Probably depends on whether the media player supports the join
, unjoin
services. Do they?
Hi, is there any possibility to make the line of the slider thinner?
Thanks in advance!
did you find a solution for this mate?
Iām using google nests and Iām getting this msg, not sure if Iām doing something wrong
Assuming the Google nest uses the Google cast integration, then it does not support the join or unjoin services.
Yup the Nest definitely uses the Google Cast integration.
Thatās a shame, thanks guys
Correct, but also kinda strange because they DO support it via the Google Home app. I wonder if this is somewhere the Integration can be improved to fix the holeā¦?
Yep, that would be a FR I think.
I want the entity name dynamic, so I use a input_text. but that does not work
- entity_id: input_boolean.media_player_ruimte1
name: {{ states("input_text.ruimte_1")}}
gives me invalid key: "{'states("input_text.ruimte_1")': None}"
anyone an idea ?
The entity_name of what? entity_name is used in a number of contexts in the docs.
- type: grid
cards:
- type: entities
entities:
- type: custom:mini-media-player
group: true
entity: media_player.oefenzaal_tv
artwork: none
hide:
power: true
icon: true
toggle_power: false
info: true
volume: true
group_button: true
power_color: true
show_source: true
expanded: true
speaker_group:
platform: media_player
sync_volume: false
show_group_count: false
expanded: true
icon: mdi:link
entities:
This need to be a media player entity. Itās name will start with media_player. You have specified an input boolean, which makes no sense.
I am not sure whether this is templatable. But fix the other problem.
I am writing code for a media player that is not excisting at the moment. I am renovating a house. When the house is ready, I want to have it running as fast as possible
Well it still wonāt be an input boolean.
Your ability to read .ts files is far superior to mine!
I know that. but when I donāt have a mediaplayer yet I made a helper. this has nothing to do with my questionā¦
And therefore your question has nothing to do with this thread. But Iāll try to help, try single quotes. If that doesnāt work see Templating - Home Assistant
my question has everything to do with this threadā¦ It is the name of an entity of a mini media player that is not ok.
and @LiQuid_cOOled said it is not templatable so my question is answered
Templating was your second line. Putting an input boolean in where you should have a media player is just nonsense.
I suppose you put diesel into your petrol car too.
