Hi team.
Is there any way I can get volume sliders beside each speaker zone? Perhaps only if that zone is ‘on’.
Here is my code.
Thanks.
Hi team.
Here is my code.
Thanks.
I have 2 sonos speakers that no matter what I try they will not show up on the card as they should…
Here’s my config… I’m sure it’s something I’m overlooking that’s simple but would appreciate some help! [I’ve changed platform that currently says media_player to sonos and nothing changes]
- type: 'custom:mini-media-player'
entity: media_player.sonos_pair
name: John's House Jams
icon: mdi:speaker
volume_step: 1
sync_volume: true
artwork: cover
hide:
power: true
volume: false
progress: false
icon_state: false
state_label: false
prev: true
next: true
speaker_group:
platform: media_player
show_group_count: true
source: full
sound_mode: full
info: scroll
entities:
- entity_id: media_player.sonos_five
- entity_id: media_player.unnamed_room
Thank you to @Louis1 for posting your config… the above issue was an indention issue!!! Fixed!! PS [EDITED the above config it’s now correct]
Hello all,
Could I possibly get some help on one the below issues. I really don’t know what is going on or causing it. Below is a screenshot of the UI when I attempt to use the mini media player custom card which was installed through HACS. There are no input abilities on the GUI and the input area where you put the entity you would like is completely missing (In my instance, there is a list of all media player entities in its place that). Essentially, I can interact with virtually no input areas. Thank you all for any guidance that you can give.
You’ve got to choose one, click on the media player you want to use!
So on this one, those things at the top aren’t clickable for some reason.
Yeah, they should be.
Hmm, let me look at this again.
Make sure you refresh your browser, ctrl-f5.
is it possible that the gui portion may be broke, i’ve read alot of the custom lovelaces don’t have a fully built out gui. I’m messing with this as we speak.
Is it possible, that I have so many media players that it is flipping it out? Refresh seems to have done nothing for me on this one.
Maybe. Use the code editor.
Would anyone else have any ideas as to what could be causing these issues? @kalkih I’m honestly at a loss and don’t know what else to look into/ check
So, something ended up being weird with this. I ended up deleting every lovelace custom downloaded from HACS (luckily, I really wasn’t using any of them). Rebooted HA and then when I went back in, downloaded only mini media player from HACS and the GUI looked proper. I don’t know if it’s possible but I almost wander if one of the custom lovelace cards I had was interfering with that one. Anyways, it’s corrected now so I guess that’s all that matters. Thank you again for the help you have given me on the couple of things I had going on. Very helpful!!
There has also been an update for this card in the last day or so, so you may have got a newer and better version in the process. Glad you got it working anyway.
Have problem with my image the first “full-cover” artwork got bright bacground image. If change it to “cover” get pallid image. Need bright image in “cover” too. Please help.
Is it possible to have more than one label in the shortcuts?
After lots of trial and error I was able to get the sensor.sonos_favorites into the custom:mini-media-player shortcuts:
type: custom:auto-entities
card:
type: entities
filter:
template: |
'entity': 'media_player.kitchen',
'type': 'custom:mini-media-player',
'name': 'Sonos',
'group': 'true',
'source': 'icon',
'hide': {
'volume': True
'shortcuts':{
'columns': 3,
'buttons':
{%- for media_id, station in state_attr("sensor.sonos_favorites", "items").items() -%}
'name': station,
'type': 'service',
'id': 'media_player.play_media',
'data':
'entity_id': 'media_player.kitchen',
'media_content_id': media_id,
'media_content_type': 'favorite_item_id'
{%- endfor -%}
If anyone knows how to get the image from the media browser it would be great to put that on the shortcut button too!
Hope this helps.
Have you tried scripts? Seems a little easier and shortcuts work with images. Hopefully this will help as well.
Script example:
sequence:
- service: media_player.play_media
entity_id: media_player.gym
media_content_id: FV:2/26
media_content_type: favorite_item_id
metadata:
title: 90s90s Hiphop
thumbnail: >-
https://sonos_generated_url
media_class: genre
children_media_class: null
navigateIds:
- media_content_type: favorites
media_content_id: ''
- media_content_type: favorites_folder
media_content_id: object.item.audioItem.audioBroadcast
mode: single
icon: mdi:radio-tower
Cards example:
type: vertical-stack
cards:
- type: custom:mini-media-player
entity: media_player.gym
group: true
hide:
volume: true
next: true
prev: true
play_pause: true
info: true
power: true
shuffle: true
icon: true
progress: true
shortcuts:
columns: 3
buttons:
- icon: mdi:radio-tower
type: script
type: script
type: script
artwork: material
source: icon
artwork: full-cover
replace_mute: stop
info: short
hide:
power: true
group: true
Screenshot of cards:
