Is this in HA?
It looks very nice
If yes, would you mind share the config?
Is this in HA?
It looks very nice
It is HA Lovelace, base theme is dwains theme and I made this custom addon for it. There is no reason you couldnāt use it without the base theme however as itās all just lovelace resources used in conjunction together.
Same here. I tried to configure soft limits on the graphā¦
Awesome job!
Is it any way to get a time label on the x-axis? I think that would be great! Now itās a little bit hard to know what you really are looking at without clicking around on the graph.
Do you have any other idea or tests I could perform ? Thanks
i would like to implement a monthly versio of the 7 days so not 7 days groups but by month
anyone ideas?
currnetly config for 7 days;
type: 'custom:mini-graph-card'
name: Energy consumption
bar_spacing: 2
decimals: 3
group_by: date
height: 200
hours_to_show: 168
icon: 'mdi:flash'
unit: kWh
update_interval: 60
entities:
- entity: sensor.monthly_energy_peak
aggregate_func: max
color: orange
- entity: sensor.monthly_energy_offpeak
aggregate_func: max
color: 'rgb(52, 152, 219)'
show:
labels: false
graph: bar
hour24: true
extrema: false
average: false
also i just started the graph and it show 7 days but i only started collecting from today so it takes the first 6 days equal to to last day? Anyone knows how to set those first 6 to zero or to hide them?
This is not the tool for graphing monthly statistics. Look at Grafana and influxdb instead.
how do you connect grafana with the local hassio db then?
This is not the place to ask.
Thank you for your helpā¦
Iāve tried installing this card but getting an error that I canāt work out.
Installed using HACS.
Installed to;
/local/community/mini-graph-card
Hereās the top of my ui-lovelace file that shows other working resources including the non working mini-graph-card
resources:
- url: /local/community/lovelace-slider-entity-row/slider-entity-row.js
type: module
- url: /local/community/media-player-mini/mini-media-player-bundle.js
type: module
- url: /local/community/mini-graph-card/mini-graph-card-bundle.js?v=0.9.3
type: module
- url: /local/custom_cards/icloud3-event-log-card.js?v=1.000
type: js
Here is where I am trying to create a quick test card;
- type: custom:mini-graph-card
entity: sensor.rumba_memory_usage
and here is the resulting error in the card on the dashboard;
Cannot read property 'length' of undefined
Any help would be appreciated.
Thank you!
if you install using hacs no need to add the recources manually anymore, they are done automatically in config > lovelace ui > recources
trie to remove those recources in your ui file and restart your server and make the entity card again (make a manual card with this:
so no ā-ā
you can also trie this in th manual card:
comes in handy if you want more entities in 1 graph card
entities:
- entity: sensor.rumba_memory_usage
Thanks for the help, but sadly none of that has worked for me.
If I remove the resources from the top of my UI file, then it breaks all my custom cards that I have working.
I tried changing the card as well, and still no luck.
I did consider whether it was something to do with changing over to hacsfiles from community, but i tried all combinations of that as well, and still it made no difference.
are you on the latest stable build of hassio and hacs?
Hi something i forgot to mention
in order to let this work install following hac plugins
card-tools
This is a collection of tools to simplify creating custom cards for Home Assistant
If you see āCanāt find card-tools. [ā¦]ā in your Home Assistant UI, this is what you want.
please install this and remove the recources in you ui yaml file and let me know if you still have the cant find the custom ā¦
Thanks again.
I have now installed the card-tools plugin.
Sadly if I remove the resources from my UI file, it still breaks all the links to everything else.
The error I am now receiving on the mini-graph-card is;
Cannot read property ālengthā of undefined
type: ācustom:mini-graph-cardā entity: sensor.rumba_memory_usage
Also, yes, on latest release for everything, however my HACS folder is all still based on community and not hacsfiles.
from my opnion i would reinstal hacs following the install procedure on their website.
in that mather all links will be correct and functioning
hacs has to be installed in the ācustom_componentsā folder
in www/community the differents plugins wil be installed because they should be accesible throught /local/community (symbolic auto link)
when you install a plugin the recource will auto be addded in config > lovelance > recources
card tools will allow the lovelace UI to open through āhacfilesā
i think your base problem is the incorrect installation of hacs
to be clear you acces tour lovelace UI file by:
go to a dashboard > three dots upper right corner > edit > three dots upper right corner > raw
i have no recources listed there
everything goes by the recources from config > lovelace > recources (automatic if you install a plugin from hacs and added afterwarths to lovelace ==> after installation there willl be a pop up on the plugin screen that says add to lovelace, thats making the symbolic link)
card tools delivers me the āhacfilesā to lovelace link ==> so all my plugins work because of that without the mentioning of recources in my ui file
This card doesnāt depend on card-tools.
From reading the error, itās most likely because you didnāt provide a valid card config, entity is not a valid root option, entities should be provided as a list, try the following instead:
entities:
