The bundle is correct. You need to read up in this thread and download the bundle - see here https://github.com/kalkih/mini-media-player/releases/tag/v0.9.2
Thank you!
Thatās actually not a typo, mini-media-player.js
is the actual source and you could use it, but I recommend following the instructions and using the bundle version for reasons stated below
Thank you again for your help and patience.
I have manually updated the tag and itās correct now.
You are absolutely right that is an embarrassing mistake.
@kalkih, thanks for your amazing work on this!
In my configuration Iām using a separate device to control the volume, different than the one actually playing the music (For example, Sonos Connect plugged to an Amplifier). In this case the volume control is delegated to the amplifier and the Sonos is configured to use a fixed volume.
The real amplifier volume is mapped to an input_number
(with the help of a bunch of automation)
Currently to achieve this, Iām using 2 entries in my lovelace config:
- type: conditional
conditions:
- entity: switch.harmony_sonos
state: 'on'
card:
type: entities
show_header_toggle: false
entities:
- entity: input_number.amp_volume
icon: mdi:volume-high
- type: custom:mini-media-player
entity: media_player.sonos_connect
artwork_border: true
group: true
hide_power: true
hide_volume: true
short_info: false
scroll_info: true
show_progress: false
show_shuffle: true
Wich renders into:
It would be amazing to optionally be able to map the volume control of the mini-media-player
to an input_number
instead of the actual volume of the media_player
. And also optionally map the mute
action to a service call or to a switch
(template_switch
or mqtt switch
for example) to get a feedback on the actual mute status.
Also in my case the amplifier is not another media_player
as itās controlled over RS232.
For information, hereās the configuration of the input_number
input_number:
amp_volume:
min: -80
max: 0
step: 0.5
unit_of_measurement: dB
Thanks for your feedback on this
Iāve just tried to swap to the bundle versionbut now the mini media_players dont show at all, givin gthe red lovelace error block
I simply followed the instructions:
Install
Simple install
- Download and copy
mini-media-player-bundle.js
from the latest release into yourconfig/www
directory.
- Add a reference to
inside yourui-lovelace.yaml
.resources: - url: /local/mini-media-player-bundle.js?v=0.9.2 type: module
I now have this in my ui-lovelace.yaml:
resources:
# https://github.com/kalkih/mini-media-player
type: module
title: Home
- id: 0 # Automatically created id
title: default_view
icon: mdi:home
cards:
- id: 8400f4da4fcd45c1a4c0e6ff169a2fae # Automatically created id
entity: media_player.house
icon: mdi:speaker-wireless
group: false
power_color: true
What have I done wrong?
Did you restart HA?
yep, I have a couple of times
wrong versionā¦
resources:
- url: /local/custom-lovelace/upcoming-media-card/upcoming-media-card.js?v=0.2.9
type: js
Iām not sure the indenting you have for the github isnāt a problem either.
Thenā¦
- id: 4
title: Media Mini
icon: mdi:boombox
cards:
- id: 462a205b39114134b68895e6f08be7ce
type: entities
title: Google Devices
entities:
- entity: media_player.all_speakers
group: true
show_tts: google
artwork: cover
power_color: true
scroll_info: true
which is different to yours.
I just realised my error. I had forgotten to include the subdirectory that I have my custom-ui resources in when I copied the bundle info:
this:
needed to be this:
- url: /local/custom_ui/mini-media-player-bundle.js?v=0.9.2
after that change its all working again now
changing from the non-bundle to the bundle was the only change I made and everything was working prior, but its all good now and working again as per above
you do have the wrong version numnber so it works but if you are using the custom-updater it might not work properlyā¦
thats the current version on GitHubā¦
oh bugger youāre right! I showed the wrong card anyway - upcoming-media-card. lol. similar name.
Hey @RomRider!
Unfortunately I donāt have any plans to add this kind of functionality at the moment, it would require quite a bit of extra code and add complexity.
If the amplifier actually was a media_player this could be solved quite easily by stacking two differently configured mini-media-player
cards, like below.
- type: entities
entities:
- entity: media_player.sonos
group: true
hide_volume: true
hide_power: true
show_shuffle: true
- entity: media_player.amplifier
group: true
hide_controls: true
hide_info: true
hide_power: true
I use the broadlink custom component to control my 15 year old amplifier via IR and because its a media_player in HA, i am able to use it with this mini player. Iām wondering if a forked version of the broadlink component cuold be used to control RS232ā¦? Its WAY out of my league but maybe something with coding skills could do. It would make the control lof your amp a $#!tload better!
@RomRider @sparkydave does this component help?
It seems you can make a virtual media player out of different components.
Thanks @nickrout! This might work. I always thought this component was to aggregate media_players together only, I didnāt remember that it had the possibility to use services and map attributesā¦
I managed to make it work with the universal component:
- 1 switch for the power
- 1 switch for the mute
- 1 sensor for the volume state to reflect the volume of the amp in the right scale for the media_player component
- 1 sensor with the real value of the volume
- 1 input_number to set the volume on the amp (not the same range as the sensor)
media_player:
- platform: universal
children:
- media_player.sonos_connect
commands:
volume_up:
service: input_number.set_value
data_template:
entity_id: input_number.amp_volume
value: '{{ states.input_number.amp_volume.state | float + 1 }}'
volume_down:
data_template:
value: '{{ states.input_number.amp_volume.state | float - 1 }}'
volume_set:
data_template:
value: '{{ volume_level * 100 - 80 | float }}'
volume_mute:
service: switch.toggle
entity_id: switch.amp_muted
select_source:
service: media_player.select_source
data_template:
entity_id: media_player.sonos_connect
source: '{{ source }}'
attributes:
state: media_player.sonos_connect
is_volume_muted: switch.amp_muted
volume_level: sensor.amp_volume_universal
source: media_player.sonos_connect|source
source_list: media_player.sonos_connect|source_list
The only caveat was that the volume is from 0.0
to 1.0
on a media_player component so I had to do some math to convert the -80dB
- 12dB
range of the amplifier to a 0.0
- 1.0
float.
Thanks a lot @nickrout !
Anyone using this in conjunction with the echo devices as a media player component?
That has a tts built-in which you call via media_player.alexa_tts service:
{ āentity_idā: āmedia_player.bedroom_echoā,
āmessageā: āmessage goes hereā }
There is no tts component setup so not clear on how you would configure access with this player?
