Lovelace: mini graph card
Not supposed to be used as a footer or header.
…Previously worked. But partial works
Only stock graph may be used for header & footer with ONE sensor defined by the “entity:” option.
There is no "entity" option for "mini-graph-card", so there is an error:
I hear what you’re saying, and I see the docs. Just wanted to mention that this works for me on 2021.5.5. I suppose it will break now when I upgrade my HA instance.
      - type: entities
        title: Electricity Consumption
        show_header_toggle: false
        entities:
          - entity: sensor.daily_power_consumption
            icon: mdi:power-plug
          - entity: sensor.monthly_power_consumption
          - entity: sensor.monthly_power_consumption_forecast
            name: This Month's Forecast
            icon: mdi:trending-up
        footer:
          type: custom:mini-graph-card
          entities:
            - entity: sensor.current_power
          hours_to_show: 24
          hour24: true
          smoothing: true
          points_per_hour: 12
          line_width: 2
          line_color: var(--custom-graph-color-red)
          show:
            extrema: true
            icon: false
            average: true
            state: true
(See the above config, @typxxi.)
almost ashamed to ask, for this must be way too simple, but it honestly is my first graph with a secondary y-axis…
could somebody please throw me a quick pointer where I can find the options to set the secondary y-axis?
my solar would go from 0- 6000 watt, and the cloud coverage from 0- 100% …
  - type: custom:mini-graph-card
    name: Zon & Wolk
    entities:
      - entity: sensor.zp_actuele_opbrengst
      - entity: sensor.weatherbit_cloud_coverage
        show_line: true
        show_points: true
        show_legend: true
        y_axis: secondary
    show:
      labels: true
      labels_secondary: true
    upper_bound_secondary: 100
is incorrect obviously:
thanks…
Marius, hi.
Check this.
name: Zon & Wolk
entities:
  - entity: sensor.cleargrass_1_co2
    color: green
  - entity: sensor.battery_life360_ildar
    color: red
    show_points: true
    show_legend: true
    y_axis: secondary
show:
  labels: true
  legend: true
  icon: false
hours_to_show: 24
points_per_hour: 60
line_width: 2
height: 200
lower_bound: 0
lower_bound_secondary: 0
The lower_bound_secondary: 0 could be your point.
a yes, I took those for default… adding them makes this:
    name: Zon & Wolk
    entities:
        color: gold
        color: grey
        show_line: true
        show_points: true
        show_legend: true
        y_axis: secondary
    show:
      labels: true
    lower_bound: 0
and
only started recording the cloud coverage sensors since this afternoon, so not sure yet if this is the right one to use, but the graph is better now.,
thanks!
Hi gents
Any idea why this is not working
name: Watering Last 7 Days
icon: mdi:sprinkler-variant
entities:
  - entity: binary_sensor.irrigation_unlimited_c1_z1
    attribute: today_total
  - entity: binary_sensor.irrigation_unlimited_c1_z2
show:
  graph: bar
  labels: true
unit: min
aggregate_func: max
hours_to_show: 168
group_by: date
lower_bound: 0
I think that you messed up the things - binary sensor have just 2 states - true / false and doesn’t have attributes (attributes are feature of devices).
Be inclusive.
Attributes aren’t supported — it’s not a documented feature. You need to create a template sensor to extract the attributes into its own sensor (it’s been asked several times on this thread).
According to Github, attributes are added to dev version; we are waiting for release version; and probably anyway I gonna stay with template sensors & availability checks…
No, you can create a template binary sensor with attributes.
Is there any way to have a graph from a sensor, but also draw in the same graph a horizintal line with a value. The scope is clearly see if we are below or above a certain treshold (horizintal line). THX!
You can add the 2nd graph for a template sensor which is = threshold value.
Kind of this (here the red line is for zero):
any way to change this icon according to the status?
For example, off icon A, on icon B
2021-08-28 13_01_13-Window
  1. to replace the icon - use config-template-card
  2. to change the icon’s size or color - use card-mod
any doc about this? How use, example, variables?
config-template-card - read community forum (use search) as well as official docs on GitHub (there is a link to the docs on the 1st post in the corresponding forum’s thread
card-mod - search for my post in this thread with examples
Nice, i’ll search, tks bro.
Hello guys, is there a way to set the animation speed of the graph?
Thanks!
