What version of mini-media-card are you on? (I may have missed you saying).
Problem solvedā¦Mini Media Player 1.15.0, but config.yaml still quoted as v1.13.0.
Thank you
@kalkih is there a way for the idle view to remain consistent with the chosen artwork view.? So when it idles, instead of it minimizing to the compact view it can remain full-cover.? I use the full-cover view or full-cover-fit view and I have an image that gets displayed when the player goes into idle mode. The problem is that the player goes into idle mode and changes to its compact view which impacts the placement of the other cards and the overall look of my layout.
Uff, it was a tough nut to crack, but I have finally finished my dashboard concerning multiple Sonos players and an Apple TV that sometimes took over my Sonos Beam.
I use a mix of conditional cards and entity filters, so the cards disappear or appear depending on if the Apple TV takes over, or the Sonos speakers become grouped.
Iāve previously bothered with having binary sensors register if speakers are grouped or not, but they were generating a lot of errors on HA bootup, so this method using entity-filter is a lot more simple for me to grasp.
Currently it looks like this:
Code is the following:
type: custom:stack-in-card
title: Media
mode: vertical
cards:
- type: conditional
conditions:
- entity: media_player.living_room_apple_tv
state: playing
card:
type: custom:mini-media-player
group: true
artwork: material
source: icon
sound_mode: icon
info: short
- type: conditional
conditions:
state_not: playing
card:
type: entity-filter
entities:
- type: custom:mini-media-player
attribute: sonos_group
group: true
artwork: material
info: short
hide:
power: true
icon: true
speaker_group:
platform: sonos
sync_volume: true
entities:
- entity_id: media_player.dining_room
name: Sonos Dining Room
- entity_id: media_player.kitchen
- entity_id: media_player.bathroom
- entity_id: media_player.bedroom
state_filter:
- attribute: sonos_group
operator: regex
value: ^..media_player.living_room[^_]
- type: entity-filter
entities:
entity: media_player.dining_room
group: true
artwork: material
info: short
hide:
power: true
icon: true
speaker_group:
platform: sonos
sync_volume: true
entities:
- entity_id: media_player.living_room
name: Sonos Living Room
state_filter:
operator: regex
value: ^..media_player.dining_room[^_]
entities:
entity: media_player.kitchen
group: true
artwork: material
info: short
hide:
power: true
icon: true
speaker_group:
platform: sonos
sync_volume: true
entities:
state_filter:
operator: regex
value: ^..media_player.kitchen[^_]
entities:
entity: media_player.bathroom
group: true
artwork: material
info: short
hide:
power: true
icon: true
speaker_group:
platform: sonos
sync_volume: true
entities:
state_filter:
operator: regex
value: ^..media_player.bathroom[^_]
entities:
entity: media_player.bedroom
group: true
artwork: material
info: short
hide:
power: true
icon: true
speaker_group:
platform: sonos
sync_volume: true
entities:
state_filter:
operator: regex
value: ^..media_player.bedroom[^_]
Hello all,
Can someone tell me if I canedit the information that is on the field below the name of the TV? Its showing āAppā but Iām using Netflix. Is it possible to edit or to fetch the app from another entity?
thanks
What brand TV is it? There is a Sony custom component that allows greater control and detailed feedback from the TV
Sony, but the integration that is giving the description as āAppā is the sony entity. the google cast entity of the TV is saying that the app_name is Netflix for example. I would like to have in the Sony integration the attribute with the same description that the google cast entity
Hello together,
I have a MusicCast multi-room setup and I like the way how I can handle grouping etc. with the Mini Media Player.
The standard HA media player has a button which opens the library, where I can actually chose a concrete source, like a specific preset, or a net radio channel.
Is there a way, how I can open the āsourceā library from the mini media player card? Probably this is via buttons, but what would the service or action be, that opens the library?
Thanks for input!
Micha
2 step process, click the card, another card pops up with the library button available.
Ok, yes, I know.
But isnāt there a shortcut button, like on the default media player card?
Ok, so thatās why I asked what brand it was. There is a Sony CUSTOM COMPONENT that gives you more detail about the apps running etc. ie: not a default / core integration.
Well I cannot see it there in the docs, but of course you should look for yourself as I may have missed it.
My Echo devices recognize these commands as being TTS and it says that the NOTIFY command needs to be used. Does anyone know how to get a streaming radio station URL to play using the mini media player with Echo devices.?
Only via TuneIn:
buttons:
- type: custom
id: play Milano Lounge on tunein
image: /local/images/MilanoLounge.png
This is a screen capture of my mini media player cards.
I wonder if itās possible to integrate thoses cards to my floorplan ?
And if so, how ?
Hi. i cant find, what can increase size of āsource menuā button. how to increase size oof this button?
Hi!
Iām trying to cast lovelace view to a google hub with only mini media player as a card.
It seems to work, but artwork is missing. Has anyone got the artwork to be displayed when using lovelace cast?
Hi all,
Is is possible to play a Sonos queue with Mini Media Player? I managed to play spotify playlist, sonos radio and favorites, but I havenāt managed to play from the Sonos queue. Thanks for your help/suggestions!
Hello, Iām trying to color the icon inside the card as you can see below:
What iād like to achieve is that each button change color if the related sensor is active or not.
The card code is the following:
entity: media_player.salotto
artwork: cover
icon: mdi:soundbar
icon_state: true
volume_stateless: false
volume_step: 5
sound_mode: full
hide:
power_state: false
controls: false
shortcuts:
columns: 2
buttons:
- name: Dialoghi
icon: mdi:account-voice
type: service
entity_id: switch.sonos_salotto_speech_enhancement
- name: Notte
icon: mdi:weather-night
type: service
entity_id: switch.sonos_salotto_night_sound
What do you suggest to use?
Thatās not a feature of this card, as far as Iām aware. Head over to card-mod and look or ask for help there.
