                        padding: 16px !important;
#                      ha-icon {
#                        color: [[ if(vars[0] >= 30, "rgb(255, 0, 0);", if(vars[0] >= 22, "rgb(255, 153, 0);", if(vars[0] >= 16, "rgb(255, 204, 102);", "rgb(153, 204, 255);"))) ]]
                    entities:
                      - entity: sensor.house_temperature
                        color: '#FF5000'
                        show_state: true
                      - entity: sensor.dark_sky_temperature
                        color: '#0099CC'
                        show_state: true
                      - entity: input_number.night_time
                        color: '#FFFFFF'
                        smoothing: false
                        show_fill: true
                        show_line: false
                        show_points: false
                        show_legend: false
                        show_state: false
                        y_axis: secondary
As as I set fill to true it works:
It might be possible to achieve with some css transforms, custom bounds and possibly template sensors, here’s a quite interesting graph I came up with recently with the help of card-mod and some custom bounds:
Note, center is 4 in the screenshot and not 0
hyperion_8123_lovelace_example%20(17)
  hours_to_show: 168
  smoothing: false
  line_width: 2
  entities:
    - entity: sensor.prod
      color: "#27ae60"
    - entity: sensor.consump
      y_axis: secondary
      color: "#e74c3c"
  show:
    labels: true
    labels_secondary: true
  lower_bound_secondary: -6
  lower_bound: -6
  upper_bound_secondary: 14
  upper_bound: 14
  hours_to_show: 168
  style: |
    .graph__labels.--secondary .label--max {
      order: 5;
    .line--rect,
    .fill--rect,
    .line--points {
      height: 50%;
    g .line--rect:last-of-type,
    g .fill--rect:nth-of-type(2),
    svg > g:last-child {
      transform: scale(1, -1);
      transform-origin: center;
That looks amazing :slight_smile:
That’s really cool! I’ll play around it.
I’m also playing with Influx/Grafana and it looks like a) Grafana integration into Lovelace seems a bit hacky with iframes and b) it doesn’t work at all with Ingress through Nabu Casa. Something native would be a better solution for me on my main Lovelace view.
Here’s a better example of what I have now:
