Lovelace: mini graph card
Invalid indentation:
  1. Wrong placement for color_thresholds - is not a property of some entity.
  2. These are not “show” options:
    update_interval: 30
    icon_adaptive_color: true
    name_adaptive_color: true
    points_per_hour: 1
That’s what you thought now, isn’t it?
entities:
  - entity: sensor.teplota_vonk
    show_state: true
hour24: true
show:
  extrema: true
  labels: true
color_thresholds:
  - value: -10
    color: '#0040ff'
  - value: 0
    color: '#00ffff'
  - value: 10
    color: '#ffcc33'
  - value: 18
    color: '#ffbf00'
  - value: 23
    color: '#ff4000'
type: 'custom:mini-graph-card'
Right
And you can add this:
update_interval: 30
points_per_hour: 1
Cannot check it myself but the code seems right.
Thanks for pushing, the line works fine, icon and name working OK
i did try the mini-graph into custom:button-card, however I can’t fit if I turn the name, state or labels as true. Can you fit all the info on such small button?
I could but it becomes a real estate issue.
Another option beside button card may be grid, but real estate becomes an issue.
type: grid
cards:
  - type: 'custom:mini-graph-card'
    entities:
      - entity: sensor.speedtest_download
        show_state: true
      - entity: sensor.speedtest_upload
        show_state: true
    style: |
      ha-card {
        transform: scale(1.0);
        height: 95%;
        border-radius: 10px;
        width: 98%;
        margin: -0px;
        padding-top: 0px;
        background-color: rgba(10,10,10,0.9);
        border: solid 1.4px rgba(50,50,50,0.9);
        box-shadow: 0px 0px 3px 0.5px #2D2F32;
        text-shadow: 1px 1px 1px block;
    line_width: 2
    align_icon: state
    font_size: 50
    group: false
    group_by: hour
    hours_to_show: 48
    fill: fade
    show:
      icon: true
      legend: false
      state: true
      labels: false
      graph: line
      points: false
  - type: button
    tap_action:
      action: toggle
    entity: switch.workshop
  - type: button
    tap_action:
      action: toggle
    entity: light.pool_lights
Screen Shot 2021-03-28 at 1.51.16 AM
Here was my original suggestion. Showing the extrema is a challenge. Eventually I added a pop up card to show the detail of the entity. The button image simply gives me a quick visual reference.
      type: 'custom:button-card'
      aspect_ratio: 1/1
      tap_action:
        action: fire-dom-event
        browser_mod:
          command: popup
          title: []
          card:
            !include /config/lovelace/popups/climate_stats.yaml
      custom_fields:
        graph:
          card:
            entities: '[[entities]]'
            animate: true
            font_size: 75
            hours_to_show: 48
            line_width: 1
            show:
              extrema: false
              icon: true
              state: true
              legend: false
              fill: fade
Screen Shot 2021-03-28 at 1.59.05 AM!
I’m working on a wall tablet that will default to a stock page during market hours, and I’m wondering if anyone has a way to set a variable based on an entity attribute that can be used a color threshold (in this case the prior market close value). I know core HA was supposed to support templates in more places as of a few releases ago but this doesn’t work:
          - type: custom:mini-graph-card
            icon: mdi:amazon
            hours_to_show: 9
            points_per_hour: 60
            line_width: 1
            color_thresholds:
              - value: 0
                color: red
              - value: "{{ state_attr('yahoofinance.amzn', 'regularMarketPreviousClose') }}"
                color: var(--accent-color)
            color_thresholds_transition: smooth
            height: 90
            entities:
              - entity: yahoofinance.amzn
Use config-template-card.
type: vertical-stack
cards:
  - type: 'custom:config-template-card'
    variables:
      - 'states[''input_number.test_number'']'
    entities:
      - '${vars[0].entity_id}'
    card:
      cards:
        - type: entities
          entities:
            - input_number.test_number
          entities:
            - entity: sensor.cleargrass_1_co2
          hours_to_show: 6
          points_per_hour: 60
          show:
            labels: false
            fill: true
          font_size: 50
          line_width: 4
          height: 500
          color_thresholds:
            - value: '${parseFloat(vars[0].state) - 100}'
              color: red
            - value: '${parseFloat(vars[0].state) - 75}'
              color: green
            - value: '${parseFloat(vars[0].state) - 50}'
              color: magenta
            - value: '${parseFloat(vars[0].state) - 10}'
              color: cyan
            - value: '${parseFloat(vars[0].state)}'
              color: orange
            - value: '${parseFloat(vars[0].state) + 10}'
              color: violet
            - value: '${parseFloat(vars[0].state) + 75}'
              color: blue
            - value: '${parseFloat(vars[0].state) + 100}'
              color: brown
Using the card to display sensors’ change with “Day / Night” as a background graph:
entities:
    color: green
    unit: ''
    show_state: true
    show_indicator: false
    show_graph: true
    show_line: true
    show_fill: true
    show_points: true
    show_legend: false
    state_adaptive_color: false
    fixed_value: false
  - entity: binary_sensor.night
    color: 'rgba(50,73,92,0.85)'
    unit: ''
    show_state: false
    show_graph: true
    show_line: false
    show_fill: true
    show_points: false
    show_legend: false
    fixed_value: false
    aggregate_func: min
    y_axis: secondary
hours_to_show: 24
points_per_hour: 60
aggregate_func: last
update_interval: 0
height: 150
line_width: 1
hour24: true
lower_bound: ~400
lower_bound_secondary: ~0
smoothing: false
show:
  icon: true
  state: true
  graph: true
  fill: fade
  points: true
  legend: false
  average: false
  extrema: true
  labels: true
  labels_secondary: true
state_map:
  - value: 'off'
    label: '0'
  - value: 'on'
    label: '1'
Recently I realized that the browser is flooded by warnings:
I suspect that this happens since the "state_map" is provided only for one graph.
So this issue - https://github.com/kalkih/mini-graph-card/issues/271 - is more important, it is not just an “improvement”.
Another case - let’s use only ONE graph with state_map like this:
state_map:
  - value: unavailable
    label: Sensor off
  - value: unknown
    label: Sensor off
Even now we have to receive lots of warnings.
So my proposal is:
  • provide "state_map" for all entities;
  • meanwhile DISABLE these warnings.
WOW
Could you post the code for this graph?
It’s great looking!!
Hello!
This is a great add on and I have had really good success with using it basically everywhere in lovelace!
I am having one issue with displaying ink level bar graph.
I want to to show the ‘last’ state of each ink level but having no luck. No matter what I do, it shows each ink level in groups:
Any idea how to make each ink level it’s own bar showing the last recorded ink level?
Here’s my Panel YAML:
name: Canon Pro-100 Ink Levels
icon: mdi:printer
hours_to_show: 1
points_per_hour: 1
show:
  graph: bar
  legend: false
  state: false
  fill: true
  labels: false
  points: false
entities:
  - entity: sensor.canon_pro_100_series_black_bk
    color: Black
  - entity: sensor.canon_pro_100_series_cyan
    color: Cyan
  - entity: sensor.canon_pro_100_series_gray
    color: Gray
  - entity: sensor.canon_pro_100_series_light_gray
    color: "#D3D3D3"
  - entity: sensor.canon_pro_100_series_magenta
    color: Magenta
  - entity: sensor.canon_pro_100_series_photo_cyan
    color: "#e0ffff"
  - entity: sensor.canon_pro_100_series_photo_magenta
    color: "#ff80ff"
  - entity: sensor.canon_pro_100_series_yellow
    color: Yellow
What is an update interval for these sensors?
Also add this:
Thank you, apparently my home assistant wasn’t previewing the card correctly. Once I saved the panel, it shows up correctly. It seems to be working without adding the aggregate function
Can someone please tell me how to do the basic two sensor in the same graph thing? I can not for the love of me make it work…
entities:
  - entity: sensor.cleargrass_1_temp
    color: green
    show_state: true
    show_points: false
  - entity: sensor.cleargrass_1_humidity
    color: blue
    show_state: true
    show_points: false
    y_axis: secondary
hours_to_show: 6
points_per_hour: 60
show:
  labels: true
  legend: true
  icon: false
line_width: 2
height: 200
lower_bound: 0
Hi, I think i’ve read through all posts related to hovering, but I couldn’t find anything. I have three graphs with my power measurement of the last hour, day and month. I would like to hover over a point and see it’s value but I don’t want to see the current state all the time as it would be 3 times the same. Does anyone know how to do that?
This doesn’t look like a mini graph card. Could you clarify?
sorry wrong topic, i thought i opend another one
It is possible for a stock history-graph card
